Projects 1933 coupster
Discussion in 'Traditional Hot Rods' started by kustomitch, Jan 14, 2023.
  1. Grumpy ole A
    Grumpy ole A
    Love your build (rebuild). Got to follow the rest
    Stogy likes this.
  2. RICH B
    RICH B
    Looking good
    Stogy likes this.
  3. BJR
    BJR
    A 32 grill on anything newer that 32 is just wrong. Just my opinion.
  4. Tim
    Tim
    from KCMO
    I don’t know how I missed this the first go round but hot damn! You’re doing the exact thing I’ve day dreamed about countless times. This is looking fantastic!
    hook00pad, Outback and Stogy like this.
  5. ronzmtrwrx
    ronzmtrwrx
    I don’t know how I missed it either. Great job straightening everything up. It looks a ton better now than when you started. Carry on.
    Stogy likes this.
  6. I too have hopes for some grille update. Work to date is stellar.
    Stogy and Xman like this.
  7. Squablow
    Squablow
    Loving the progress, I like how you can see the shadow of the flame job in the sanded-down body sides.
    '32 grille on a channeled 33-34 Ford is the way a lot of them were done, and I don't mind it at all, it looks a lot better with proper frame horns and not the T-bucket looking stretched frame it used to have. I might consider buying one of those cheap repop shells to whack the bottom bit off of and add it back to this shell to make it look a bit more complete, but I won't be disappointed either if the original cut down '32 grille with the tubing insert goes back on, that's one of the details that makes this car recognizable.
  8. hotrodjack33
    hotrodjack33
    Agree. A '32 Grille shell is about the only choice. Shortened/sectioned '33-'34 grilles never look right.
    hook00pad, Outback, Squablow and 2 others like this.
  9. kustomitch
    kustomitch
    Thanks everyone. The ‘32 grill is staying. Like @Squablow said it’s how a lot of them were done. It’s what was on the car, I like it, and I agree a sectioned 33/34 grill wouldn’t look right. Going for an early 60s style. So I guess what it might have looked like before the earliest photo I have of it.
    Moved in to the new shop. Any necessary body work was done and then it was primed again with epoxy then some high build primer. All wet sanded and ready for some color.
    catdad49, hook00pad, Outback and 6 others like this.
  10. kustomitch
    kustomitch
    My friend Tim laying down the color and clear. Mixed up a green similar to a ‘62 tbird. Tbird color was a little more blue.
    IMG_3512.jpeg IMG_3516.jpeg IMG_3522.jpeg IMG_3525.jpeg IMG_3523.jpeg IMG_3527.jpeg
  11. Tim
    Tim
    from KCMO
    Love it
    kustomitch and Outback like this.
  12. Grumpy ole A
    Grumpy ole A
    WOW! That is looking real good
  13. Squablow
    Squablow
    Pretty color. The new upholstery pattern makes more sense with this new color, too.
    How do you like that inflatable paint booth? I have considered one. I've been painting outside and wind is always an issue, but I wonder how stable the booth would be in the wind, if I'd still be fighting it.
    Outback likes this.
  14. 3blapcam
    3blapcam
    When I first clicked on this thread, I almost bailed immediately. I was worried it was gonna get "saved" but everything you have done that I have seen has only improved this car!
    Kudos to your eye and dedication!
    3blap.
    catdad49, kustomitch, Outback and 2 others like this.
  15. The roadster used to be Ronnie Robinson's creation, but it is now born again as yours. You did a great job resurrecting the bad work, to make a cleaner hot rod. Congratulations.
    hook00pad, kustomitch and Outback like this.
  16. Outback
    Outback
    from NE Vic, Oz
    Love the transformation,
    that green is very similar to an Aussie Falcon colour called 'lime Frost' the colour of my my first car.
    I too missed the first time around, thanks for keeping us updated!
    kustomitch likes this.
  17. kustomitch
    kustomitch
    Thanks. The booth works pretty well. It’s stable and great for dealing with the wind but it’s pretty hard to keep it clean.
    Outback and Squablow like this.
  18. kustomitch
    kustomitch
    Thanks everyone. Always a great moment when you get to roll a freshly painted car outside to see in the sunlight for the first time. Started cleaning and painting the engine next. Made some tuck n roll panels for the fender wells and front frame rails to take a little break in the polishing. Lots of sanding and polishing.
    78673808038__67C6BA22-8FB8-4730-96F5-849FDBCA793D.jpeg IMG_4388.jpeg IMG_4479.jpeg IMG_4481.jpeg IMG_3521.jpeg IMG_5590.jpeg IMG_5522.jpeg IMG_5499.jpeg IMG_5690.jpeg
  19. chlsnk
    chlsnk
    I really like what you're doing here, definitely doing the car justice and it's not another "belly ****on build".
  20. VALVE FLOAT
    VALVE FLOAT
    What is the black two door next to the Chevrolet?
  21. kustomitch
    kustomitch
    It’s a 1959 rambler
    Greenblade and Squablow like this.
  22. kustomitch
    kustomitch
    Got some new tires on the old chrome slots. The underside of the car didn’t quite get fully painted so I masked everything off and laid under there for a couple hours. Took care of the body work and paint on the grill, headlights, and steering box while I was at it. Finally ready to get the engine in and start putting everything back together slowly.
    Ragged Edge, hfh, catdad49 and 7 others like this.
  23. brady1929
    brady1929
    Very nice.
  24. Robdski
    Robdski
    Wow, what a transformation. Beautiful color.
    kustomitch and IronFord like this.
  25. Grumpy ole A
    Grumpy ole A
    That looks real good sitting out in the sunlight. I am not sure how the upholstery in the wheel wells and frame horns is going to work out over the long term. Down here on the gulf coast, it would encourage rust.
  26. kustomitch
    kustomitch
    Decided to remake the dash. The gauge layout and gauges in the old one ****ed. Also started in on removing the rats nest of wires back there.
    Ragged Edge, hfh, BigJoeArt and 5 others like this.
  27. Outback
    Outback
    from NE Vic, Oz
    Love your work! This car is going to be a stand out!
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Wow, really nice work. Loving the direction you're taking it. And, of course, the white engine and striped cable wrap on the front brake hoses are speaking my language.
  29. Wiring, I love wiring, and I love ripping all that rats nest out. I have a whole box of wire I ripped out of my Squarebody, and a lot of those wires were battery hot just stuffed under the seat not connected to anything.
    3blapcam and Outback like this.
  30. kustomitch
    kustomitch
    It’s always satisfying. Squarebodies seem to always have the worst wiring for some reason.
    Outback likes this.
