Hot Rods 1932 Roadster Build
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Mar 7, 2011.
  1. 48 Chubby
    48 Chubby
    Yeah, most of those comparisons are going to be like,"Well it's a pretty nice roadster, but it don't measure up to the one that Cory built."
    Not all good hits are home runs, but this one is.
  2. Randy P
    Randy P
    from Austin, TX
    I love it, and vote for leaving it alone unless it settles more.
  3. CTaulbert
    CTaulbert
    from Detroit
    Thanks a lot. Luckily, the rear suspension can be completely bottomed out and not have any rubbing issues with the tires.
    btw, your coupe....the best looking '39-40 coupe I've seen.
  4. sk8erdave
    sk8erdave
    ive ust read the whole thread. WOW you nailed it. It sounds amazing.
  5. kisam
    kisam
    Wow Cory, so impressive!
  6. Deuce_Eddie
    Deuce_Eddie
    from Portugal
    Photos do trick you sometimes... the screen doesn't look so heavy now in this set. It's all in the perspective, I guess.
    Have you decided what colour the interior is going to get trimmed in?
    Cheers, Eddie
  7. CTaulbert
    CTaulbert
    from Detroit
    The interior is going to be dark brown
  8. CTaulbert
    CTaulbert
    from Detroit
    I finally got around to making a mount for the fuel gauge (instead of looking in the tank every so often). I had welded a couple of threaded bungs to the backside of the dash before it went to paint, to the left of the column just for the fuel gauge.
    I made a bracket to mount to the dash, that allows the gauge cup to rotate upward 120 deg so the gauge can be behind the dash, out of sight, when not in use so the dash doesn't looked cluttered. I made a detent at each position so the gauge has a positive hold at each position. The wiring was already ran, so it was just a matter of painting it and installing it:
    On it's way up out of sight behind the dash:
  9. Damn,I love this car!!!
  10. chopt top kid
    chopt top kid
  11. 296 V8
    296 V8
    from Nor~Cal
    I really like the way its sitting.
    To me a fenderless car should sit just barely to low to have fenders….but not any lower….fender well even or just slightly higher that the top of the tire.
  12. CW's40TPU
    CW's40TPU
    Your car is PREFECT!
    Like the fuel gauge idea, i'm thinking the same for AC outlets for my 40PU.
    Thanks....cw.
  13. Nads
    Nads
    from Hypocrisy
    I love the blackness of it all, it's a beautiful car.
  14. Brog
    Brog
    Gorgeous, it's a shame your awesome metal work had to be covered up by that good lookin' paint!
  15. hasty
    hasty
    Looks fantastic! In the early pictures the rear wheels looked very tight to the body but they look great now - did you space them out a bit or is it an optical illusion?
  16. paperdog
    paperdog
    well like everyone says great .. i need to ask whats next?
  17. Weedburner 40
    Weedburner 40
    What is probably even more impressive than the quality of the build is the trick ideas you have come up with to solve the little things to keep it so clean.
  18. CTaulbert
    CTaulbert
    from Detroit
    In the real early photos, the rearend was just about 1" narrower. I had to change the axle flange offset to work with the Lincoln brakes, so I had some new axles made. Each wheel is spaced out less than 1/2" from the early photos.
    The last photos of the car fully mocked up, before paint, did have the current offset.
  19. FOURTYDLX
    FOURTYDLX
    Cory Did you wind up with 56" or 57: hub width? Les thanks.:
  20. rat seeker
    rat seeker
    Wow, what a thread!
  21. CTaulbert
    CTaulbert
    from Detroit
    56" drum to drum
  22. Samcote2000
    Samcote2000
    from San Diego
    I've spent the last hour looking at this build from start to finish and I'm in absolute awe. Most incredible build I've seen and the outcome shows every attention to detail you put into it. I'm hoping to start my 32 build within the next year and your car and your work are a complete inspiration for us young guys obsessed with the hobby and lifestyle. Thanks again and congratulations.
  23. Lil32
    Lil32
    great build enjoy cruising from Lil32
  24. doubletubtrouble
    doubletubtrouble
  25. shiftervic
    shiftervic
    from So. Cal.
  26. rob lee
    rob lee
    from omaha,ne
    Bad*** car,great plan and follow through!
  27. FOURTYDLX
    FOURTYDLX
    Cory: your building a piano,not a uprite, A GRAND PIANO. JUST NEAT.
  28. 29ToyA
    29ToyA
  29. CTaulbert
    CTaulbert
    from Detroit
    Thanks Sam, it was good to meet you at GNRS this year.
  30. CTaulbert
    CTaulbert
    from Detroit
    The weather has cooled off here quite a bit, so the car has been in the garage. It's probably for the better, so I can get some things finished that I've been putting off. My dad finished the bows and header for the top for me a few weeks ago. When we came through KC on the way to and from Austin, I picked them up. This week, I blasted the irons, and shot them in a semi-gloss black.
    Then, this morning, I ***embled the top again, put it on the car, and started another masking tape top. I laid out two different side window options. I'm not 100% what I'll go with, but I'm leaning towards the first style:
