Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. rusty valley
    rusty valley
    well. i check often...but not often enough it seems. went to a good home anyway!
    Elvis100 and loudbang like this.
  2. Elvis100
    Elvis100
    The cowl vent was leaded in and rusted out. I went ahead and cut it out, I can use a couple parts, but I’ll replace most of it.
    Stogy, brEad, Cyclone Kevin and 3 others like this.
  3. Elvis100
    Elvis100
    It seems every 33/34 I get needs this repair. I pressed a new skin piece. There is a scupper that goes under this, thats next on the hit list.
    Stogy, brEad, Cyclone Kevin and 6 others like this.
  4. Elvis100
    Elvis100
    Pressed the scupper, I should be able to reuse the brackets for mounting the vent door
  5. Elvis100
    Elvis100
    Thanks, my motivation is to make them better than when I got them.
  6. Elvis100
    Elvis100
    Finished up the cowl vent. I’m going to wait until I get the cowl media blasted to install it.
    Here is a before and after
  7. rusty valley
    rusty valley
    nice work as usual.
    Stogy, loudbang and Elvis100 like this.
  8. Elvis100
    Elvis100
  9. Elvis100
    Elvis100
    Got the 33 cowl and a bunch of other parts and pieces media blasted. [​IMG]
    Squablow, waxhead, Stogy and 7 others like this.
  10. rusty valley
    rusty valley
    nice an clean
    Stogy, Elvis100 and loudbang like this.
  11. Elvis100
    Elvis100
    I got spoiled with my 3 window body I put back together. I can’t work with rusty stuff anymore.
    Stogy, rusty valley and loudbang like this.
  12. Very cool. Care to share how you pressed those pieces? Dies in a shop press or???
  13. Elvis100
    Elvis100
    I made the dies for my coupe project, relatively straight forward. Had a lot of trouble with the 90’ corners blowing out when pressing. Used a combination of progressive pressing and intermittent hammer and dolly to gently stretch the corners. Ended up about half and half hand forming and die pressing. The scupper die is all metal.
  14. Excellent! Thanks for sharing.
  15. Elvis100
    Elvis100
    Lorenzo90, Squablow, Stogy and 4 others like this.
  16. Elvis100
    Elvis100
    Pulled the new frame rails out and cleaned them. They came with all the holes for fenders and mounting the body, but not the stock steering gearbox or shocks. Went ahead and plotted and drilled. Waiting on a 1 1/8 carbide bit for the rear shocks.
  17. Elvis100
    Elvis100
    Did a few repairs to the center crossmember. Fit the crossmember in the frame. Most of the holes lined up, a couple are off...not critical ones.
    Squablow, cactus1, Stogy and 4 others like this.
  18. Elvis100
    Elvis100
    cactus1, Stogy, Shadow Creek and 4 others like this.
  19. loudbang
    Those are some BIG C clamps. :eek:
    Elvis100 and rusty valley like this.
  20. Elvis100
    Elvis100
    I’ve been working on top irons for the project and for sale to support the project. The first set is for sale in the classifieds
  21. Elvis100
    Elvis100
    Fit the rear crossmember and rear shocks. Made the doubler pieces for the rear frame horns
  22. rusty valley
    rusty valley
    be careful, you're gonna become the world renowned model 40 roadster expert...phone will never stop ringing, emails all day...you see the picture !
  23. Elvis100
    Elvis100
    The funny thing is...this is what I started with four years ago.
    Squablow, brEad, Stogy and 5 others like this.
  24. Elvis100
    Elvis100
    Squablow, brEad, loudbang and 3 others like this.
  25. rusty valley
    rusty valley
    i am disappointed, why boxing the rear?
  26. Elvis100
    Elvis100
    Unfortunately my center crossmember stops about where my boxing plate starts.
  27. Elvis100
    Elvis100
    Welded the doubler and fit the rear crossmember with the boxing plate
    Stogy, Squablow, loudbang and 2 others like this.
  28. Elvis100
    Elvis100
    Made some modifications to my rotisserie and mounted the frame to it.
    Stogy, Squablow, waxhead and 5 others like this.
  29. Elvis100
    Elvis100
    Did a repair where someone had nibbled a larger hole for hydraulic brakes.
    Stogy, rusty valley, brEad and 6 others like this.
  30. nunattax
    nunattax
    Stogy and loudbang like this.
