Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
  2. Squablow
    Squablow
    Those top irons are a work of art. The frame work is very clean as well, nicely done.
    Stogy, Elvis100 and loudbang like this.
  3. Elvis100
    Elvis100
  4. Elvis100
    Elvis100
    Setting up the brake and clutch pedals. Normally the clutch and brake pedal rotate abound a 7/8 shaft that is pinned to the bracket and operate mechanical. I found a thread on here where a guy put bosses with bushings on the bracket allowing the shaft be pinned to the brake pedal and rotate in the bracket allowing for a leaver on the end of a longer shaft to operate hydraulic brakes.
    Cut the bosses off
    Welded bosses with bushings
    Made a lever using the arm I cut of the brake pedal
    Mocked up, still need a longer shaft(ordered). Need to drill and tap the new bosses for grease fittings and drill the brake pedal, lever and new shaft for pins
    wheeldog57, j hansen, Stogy and 3 others like this.
  5. Elvis100
    Elvis100
    Stuck the cowl on to check pedal positions...had to force myself not to put a radiator, grill shell and hood
    Squablow, bowlingball, Stogy and 3 others like this.
  6. Elvis100
    Elvis100
    Installed “rivets” in the front and rear crossmembers.
    They are made with a nut that will sheer and leave the appearance of a rivet. I’ll then rotate the frame and fill the center with a weld
  7. those are slick! Where do you source those from?
    Stogy and loudbang like this.
  8. Elvis100
    Elvis100
    Stogy, loudbang and uncle buck like this.
  9. Elvis100
    Elvis100
  10. Elvis100
    Elvis100
    Finished up the pedal conversion. Made a bracket for the master cylinder.
  11. Elvis100
    Elvis100
  12. I like that! Weld them up, smooth them out and no-one is the wiser.
    loudbang and Elvis100 like this.
  13. Elvis100
    Elvis100
    And I think they will be about as strong as the original rivets
  14. Elvis100
    Elvis100
    Spent the afternoon cleaning the rear floor pieces. They had been on the shelf for a couple years.
  15. Elvis100
    Elvis100
  16. uncle buck
    uncle buck
    Excellent work!
  17. Elvis100
    Elvis100
    Thanks
  18. Elvis100
    Elvis100
    More fitting. I’m concerned that since the rear is fixed and the cowl is fixed...everything has to meet in the middle with good door gaps.
  19. Elvis100
    Elvis100
    With the acquisition of the 1933 roadster, the nice 33 dash I had for this one will go to it more appropriately. Not to worry, I picked up a nice unmolested 1934 standard roadster dash in a deal last spring.
    Since there were only 4 standard roadsters produced in 34, it probably came from one of the pheatons
    Squablow, brEad, loudbang and 2 others like this.
  20. Johnboy34
    Johnboy34
    from Seattle,Wa
    Even if it came from a standard phaeton it's still a very rare piece.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  21. uncle buck
    uncle buck
    Now I know where my missing dash is...
    lol
    Elvis100, loudbang and kidcampbell71 like this.
  22. Elvis100
    Elvis100
    Remade the front floor stiffeners and installed them.
    Had to press the end of a couple detents in the floor, when I make the center floor part I’ll continue the indentation.
    Squablow, j hansen, brEad and 4 others like this.
  23. Elvis100
    Elvis100
    Disassembled and cleaned the transmission. Ordered a couple parts that were deficient. [​IMG]
    Squablow, brEad, el Roach and 2 others like this.
  24. Elvis100
    Elvis100
    Made a set of A-pillar brackets and bolted the cowl to the frame with the carriage bolts. The subrails still need to go in this stack.
  25. greaser
    greaser
    Just beyond impressive. Your fabrication skills are incredible.
  26. Elvis100
    Elvis100
    Made the stiffeners for the rear floor and plug welded them in.
    Cut the rectangular hole for the fuel sending unit and mounted the cover.
    Squablow, j hansen, loudbang and 3 others like this.
  27. Elvis100
    Elvis100
    Thanks, I’ve had to up my game for this build
  28. RodStRace
    RodStRace
    I've always admired the model 40s, but this thread has really shown some amazing detail in how the roadsters were made. I went into your history to see what your previous projects were and how you handled them, but this appears to be the first one you have shared. Thanks for documenting this one and I hope you can share some of your past work, too.
  29. Elvis100
    Elvis100
    Thanks, I did a thread for a 3-window body I recently sold.
    1934 ford three window project
    https://www.jalopyjournal.com/forum/index.php?threads/1934-ford-three-window-project.1073172/
  30. Elvis100
    Elvis100
    Squablow, Stogy, lurker mick and 7 others like this.
