Projects 1932ish Project in Newberg OR
Discussion in 'Traditional Hot Rods' started by isaiah1000, Apr 16, 2024.
  1. DDDenny
    And not a cel phone in sight!
    isaiah1000 likes this.
  2. isaiah1000
    isaiah1000
    What a beautiful car! And a great color. Looks like a great day on the beach... except the broken leg
  3. isaiah1000
    isaiah1000
    Or wind... they must not be in Oregon ha
    oliver westlund and Tim_with_a_T like this.
  4. isaiah1000
    isaiah1000
    I still feel a little way off, so I haven't really been looking (and Summit red is looking likely) but this stream got me looking... I think my dream color is "medium maroon".
  5. Like what you have done, seems well considered with solutions that are yours. Looking forward to the cowl/dash are repairs and integration. Keep it up.
  6. I read so long and still missed that all I read was the first "page", I will revisit another day.
  7. isaiah1000
    isaiah1000
    We hauled it to DMV and got a ***le and plates! I've been picking away at little fit things. Steering column was almost rubbing the headers so I moved it a little. Hood is getting lots of attention as it had some cracks and isn't fitting quite like I'd like. I'm finding as I straighten it out it fits better. Even though I have the cord at the firewall, the hood is still sitting low. I might need to put something under the cord, or find a bigger cord to get it to match the cowl level. Anyone else deal with this? The funny thing is, the cowl and hood are from Ford so I would have ***umed they'd fit better together ha.
  8. Tim_with_a_T
    Tim_with_a_T
    Rad. Nice job dude!
  9. isaiah1000
    isaiah1000
    Thanks Tim! Hope your projects are coming along well!
    Tim_with_a_T likes this.
  10. pprather
    pprather
    I've heard the reproduction hood cord is often too thick and needs to be pounded flatter on the work bench prior to install.
    Nice progress!
    I like the OG on the new plate.
    19Eddy30 likes this.
  11. isaiah1000
    isaiah1000
    Me too. Oddly, it seems like mine isn't thick enough as my hood sits noticeably below the cowl's body line right now.
  12. RockyMtnWay
    RockyMtnWay
    This cowl fit deal is pretty common from what I’ve seen. Way I solve it is to cut some fuel line hose in half and hide it under the lacing.
    pprather, 19Eddy30 and isaiah1000 like this.
  13. isaiah1000
    isaiah1000
    Good to know, thank you. I thought maybe I did something wrong since I saw posts complaining that the rope stuff was too thick and I seemed to be having the opposite problem. I was wondering if I forgot a spacer under that center-of-cowl hood strap holder thing... but then if I raised that up it would be higher than the cowl bead so I doubt it. Fuel line, I like it.
  14. 19Eddy30
    19Eddy30
    from VA
    Over the year the lacing go's flat , need to build up ,,, then there is New way to thick ,,
    Nice looking !
  15. isaiah1000
    isaiah1000
    Thanks!
  16. DDDenny
    Just a thought........could the body to frame welting be too thick, causing the mismatch?
  17. clem
    clem
    Is this what you are using ?
  18. isaiah1000
    isaiah1000
    Good thought, but the hood line bead isnt lining up with the bead on the cowl and it's lower than the profile on the top of the cowl so i think i can safely say my hood is a little low. There's also a slightely larger gap near the bottom of the cowl, also indicating it needs to come up at the top/back
  19. isaiah1000
    isaiah1000
    Yep, although i think i might try some of this newer thick stuff ha. Mine came in an old bag with my Ford parts and was older... probably the older thinner stuff ha
  20. DDDenny
    If you havent's done it, it's a good idea to get a good "standback" (way back) look at how the hood top flows from the cowl to grill shell, I've seen a lot of real nice cars over the years that you could tell they were built in a narrow shop.
    Some slight shimming under the radiator/grill shell may also be needed.
    Roll the car outside, but you'll have to wait until the big rain "event" that is predicted has p***ed.
    Oregon, you would have thought they'd have fixed that by now.!
    clem likes this.
  21. oliver westlund
    oliver westlund
    I think the one you saw for sale I bought if it was in portland. It was a slightly cut up and slightly rusty 32 pickup cowl with no a pillars
