History 1933 - 1936 Willys, picture thread
Discussion in 'Traditional Hot Rods' started by WillysRule, Dec 5, 2010.
  1. Marty Strode
    Marty Strode
    A steering damper cured the wobble on the Bizio truck.
  2. jnaki
    jnaki
    Hello,
    Yes, death wobble in a new build would cause other problems. But if one looks at the two photos, the original build was getting into the taller suspension set up and drive components. The later year version the suspension is brought down as well as a slight rake and a chopped top to give it some lower center of gravity.
    Racers thought the high suspension and/or for some, raised front end moves the power back to the rear wheels. After some experimentation, the lower ch***is and ground clearance seemed to win in the go fast speed era. Obviously, the inch clearance of the current funny cars and modified coupes are way beyond this era of higher suspension. As the wind tunnel and powerful motor set ups showed in the initial builds.
    So, we all must have learned something over the years. From normal size cars to narrow, shorter wheel based cars were all used in the vast experiments to go fast and faster. But, also, it was the top quality new speed parts and builds that played an important part... not just the "high in the air" stance.
    We all saw what happened to a short wheel base injected, Buick powered FED that was a top record setting race car. Then as more power was added, the problems with a short wheel based build necessitated a better, longer design for the newer, more powerful builds that began to get put together.
    Jnaki
    A narrower body like the 33 Willys raised up may be the starting era for ch***is set up back then, but it definitely did not last long. A powerful motor, a short wheel base ch***is and raised up body just seems like a recipe for something to happen in handling… YRMV
    Charlie K and 1934coupe like this.
  3. Marty Strode
    Marty Strode
    Stickier , wider tires also had a lot to do with the lowering the ch***is height, along with the advent of the burnout.
    jnaki likes this.
  4. mgtstumpy
    mgtstumpy
    This rare & complete 35 Willys 77 roadster is for sale down here. Holden body
    Fogger, Apenaut, ottersea and 4 others like this.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yes, and slider clutches.
  6. Marty Strode
    Marty Strode
    Rosin "Burn Throughs" and on to spraying the track surface.
  7. 1940Willys
    1940Willys
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Interesting that they chopped the top...
    ...but added windshield wipers.
    I've seen that car run at vintage events.
    EDIT: I see it now has a front license plate so maybe the wipers make it street legal LOL.
    bschwoeble likes this.
  9. earlymopar
    earlymopar
  10. 1940Willys
    1940Willys
    If you are talking about the James Boys Sedan some one did a Clone of it. That might have been the sedan you seen?
    THE FRENCHTOWN FLYER likes this.
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yes, I was referring to the green version. But somebody has edited out that pic, so 1940Willys, you may be correct - that is a different car. So now that begs the quesion, Where is the original car?
    1940Willys likes this.
  12. Dharrell
    Dharrell
    Couple of really clear photos of Quicksilver one from 1965 when ran by WR sanders in KY and the one on the trailer around 69 with it was in IL. I am still looking for the car if anyone may have a slight lead. I recently purchased the engine that was ran in the car when it was last in KY bored and stroked 327 with a reath crank and mondello heads.
    elgringo71, 1934coupe and akoutlaw like this.
  13. 65pacecar
    65pacecar
    from KY, AZ
  14. willys36
    willys36
    It was a tire problem. Early slicks were p***enger car tire recaps with p***enger car hard rubber. Very little traction. Raising the front end put a bit more weight on the rear tires. G***ers used 3" pipe rear axles with screw caps and filled them with lead and/or added dual batteries in the trunk, anything to get weight on the rear tires. As soon as tire companies started making soft compound racing tires that got awesome traction, the noses came slamming down.
    loudbang, bschwoeble and jnaki like this.
  15. Gypsyflier
    Gypsyflier
  16. Gypsyflier
    Gypsyflier
    My '35 I've had since '99. Ex Chuck Finders body. He used it to make molds.
    1940Willys and elgringo71 like this.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Fun fact: Chuck had a ground effects tunnel under his '33 that exited out behind the rear window that kept the car glued down at speed.
    tommyd, 1934coupe and elgringo71 like this.
  18. enloe
    enloe
    from east , tn.
    Southeast G***ers race today
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    wow - a 409. I didn't see that coming.
  20. Marty Strode
    Marty Strode
    And Lamar Walden Jr., it should run good!
    elgringo71 likes this.
  21. elgringo71
    elgringo71
  22. enloe
    enloe
    from east , tn.
    The grandson was also there running a 61 Chevy with a hot 348. It was BAD*** as well
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    What's next??? A '33 Willys with an inline six? Preposterous - have you no shame?
  24. 1934coupe
    1934coupe
    No shame at all Frenchtown, mine had a 4 cylinder chevy.
    Pat
  25. Dharrell
    Dharrell
    W.R Sanders p***ed away at 89 on Friday. Original owner and driver of the Witchcraft as well as Quicksilver 33s in the 60s both of which I have been trying my hardest to find for the last several years which little to no luck. Will continue my search but sad he will not be here to see it if I find one of them.
  26. jnaki
    jnaki
    Hello,
    Some of those statements are a little off. The time periods have to be listed to be accurate. To say the 60s did this or that, covers 10 years and in the early 1960-64 years, was a lot different than 1965 and later when the Gas Coupe/Sedan cl***es went crazy and soon disappeared. What was once legal street converted cars with stock equipment and headers was then a street legal car, if nothing else was changed. But, that moved any stock car to the Gas Coupe Cl*** with one simple set of headers not from the factory.
    Forget a bumper at home, because you used the brackets for the tow bar? No problem... a street legal gas coupe goes right into the Altered Cl***. No mufflers under the car during eliminations, that move deemed those legal Gas Coupes into the Altered Coupe cl***es, too. And it is still a streel legal car, without a front bumper. But, street legal requirements are/were the drag racing rules at the time.
    On the West coast, racers went from original soft Bruce Slicks to wider Bruce Slicks until the advent of the M&H series. Then, those M&H slicks were a lot wider and had more traction. The weight over the rear tires were taken care of by adding weight inside of the trunk. But, when other racers complained, the rules changed to making those weights part of the ch***is, by welding them in place, not using weight room circular weights, strapped down.
    We went one step further by getting 1 inch thick steel plates welded into the rear floor of the trunk. Some were over the floor and stiffened the structure. There were more plates welded above the rear axle. The weight over the axle was important as the Bruce Slicks still grabbed and launched quite well after the weight. Plus, the added weight allowed us to go to the compe***ive C/Gas cl***.
    All were checked by the tech inspectors at Lion's Dragstrip and deemed legal for the Gas Coupe and Sedan cl***es. Street legal was a real thing at one time, headers with mufflers and exhaust pipes... AND drive-ability on the local streets as a Saturday night cruiser. No individual pipes from the motor by themselves until the late 60s. Times changed and so did the cl***.
    Jnaki
    As far as the noses up in the air, it was not during the real legal street Gas coupe and sedan cl***es. It was during the late transition from a 37 Chevy so powerful to raise the front end upon acceleration that made others think "up in the air" moves weight back and the car forward faster. Not a proven technique, but a fan favorite thing to do.
    After the gas tank ruling for moving them out of the cab to the front or rear in the trunk, most thought the front was a shorter distance to the motor and hid them behind the grill. Actually, the ruling was for the FED and Altered Roadsters/Coupes to move them forward, not for street usage cars. The rules committee wanted to stick the Gas Coupes gas tanks back in the rear where they were actually stock. So, some modifications were made and the shorter area in front look stuck. Not for the better.
    Then some decided that it was too difficult place, so they moved them outside of the grille... It was a street legal car insurance nightmare for real street legal cars. By this time the real street legal cars were now sporting individual headers and other modifications for more performance. But legal for the street? Very questionable, as the legal cl*** was waning, the tech committees allowed a mod here or there and soon, the so called "street legal" coupes became no so insurance company legal for the street.
    The racing cl***es began to fade out and soon all sportsman cl***es like the old Gas Coupe and Sedan + Street Roadster cl***es were so modified that they were eliminated or moved to the Altered cl*** or eliminator cl***es, which lasted another year or so, then they too, bit the dust.
    upload_2024-8-6_5-4-24.png K.S. Pittman 1964 gas cl***
    versus:
    A much later version…exhibition
    So, it is important to signify which period of the 60s is the era you or anyone is talking about, without infringing on what was actually done in a timeline fashion. The 1960 to 64 era looked similar to the 65-68 era, but each designated period changed the rules and the ordinary cl***es for the m***es as originally thought of for dragstrip use, just faded away in the name of more dollar sponsorship and entertainment money.
    The last K.S. Pittman race car... Friday Art post
    As far as the 33-36 Willys was concerned, there were a few back in the late 50s, but mostly they were odd ball styles not in favor like the 33-34 Fords and Chevy models.
    The little guy got left out of the whole picture and now, today we see three categories for what is called: "Drag Racing in the USA." Fuel Dragsters, Funny Cars and Motorcycles. (The theory of high in the front was bunk as the current racers can't put a pack of cigarettes under their cars...)AND... money poured into the race cars like we could not ever imagine when we all started our backyard hot rod builds, just so we could go a little faster than our friends and neighbors. Ha!
    Some progress...YRMV
    bschwoeble, 65pacecar and drumyn29 like this.
  27. TheMerch
    TheMerch
  28. willyfaster
    willyfaster
    from minnesota
  29. willyfaster
    willyfaster
    from minnesota
  30. willyfaster
    willyfaster
    from minnesota
