Projects 1933 coupster
Discussion in 'Traditional Hot Rods' started by kustomitch, Jan 14, 2023.
  1. kustomitch
    kustomitch
    Well I guess I’ll start a build thread on this one as I’ve made quite a bit of progress over the past year and I’m trying to get it back on the road this spring. A few years ago we pulled this car out of a small little garage a town over. I’ve found quite a bit of history and old photos since then. If anyone else has anything let me know! This was Ronnie Robinsons “voodoo” roadster. It started life as a ‘33 3 window. The roof was cut off and the body was channeled over a ‘32 frame back in the day. The original version of the car looked really cool to me. It was rebuilt a number of times over the years. When we got it it had been redone again probably in the early 2000s. Lots of scary work and parts. I got the car running and driving. It ran really well until the rear end let go due to someone half *** fixing it at some point in time. I really started digging into it then and well here it is.
    The oldest photo I have (found on here). Man I wish it still had that blower on it.
    Second oldest picture and the only one when it was painted yellow
    Stafford speedway I believe
    The Big E
    Spec Pond
    Ronnie with the car 1979
    The day we pulled it out of Ronnies old garage
    The smile on my old mans face says it all
    Yup. It was quite ugly when we got it.
  2. It will be interesting where this goes. Today it would be sacrilege to cut up a three window, but that ship was sailed long ago.
    Greenblade, Outback, Stogy and 2 others like this.
  3. kustomitch
    kustomitch
    Unloaded and it didn’t take long for me to get rid of some of that gold paint
    A tune up and a little carb cleaning and it fired up. (Can’t figure out how to upload a video)
    catdad49, Outback, Squablow and 7 others like this.
  4. rusty valley
    rusty valley
    Yes ^^^, its interesting, but really sad use of a 3W body.
  5. kustomitch
    kustomitch
    Yup! I sure do wish it still had the roof.
    rusty valley likes this.
  6. kustomitch
    kustomitch
    The day it stopped moving. Many issues to address. Pulled it into the shop to tear it all down.
    It was obvious that all the suspension needed to be addressed if this thing was ever going to be back on the road and looking decent. Really the whole car needed to be gone through. It has a c4 trans which I don’t really like but it does make it easier to drive with the channel. The shifter wasn’t bolted to the trans so finding a gear was near impossible. The seat was so high that your head was a foot above the window. The throttle pedal was mounted on the p***enger side of the car and the brake pedal was about a foot off the floor… no idea. The pinion shaft had fallen out the front of the axle because there wasn’t anything holding it in other than the driveshaft and some rtv. Now it needs oversized bearings and a whole rebuild.
    catdad49, Outback, Stogy and 2 others like this.
  7. I remember Ronnie and his roadster from many years ago. I liked the roadster best when it was painted black with flames. He was "The Man" back in the day. I remember being in Ronnie's garage and seeing a Harmon-Collins cam display hanging on the wall. The background was green, and it had a chromed partial camshaft that had several different grinds on it. I always wanted to know what happened to the display. I am not a flathead person, but if I had the display, I would want to keep it in rememberance of Ronnie.
    catdad49, J.Ukrop, Outback and 2 others like this.
  8. kustomitch
    kustomitch
    Started with the rear. This would have been much easier if the body wasn’t welded to the frame! Oh well, can’t get too deep into it. I cut out the scabbed in “crossmember” and put a model a crossmember and new frame horns in its place. Also cut off the big roll pan. Much better stance in the rear.
    New tires came in from towel city. Started looking for some new wheels as the mags were different bolt patterns front and rear with big adapters.
  9. kustomitch
    kustomitch
    Sounds like he was “the man” from what I’ve gathered. I never did see that display. His wife kept the display he had for the car shows.
    Outback, Stogy and VANDENPLAS like this.
  10. kustomitch
    kustomitch
    The front end was even worse. Started by cutting it back to where it looked like the square tube extensions stopped. These were spot welded in a couple spots and filled with bondo… Took quite a while to get those pieces removed. I installed a model a crossmember but couldn’t get my hands on any ‘32 front horns so I used some model a ones I had on the shelf. Ordered a drop axle from roadster supply and got some headlight mounts at the Stafford swap. Put the chrome reverse eye spring I picked up at Hershey a while ago to use too. The chrome parts I’d been hunting down started rolling in. If I remember correctly the wheel was about 120”. It is now 109”. Right in between a 32 and a 33. Much better. Of course owning an upholstery shop, I had to make a seat too. More on interior later.
  11. alchemy
    alchemy
    That fordor was and is still owned by @desoto.
  12. kustomitch
    kustomitch
    With the new crossmembers in I started working on getting the ride height just right and tacked on some wishbone mounts to roll it around.
    Also got real sick of looking at those flames. The car will be getting painted soon but I think I’ve decided on no flames this time.
    I then started doing some little things like drilling out the door and deck lid handle holes. They were just filled with coat hangers luckily and I was able to just drill them out from the inside out. Rolled it outside to take a look. I also redid the fuel system and rebuilt the carbs this day and got it fired up again.
    hook00pad, catdad49, Outback and 7 others like this.
  13. kustomitch
    kustomitch
    After looking for about a year for original chrome slots I ended up ordering some new ones from Phillips on here.
    Then I found some original fronts a few weeks later digging through an old barn of course.
    Came across these old chrome ladder bars on eBay and put some new ends on them.
    Back to work on the rear making new ladder bar brackets, crossmember, and shock mounts.
    The Springfield quick change that still needs to be saved
    There was nothing holding the shaft in on this side so it slid right out the front.
    Chewed up the end of the shaft a bit, ate some bearings, and wobbled out others. It will need to be machine for slightly over sized bearings now.
    catdad49, Outback, Squablow and 3 others like this.
  14. kustomitch
    kustomitch
    When it got really cold in my shop where the car is I started doing some interior stuff at my upholstery shop.
    The old seat
    Old vs new foam
    All rebuilt
    New cover s***ched up and installed and moved on to making some kick panels and firewall panel.
    My inspiration for the interior. These old interiors were so damn cool.
    catdad49, Outback, Stogy and 3 others like this.
  15. kustomitch
    kustomitch
    Got some chrome wishbones to replace the 4 bar setup. Was not easy cutting off those big molded 4 bar mounts but well worth it.
    catdad49, Stogy, Tim and 3 others like this.
  16. kustomitch
    kustomitch
    That brings it to where I am right now. With the crossmember back where it should be the tie rod was hitting the engine. When they installed the c4 trans it looks like they moved the motor mounts forward instead of moving the trans mount back. So in order to clear the fan and the steering everything had to move back 3”. Plenty of room with that big goofy gap between the engine and firewall.
    Cracked motor mount and the engine was too far forward so they torched the bottom of the frame to clear the headers. Both will be fixed of course.
    Doing some wheelies in the shop
    Looks like it only took a few tries to get the trans mount in the right spot…
    Old motor mounts cut off and a little cleaning up on the old k member it fit perfectly where it should be. Closed up the gap, clears the steering, headers clear the frame, fan clears the radiator.
  17. You are doing a great job of updating Ronnie's old roadster. What you have shown in your pictures was how many old hot rods were really built, "rough and tough", or "rude and crude," but pretty, if you don't look too close.
    rod1, catdad49, hook00pad and 4 others like this.
  18. GordonC
    GordonC
    Nice job. Also not your typical looking 33 which is nice.
    Stogy likes this.
  19. I like it. And I like that bad work is being corrected so it doesn't disintegrate at speed.
  20. I believe you mean Skip Readio. He put a lot of miles on that sedan. He also wrote one of Tex Smith's How to do Electrical Systems books (good how to book). I'll keep the book image small as it's not particularly HAMB friendly...and no interest in derailing the thread.
  21. Skip Readio and "Tex" Smith were good friends.
    Stogy likes this.
  22. This is an interesting archeological dig into what used to p*** for fabrication. There is something to be said for 1-800 bolt on parts.
    chlsnk and Stogy like this.
  23. Squablow
    Squablow
    Cool car with some neat history, but the frame butchery definitely was not some great artifact worth preserving, glad it's being corrected. And at least some of the frame from the original build is being saved, which I like, rather than just pulling the body and engine off and starting over from scratch. The previous wacky wheelbase was none too attractive, but it's still clearly the same car.
    I didn't mind the flames, but I look forward to seeing what this car ends up looking like in the end.
    Stogy and NealinCA like this.
  24. kustomitch
    kustomitch
    Thanks. I really like that it’s not your typical 33 too.
    Thanks! Ya I definitely want to drive this car quite a bit. That just wouldn’t have been possible without going through everything.
    Thank you. Ya it was much different than today’s fabrication and safety standards.
    catdad49 and Outback like this.
  25. kustomitch
    kustomitch
    Pretty wild what used to p***. I guess if it worked it worked though.
    Thanks. Ya I don’t think the frame would have lasted much longer than another weekend on the road the way it was. Trying to keep it looking like the same car somewhat, but also make it look good. To me it would be a totally different car and none of the history would really even matter if the body was cut off the frame and started over from scratch. That’s why I’m leaving some of the weird stuff like the windshield.
    I have some other ideas for paint right now. We’ll see how it looks without the flames first.
  26. kustomitch
    kustomitch
    Well it’s been quite a while since I updated this thread. I’ve finished building and moving into my new shop and made quite a bit of progress on the car. I will try to post pictures here in order. Working on finishing it up now.
    Stripped everything down for paint. Corrected as much as possible without getting too crazy and building an entirely different car and got it in epoxy primer.
    IMG_4916.jpeg IMG_5323.jpeg IMG_4919.jpeg IMG_5337.jpeg IMG_5338.jpeg IMG_5339.jpeg IMG_5340.jpeg IMG_5341.jpeg IMG_5525.jpeg IMG_5535.jpeg IMG_6641.jpeg IMG_7328.jpeg
    catdad49, Outback, Deutscher and 3 others like this.
  27. kustomitch
    kustomitch
    Ended up selling the Springfield quick change and picked up a rebuilt halibrand 201.
  28. James D
    James D
    Huge improvement over when you got it.
    Outback and Stogy like this.
  29. Bentrodder
    Bentrodder
    from Cotati
    Very cool!
    Stogy likes this.
  30. flyn schlosser
    flyn schlosser
    from Elko,NV
    Awesome thread ,very interesting...
    Stogy likes this.
