History 1933 - 1936 Willys, picture thread
Discussion in 'Traditional Hot Rods' started by WillysRule, Dec 5, 2010.
  1. edfueler
    edfueler
  2. willys36
    willys36
    Yep. the way to easily tell if it is a '33/34 body or a 35/36 body is the door handles. Also, if it is steel, the gas filler is a tell tale. '33/34 door handles are swoopy, curvy style, whereas 35/36 have stubby hotdog shaped ones. Also if the car has stock steel rear panels, the 33/34 gas filler is located in the spare tire panel whereas the 35/36 is in the body panel between the fender and spare tire panel. All pickup and sedan delivery g***ers are 35/36 since they didn't make those body styles in early years. Most "33" g***ers are actually '36 cars since the company was in receivership in 33/34/35 and made few cars, cranked up production in the last year.
    Production Numbers
    1933 - 12,819
    1934 - 13,234
    1935 - 10,644
    1936 - 72,295
    ***ume 95% of them got crushed in junk yards, that left only about 5,000 of them for us to find in garages, out rusting in fields.
    Incidentally they were $325 for the standard model, $375 for the deluxe with different colors on body and fenders.
    Ohio George's car was a 33/34
    SWC's Dark Horse which later became the Altizer Finders Kibler Traveler was a 35/36.
    "33 Willys (see gas filler)
    35/36
  3. WillysRule
    WillysRule
    from Central FL
    The Stone Woods Cook & Finders Dark Horse 33 was a gl*** car. As you said, it became the Traveler, but it was gl***.
    1934coupe and loudbang like this.
  4. Forget the door handles, they can be changed. 1933-34 Willys have a glove box in the dash, 1935-36 do not. 1933-34 have a flip out windshield, 1935-36 have a windshield frame that is attached by screws from the outside. I won't go into other details as far as early 1935 verses late 1935-36, as a lot of the cars were built using what was left available from the previous years production. This was common for the time, as Ford did the same thing.
    33skippy likes this.
  5. loudbang
    Malco
    Hamberie & Mitchell
    Bucksnort?
    1947knuck and 41 coupe like this.
  6. willys36
    willys36
    Hmmm . . . I think the body was steel but it definitely had a lot of 'gl*** parts. Article says, "The four inch chopped top tends to heighten the ferocious look of the stock '33 Willys Coupe. Cal-Automotive furnished the numerous fibergl*** parts such as: front and rear fenders, hood, grille, doors, and deck lid." Car Craft note says, ". . . ."Traveler", a fibergl***-furnished Willys coupe . . .". It definitely ran a stock frame.
  7. willys36
    willys36
    Absolutely true, back then it was 'run what you brung', guys put together cars out of whatever they could find. However since the '35/36 version amounted to 76% of the total production of Model 77s, '33s and '34s were only 12% of the total respectively, it is much more likely than not, most '33 Willys were really the later models. Incidentally cracked 2 windshields in my '36 by nicking them with the rim screws because the gl*** was cut just a tiny bit too big by the gl*** shop!
  8. 26 T Ford RPU
    26 T Ford RPU
    I have an unmolested 35 sedan and it has a glove box in the dash, the 36 has the different dash and fixed wind shield. JW
  9. Squablow
    Squablow
    loudbang and 26 T Ford RPU like this.
  10. Speed Gems
    Speed Gems
    26 T Ford RPU and loudbang like this.
  11. Speed Gems
    Speed Gems
    Jack Merkel's car at the 2014 Meltdown Drags.
  12. Speed Gems
    Speed Gems
    I didn't see this one posted yet.
    1947knuck, rfraze, WillysRule and 4 others like this.
  13. Speed Gems
    Speed Gems
    I think the production numbers are off a little in this article but i figured i'd post it anyway. It's from the April '17 issue of Hot Rod.
    1947knuck, 41 coupe and loudbang like this.
  14. Wow, every year i look through the coverage of this great event on here and this is the first time I've seen a photo that I'm actually in. Well almost, I'm all the way on the left cut in half. That's a good friends rig and I'm guessing this pic is from when we cackled the dragster.
  15. Speed Gems
    Speed Gems
    Hmm... I thought i croped the half guy out of that picture. I guess now i'm glad i didn't. It may have been when Bones was sitting in Mr. C's dragster just before i got Isky's autograph.
  16. Speed Gems
    Speed Gems
  17. UOTE="Speed Gems, post: 11940117, member: 191851"]Hmm... I thought i croped the half guy out of that picture. I guess now i'm glad i didn't. It may have been when Bones was sitting in Mr. C's dragster just before i got Isky's autograph.[/QUOTE]
    That's what I was thinking, or possibly when C***andra was sitting in it if you were there at that time also. Unofficially, Bones and Isky may be back again this year but you didn't hear it from me. I was at Bones house in Oct after Bakersfield weekend
    loudbang and Speed Gems like this.
  18. Speed Gems
    Speed Gems
    A few pictures i took in Arizona a couple of years ago.
    10414450_1023013974380785_8873296802632470130_n.jpg 10981955_1023014097714106_1690637060320556010_n.jpg 10991357_1023013997714116_8865441484717801130_n.jpg 10997517_1023014021047447_2532987461017922926_n.jpg
  19. willys36
    willys36
    It is 100% modern 'gl*** car but definitely has the look, correct engine. Here it is @ Bakersfield CHRR in 2010. Was probably brand new then as I recall it had trouble making p***es down the track.
  20. Del Wiesner built this as a tribute to his original car he raced in the 60's . I was at the Thompson, Ohio G***er reunion the year he picked up the body and ch***is. His original car became the yellow coupe of Jess Belton if I remember right. It came up for sale about the same time period but Del said it was to much money as he'd start all over anyway.
  21. willys36
    willys36
    I was at that event too! Got a business card from the guy making the aluminum repros of the Halibrand G***er front wheels, bought a pair when I got home.
  22. loudbang
    Mike Mitchel
    Malco G***er
    1947knuck, t-rod and 41 coupe like this.
  23. landseaandair
    landseaandair
    from phoenix
  24. 1934coupe
    1934coupe
    1934 Willys sedan, if she only knew that many years later it would be a g***er.
    Pat
  25. landseaandair
    landseaandair
    from phoenix
    Written on the back it says picking blackberries in Oklahoma.
  26. loudbang
    Ambition
    Bones Dubach Pisano
    Jack ****rod & Harry's Kamakazi Koup
    Jack ****rod's Jack the Bear
    Jack Merkel
    Early Merkel
    K S Pittman
    S&S Racing team with K S Pitman in small letters
    vs Big John
  27. The late "Rapid" Roger Garten is shown in the top photo working on the Altizer-Kibler A/GS which he later bought and campaigned in the so-cal g***er wars of the late '60's. Roger moved on to AA/FA driving the Tocco &Harper altered and then into fuel funny car with Mike Tocco and the "Warhorse" F/C. After taking quite a few years off he returned with Tocco and the"Warhorse" nostaglia F/C only to lose his life in a tragic racing accident at Bakersfield.
    loudbang and 41 coupe like this.
  28. Do you or anyone else for that matter know where the WILLYS went after Garten moved on? Never really heard anything about it after the wild Garten & Braskett paint job. Heard a rumor about it at Thompson, Ohio G***er reunion about 15 years ago someone knew where it was.
  29. Looking at the front spring shackles (dog bones) they had no room for spring movement during braking, or down travel from a wheelie. Must have been a hair raiser in the shut down area!
  30. rfraze
    rfraze
