Hot Rods 1932 Roadster Build
Discussion in 'The Hokey Ass Message Board' started by CTaulbert, Mar 7, 2011.
  1. CTaulbert
    CTaulbert
    from Detroit
    I've been staying busy on the car. Over the past week, I finished the oil lines for the filter setup, and ran the fuel lines from the pump to the carbs using some banjo fittings and NOS thumb tower clamps. The distributor came back from Baxter, fresh throughout and timed on their timing machine.
    I also got the dash tunnel ***embled with a new panel, the gauges, and some '33 knobs. The dash light switch is now a dual axis toggle, that uses the left/right axis for the turn signals, down for start, and I still need to ***ign something for the up direction (maybe a toggle between high/low beam).
    The body leaves tomorrow for paint, so installed the Dynamat and Dynaliner so I didn't have to crawl over fresh paint later.
    And finally, here's a shot of the front spreader bar installed. I used some early backing plate bolts, and castle nuts. The thickness of the rail, reinforcement plate, and spreader bar plate were just right for the cotter pin hole to line up with the castle nut - now I just need to pick up some small stainless cotter pins.
  2. erlomd
    erlomd
    Very cool...love it....gauges look sweet
  3. CTaulbert
    CTaulbert
    from Detroit
    Here's a few shots from the progress over the past couple of days. The pedal ***embly came back from the powder coater, so I got that setup in the frame with the master cylinders. Then, I got the clutch ***embled, and bolted the trans up to the motor before sitting them in the frame. The front suspension came back from the painter on Tuesday, so I began to ***emble it. I still need to install the shock mounts before the front is wrapped up. If all goes well, this may be a roller but the end of the weekend.
  4. bonesy
    bonesy
    I love all the black components. That front end is perfect.
  5. CTaulbert
    CTaulbert
    from Detroit
    Here's the Sunday night update - I pretty much finished up the ***embly on the front suspension. After that, I turned to the rear and began ***embling the quick change. Here's the car as of tonight sitting on it's own weight. Hopefully, I will be starting the motor in about a week.
  6. general gow
    general gow
    MODERATOR
    wow! holy cow. that's looking great!
  7. billylo
    billylo
    Man I wish I had your frame sitting underneath my 3 window. I might finish it then. :) Looking good.
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Love all the finish choices. Nothing looks better next to fresh cast aluminum then shiny shiny black paint. Killer!
  9. Pewsplace
    Pewsplace
    Stunning ch***is and detail. You should be real proud of your efforts. Henry would be proud of your finished product. I want one for my sedan.
  10. langy
    langy
    Only just found this thread and went through all the pages, great job.
  11. Looking good, makes me want to get going on mine (once I've won the lotto). Meantime can I just droll over yours :)
  12. Jimmy Tee
    Jimmy Tee
    That is a Damn nice looking Engine & Frame. It's coming together real nice.
  13. kisam
    kisam
    Nice job Cory. I wish I had your skills at such a young age!
  14. Malcolm
    Malcolm
    from Nebraska
    Looks great, Cory... moving right along!
    Malcolm
  15. 296 V8
    296 V8
    from Nor~Cal
    Looks fantastic
  16. CTaulbert
    CTaulbert
    from Detroit
    Thanks Greg. You did that axle for me a couple years ago.
  17. x77matt
    x77matt
    Corey- unreal dude- keep the pics coming. Lets see that body progress!
  18. CTaulbert
    CTaulbert
    from Detroit
    Here's a quick update on the car. I finished up the fuel lines, installed the gas tank, and mounted the radiator. I fired the motor for the first time today and broke it in. The carbs still need to be sync'd, but it's an idea of how the car sounds. I'll get a video with better audio later this week. The exhaust will come off now to get coated before putting it back on.
    <iframe src="http://www.youtube.com/embed/EUEBK3xsUQ0" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
  19. drmrman
    drmrman
    from new Jersey
    Motor sounds incredible. whole build is awesome.
  20. Copper Top
    Copper Top
    Major milestone, Congratulations.
  21. My1932
    My1932
    Quality work all across the board. It's been a pleasure following this thread so far..looking forward to more updates...
  22. youngrodder1929
    youngrodder1929
    loooks awesome !! really like the all black look
  23. attitudor
    attitudor
    from Finland
    Beautiful fabrication. I love everything in that Roadster!
  24. Rickabilly
    Rickabilly
    Ahh,
    Just like the sound of a newborn crying:)
    Well done Daddy, P*** out the cigars,
    Rick
  25. CTaulbert
    CTaulbert
    from Detroit
    One more video with some better sound and picture. Ignore that p***enger side radiator hose....I cobbled together that hose just for running the motor right now. I'm going to weld up some tubes this weekend and just have rubber couplers at the head and radiator.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/5dg4pxjmx0E" frameborder="0" allowfullscreen></iframe>
  26. 123pugsy
    123pugsy
    Phenominal workmanship and a real cool vid to boot.
    The motor sounds sweet.
    Looking forward to updates.
  27. Hot Rod Elvis
    Hot Rod Elvis
    Sounds awesome!!!
  28. anothercarguy
    anothercarguy
    Cory, I'm not a postoholic...I regularly lurk with much interest. That said, I just went through your whole build thread and capped it off by watching and listening to your video and felt compelled to write. The sight and sound of your flatty and ch***is slapped a grin on my face from ear to ear. Thanks and great work!
  29. 296 V8
    296 V8
    from Nor~Cal
    Wow has it been that long?
    I better start getting something done :eek:
    Kinda proud to have one I did in such a choice roadster &#8230;. I wouldn&#8217;t change a thing if it was mine &#8230;. shes perfect.
  30. x77matt
    x77matt
    Great video! Nothing like thE sound of a healthy flatty! Can't wait to see more Corey- let's see that body in paint!
