1933 Phaeton Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, May 23, 2012.
  1. tub1
    tub1
    from tasmania
    great panel work ,thats going to be one nice car cant wait to see more
  2. titus
    titus
    Thats all cool, but im looking for pics of the hinge hardware. ie hinge pins and the little funny spaces that go in between the door hinge and body hinge.
    my pheaton has roadster door latches in it to btw.
  3. Salt Flats Speed Shop
    from Utah
    Here are some pictures of the hinges. The hinge is tapered up top for a tapered head screw. Then in the bottom it has a spring that keeps tension on the nut. Kind of weird, so i'm thinking of a better way to make this work.
  4. Salt Flats Speed Shop
    from Utah
    I started working on the drivers front door yesterday. It had some bondo in it so I first ground that out, then put it back in my sand blasting cabinet to finish taking it all off. Then I got the dents all worked out. It has some rust on the bottom so I have to take care of that next.
  5. titus
    titus
    Thanks so so much for taking the pics of that stuff for me its helps me immensely, i really appreciate it, now i can have my machinist buddy make some of that stuff!
  6. Salt Flats Speed Shop
    from Utah
    Sure thing, the br*** balls measure 3/4". I was able to find some on the web that we're threaded that I can drill out to the right size. Hope that helps.
  7. LowKat
    LowKat
    I love tubs!
    Can't wait to see more progress. Nice work.
  8. Pewsplace
    Pewsplace
    A true metal master.
  9. continentaljohn
    continentaljohn
    Sweet love the pheatons
  10. Salt Flats Speed Shop
    from Utah
    Thanks guys!
    So I got the bottom patched, and it all leveled out. Now I need to blast the body and work out any issues there.
  11. Salt Flats Speed Shop
    from Utah
    I started mocking up the engine and transmission in the car. I used a mock up block I had at the shop so that I didn't have to worry about damaging the new engine.
    I still have a few things I need to check for on space, but its pretty much where its going to be.
    Also mocked up the new Br***works radiator. Im super impressed with the craftsmanship.
  12. dad-bud
    dad-bud
    This is an awesome build - great work.
  13. RoddyB34
    RoddyB34
    have you checked the body # on the firewall ,this body was reputedly #5 ,,starting with 40P***,aussie #was on left side sloping part against lip ,there should be enough left of the firewall for it to be there,,
  14. Mart
    Mart
    Great job on the door skin repair.
  15. dad-bud
    dad-bud
    Update time....?????
  16. Mart
    Mart
    The UK built Thames 300E van used those type of hinges on the rear doors.
    Mart.
  17. Salt Flats Speed Shop
    from Utah
    I got some motor mounts made, working on the transmission mount.
  18. Salt Flats Speed Shop
    from Utah
    I got the Pete and Jake ladder bars today, and got them tacked in place. Next thing to work on is the rear spring.
  19. ken1939
    ken1939
    Looking awesome. Like the C4 as well, nice fit transmission for flatties and gives you more floor space.
  20. Pewsplace
    Pewsplace
  21. Salt Flats Speed Shop
    from Utah
    Im working on modifying the rear crossmember. I need to flatten it as well as modify the center so that I can use a straight 36' spring. First I put bracing all around so that nothing would move on me. Then I cut the center out and then cut the other two pieces out.
  22. Salt Flats Speed Shop
    from Utah
    I worked today on getting the center of the crossmember square instead of curved. Then I got that placed at the height I wanted in the car. Then I got the one piece re-shaped to connect it back onto the frame.
  23. Such a cool car. Nice work! We did allot of similar ch***is stuff on our '34 pickup build. This will be one i'm watching!
  24. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Very cool work. I'm gonna bookmark for when I need this info down the line.
  25. ss34coupe
    ss34coupe
    You guys rock! Very nice build!
  26. nitrohonkey
    nitrohonkey
    great car...great work!
  27. Salt Flats Speed Shop
    from Utah
    I finished up the rear crossmember (except for some grinding on some of the welds). Now I have to make up some spring hangers for the axle.
  28. Pinstriper40
    Pinstriper40
    Looking good! I love how clean and rust-free everything is.
  29. Salt Flats Speed Shop
    from Utah
    Ya, I hate working around rust. Its so much easier to just get it blasted. Ha
  30. Salt Flats Speed Shop
    from Utah
    I got the transmission mounted, and started working on the exhaust headers. They were some that we had laying around the shop. The drivers side rear leg had to be modified to clear the steering box.
