Technical 1932 Pickup Bed Dimensions.
Discussion in 'Traditional Hot Rods' started by chev34ute, Sep 27, 2024.
  1. chev34ute
    chev34ute
    The Pickup is in for final ***embly and with the floor yet to go into bed, I was able to get the much needed measurements for the frame. A couple of surprises were noted. The biggest ones were the gaps between the leading edge and the sides.
  2. chev34ute
    chev34ute
    I think it has something to do with the frame needing to line up with the mounts on the ch***is rails.
  3. chev34ute
    chev34ute
    I was also able to get measurements of all the cross rails.
    01961682-AFEA-4DEB-82D5-DC78A6892140.jpeg 3052D0C3-5AEC-4D36-A238-FE3D96D58ACD.jpeg 1C7D69E8-501E-4911-9F87-D23CCABF54C8.jpeg 3723B61E-E80F-4D0D-8A16-20CBC759F3FA.jpeg
  4. chev34ute
    chev34ute
    With all that out of the way, I’m keen to get to work on the cross rails first, starting with the one the tailgate attaches 16B9DF9B-00F1-46DF-89A7-40B7A55F24EA.jpeg 44C879C5-64F8-4F79-9C8C-C76DAD4D427A.jpeg 0FE40A1F-FBD6-4ED1-BFF2-A8B5ADC0A92D.jpeg to.
  5. chev34ute
    chev34ute
    There’s a quarter inch stepped flange running along the top where the mounts for the hinges fasten. I will be able to make this section in the bend brake.
  6. chev34ute
    chev34ute
    The other thing I got measurements of is the floor. They were originally steel but the owner decided he wanted a timber one instead. This one is constructed from a single sheet of 3/4 inch ply for simplicity. Notice how the bed is varnished different shades of stain to simulate individual planks, once the stainless steel bed strips are fastened it’s hard to tell, it’s a single unit. I can source this from my local lumber yard.
    clem likes this.
  7. chev34ute
    chev34ute
    Hey Guys.
    The pickup was back in the workshop last month so I was able to get much needed patterns of the sides and the tailgate. This is the pattern for the sides. I also took patterns of the tailgate and bead profiles.
  8. chev34ute
    chev34ute
    The other big development was ordering a full slab of 3/4 inch thick form ply for the bed along with 1/8 sheet of regular ply and lengths of 1 x 1 angle iron. Once cut to size the slab will act as a jig for the three sides to fasten to. The angle will fasten to the bottom edge of the sides and the bottom edge where the bed will sit.
  9. chev34ute
    chev34ute
  10. chev34ute
    chev34ute
    The second length of angle will sit just below where the floor sits. There are three points of reinforcement that tie the sides together.
