1933 Steel Vicky Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Jan 5, 2009.
  1. Salt Flats Speed Shop
    from Utah
    This is a shop project that I've been planing on doing for a while now. As a shop I will in the near future be offering the 1933 Steel Vicky conversion. Both in complete bodies that I will convert, like this one. And in converting customers 2 door sedans into 1933 vicky's. All the origional beads and contours will be faithfully reproduced down to the smallest deatails.
    Once I get a few of these done myself I will be able to accuratly judge how much a conversion will cost. So costs for the conversion will be down the road.
    This sedan will be my first vicky conversion. It is an actual 1933 2 door sedan that is amazingly in great shape. It is a complete car with suspention, engine/transmission, and all the sheet metal.
    My plans with this build is first to convert the sedan into a vicky. And then to do all the metal work. The body, and rest of the sheet metal will be completly metal finished. (The entire car will look like the dash, sanded to perfection). Once that is finished I will be selling the car complete with everything included.
    Thanks for looking
      117.8 KB
      123.1 KB
      133 KB
      130.8 KB
      125.9 KB
      131.1 KB
      123.4 KB
      110.1 KB
  2. alchemy
    alchemy
    Very interesting, but make sure you pay attention to the roofline and window opening profile. VERY important, and that's where most pseudo-Vickys fail. Seeing your past projects, I know you have the metalworking expertise.
  3. fab32
    fab32
    Please keep us informed as this project moves forward. Pictures are a must.
    Frank
  4. Weasel
    Weasel
    Where's Druss 32 - late to the party again????:D
    You might look at joining the AVRG chapter - Abused Vicky Recovery Group - here on the HAMB.
  5. Salt Flats Speed Shop
    from Utah
    I plan on making dies to reproduce the rear beads around the rear of the car, and also a set of dies to reproduce the small bead that continues from the rain gutter.
    Today I continued working on all the panels that really dont need much work. Just getting them looking good.
    Also started working on the rear fender. Its really in good shape, just needs some bead work, dents, and a patch on the front of the fender.
      115.1 KB
      115 KB
      120.3 KB
      123.9 KB
    Big mike 1968 and Stogy like this.
  6. Docco
    Docco
    from Ippy
    That looks like a real solid body you started with.
    Stogy likes this.
  7. I SMELL SMOKE
    I SMELL SMOKE
    I'm going to have to stay tuned for this one
  8. metalman
    metalman
    This will be interesting to watch. Posted on here before, I did the same to a 32 Tudor, didn't have as much to start with as you do. Keep us posted with updates for sure.
    welcome to the AVRC, although like me we arn't really saving an old Vic!
    Stogy likes this.
  9. 33Tudor
    33Tudor
    Just curious. What all is involved in the conversion? Is it just from the doors back? Or do the doors have to be modified too?
    Stogy likes this.
  10. Salt Flats Speed Shop
    from Utah
    Its just the back of the car that needs to be altered. The rear side windows are smaller by roughly 9 inches. The beads, and back panel under the window are all different. The 1933 vicky has a small bead that starts at the end of the drip rail and continues around the back of the car to the other drip rail. The bottom end of the car where the gas tank cover mounts is in the same place but the bead there is different as well. And also the rear roof is leaned forward slightly more than the 2 door sedan is.
    Stogy likes this.
  11. pan-dragger
    pan-dragger
    keep the photos coming, can't wait to see the progress on this.
  12. 33Tudor
    33Tudor
    Thanks. I'll be watching, to see your progress. Lots of luck!
    Just Gary likes this.
  13. Dyce
    Dyce
    Do you have a vicky to use for a pattern? If so is it yours (if so lucky dog)? Cool project.
    Jeff
    Stogy likes this.
  14. Cool concept. Now if you could just come up with a kit that converts a 4dr into a vicky............ hmmm
    Stogy likes this.
  15. Sparkswillfly
    Sparkswillfly
    from Colorado
  16. hemifarris
    hemifarris
    Looks like an interesting project. The stripped parts look as though they're in nice condition.......Mike
    Stogy likes this.
  17. Looks like you started with a great car...definitely keep the pix and updates coming
  18. Salt Flats Speed Shop
    from Utah
    I have access to one. (wish it was mine though). I will use it for all my patterns and basically make a fixture here at the shop using those patterns. That way I can use that fixture over and over again making each conversion as uniform as possible.
    Stogy likes this.
  19. Dyce
    Dyce
    Over at metalmeet.com there are a few guys using bondo bucks. You make a frame out of rod and use body puddy to pick up the detail. Here is a picture of one Wray Schelin posted.
    That's one reason why I asked if the vicky was yours. You could get some pattern bucks off of it, if it was body shell.
    Stogy likes this.
  20. Salt Flats Speed Shop
    from Utah
    Ive been working on this rear fender for the past few days. I worked out all the dents, now I just have to patch the front where it meets the running board.
      118.5 KB
      110.1 KB
      113.4 KB
    Stogy likes this.
  21. oldrelics
    oldrelics
    from Calgary
    If its one thing I've learned from watching your builds....is.....that......
    I ****.
    I think I'll take up knitting.
  22. Salt Flats Speed Shop
    from Utah
    Tonight I got the front of this fender patched.
    Now with this fender done I will use it to check the contours of the other. That way I can make sure they both reflect well.
      115.6 KB
      114.8 KB
    Stogy likes this.
  23. 1bad37
    1bad37
    from new york
    i am definatly interested to see how it turns out, i have a 33 2dr sedan, and ive been debating vickys or sedan delivery, how you post some pics and good luck-
  24. willysguy
    willysguy
    from Canada
    That is some nice work!
    Stogy likes this.
  25. Salt Flats Speed Shop
    from Utah
    I finally got the body sandblasted. Now i can start on the body.
    Today I finished up the rear fender and got it bolted on.
    I also started hanging the drivers door. The hinges were bent so its taken some m***aging to get the gaps looking good. Ive still got some more tweaking, but its coming.
      120 KB
      124.4 KB
      123.3 KB
      141.2 KB
    Stogy likes this.
  26. 33Tudor
    33Tudor
    Wow! That looks like a great starting point. Keep up the good work!
  27. Salt Flats Speed Shop
    from Utah
    Today I am starting on the other rear fender. This one is a lot worse than the other, but still its not that bad.
    I will post more pictures later today.
      124.5 KB
      121.6 KB
    Stogy likes this.
  28. Salt Flats Speed Shop
    from Utah
    I got all the dents worked out of the fender. Now I have to patch the front as well as fix some problems in the bead and wire edge.
      111.2 KB
      114.2 KB
      109.8 KB
      114.3 KB
    Stogy likes this.
  29. Flipper
    Flipper
    from Kentucky
    How did you get all of the dents out? just hammer and dolly?
    Stogy likes this.
  30. chad
    chad
    Do you use a shrinking disk too??
    Stogy likes this.
