Projects 1933 dodge coupe "Baleful"
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Nov 8, 2021.
  1. oliver westlund
    oliver westlund
    Thank you, im not real well acquainted with cross steer setups. That's why i asked! What wpuld i find a 625 saginaw in? All im seeing in google is 525 boxes
  2. trevorsworth
    trevorsworth
    Since you are going fenderless, you are going to need to be careful about your choice of suspension and steering setups. Everything will be out on display. Rack and pinion is ugly as hell and not traditional in any way.
  3. oliver westlund
    oliver westlund
    Copy that
  4. stanlow69
    stanlow69
  5. trevorsworth
    trevorsworth
    I’m not sure what the stock Mopar front end looks like but if I was starting from nothing I would probably use a Ford beam axle and F1 steering box, these are readily available/rebuildable vintage parts that look right and perform well. But before making plans on the steering I would at least settle on a frame & get your engine mocked up in it to see what you have room for.
    loudbang and oliver westlund like this.
  6. oliver westlund
    oliver westlund
    I have a frame, and everything but the column and steering gear, i have the engine too, small manual box would be ideal as im sticking a 303 olds in it
  7. Budget36
    Budget36
    Your current front end is side steer, right?
    If you plan on keeping it, you’ll want a side steer box, not a cross steer box.
    Edit: I took a look at the first pics, appears to be cross steer. I ***umed side steer because the ‘32 Plymouth front end I used was side steer.
  8. vtwhead
    vtwhead
    I had a 625 lying around from a power steering conversion. Gave it to my buddy who put in in his 31 with a flathead. He said that it steers real easy and he doubted he would ever go back to the F1 box, Since then we have found a standard box from a jeep circa '79 that is just as good as the 625. He has built three 31's since and they all have a jeep box. If I remember I will take a pic of the jeep piece tomorrow when I am in the shop.
  9. oliver westlund
    oliver westlund
    Thank you!
  10. oliver westlund
    oliver westlund
  11. dwollam
    dwollam
  12. scotts52
    scotts52
    I agree . 2" on the haircut.
    oliver westlund likes this.
  13. oliver westlund
    oliver westlund
    Chopped! 2 inches off the top looks good. Usually these look goofy chopped imo. Got some structure welded in! 20211111_164246.jpg 20211111_164255.jpg
    AHotRod, kidcampbell71 and scotts52 like this.
  14. scotts52
    scotts52
    FYI, you can use a sedan roof to repair everything on yours. I'm having to repair the left side of mine due to rot.
  15. oliver westlund
    oliver westlund
    I may do that, most of the rot is in the filler panel but the p*** side right above the door is crispy
    Stogy and scotts52 like this.
  16. oliver westlund
    oliver westlund
    Anyone recognize this carrier? Pic of housing included in case its not obvious 20211111_143940.jpg 20211111_143921.jpg
  17. trevorsworth
    trevorsworth
    Ford 9" rear, tastefully chopped roof... you've got yourself an old hot rod buddy.
  18. scotts52
    scotts52
    Looks like a Ford 9 inch to me but I'm not well versed in these things.
  19. hotrodjack33
    hotrodjack33
    Hmmm. guess I called that one:p. For the life of me, I have no idea why ANYONE would ever doubt my outstanding and amazing observational skills:eek::p
    brEad, WalkerMD, Algoma56 and 3 others like this.
  20. oliver westlund
    oliver westlund
    Its a 9 inch, i want tp kmow which carrier though, ive never seen one that looks quite like that...not that i can think of
  21. oliver westlund
    oliver westlund
    When you're good...you're good
    hotrodjack33 likes this.
  22. oliver westlund
    oliver westlund
    Makes me all tingly in the toes! I'm gonna do it justice too
  23. dwollam
    dwollam
    Are you sure that's not a '49-'56 Ford? Pre 9"? Has that old u-joint style, mechanics joint is it?
    Dave
  24. oliver westlund
    oliver westlund
    Winner winner! Its roughly a 53 or 54 rear diff called the "ford rear" still perfect for the period im after
  25. oliver westlund
    oliver westlund
    I confirmed since 75% of the vehicles in my shop have the same rear....of all the people who shouldve known....shame on me lol 20211111_223741.jpg 20211111_224105.jpg 20211111_224231.jpg
    kidcampbell71 and trevorsworth like this.
  26. dwollam
    dwollam
    Well, I hate to say it but I think I was wrong! Here are 2 pics of my '56 Ford rear end and a link to a '53 Olds rear end on the HAMB. The '56 Ford is rounded on the back while my '51 Ford rear ends have the push out for the ring gear. The Olds rear end will be much stronger and perfect for the 303 Olds engine.
    Here is the Olds link.
    https://www.jalopyjournal.com/forum/threads/1953-oldsmobile-rear-end.1176642/
    Dave
  27. oliver westlund
    oliver westlund
    Dave really made my day with this discovery! My 33 indeed has an olds rear which is PERFECT as im putting an olds mill in it
  28. vtwhead
    vtwhead
    Here is a clearer pic of that olds rear
  29. oliver westlund
    oliver westlund
    Thanks! Im gonna head back with a putty knife and wire brush and find some numbers!
  30. oliver westlund
    oliver westlund
    E 25 4 by what i can see which should be casting date although i dont know what it translates to. Carrier looks round and is huge which makes me think its the 57/58 version. If anyone has more info its greatly appreciated
    brEad and kidcampbell71 like this.
