1933 Steel Vicky Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Jan 5, 2009.
  1. Shobra
    Shobra
    from SLC, Utah
    Nice work.
    Just a work of caution, with those bungee cords on your shrinker/ stretcher, get rid of them asap and replace them with some springs from the hardware store. I worked with a guy that had one of those bungee cords break and guess where it went.... yeap shot right into his eye *ouch* he didn't lose his eye, just his sight out of it.
  2. Salt Flats Speed Shop
    from Utah
    I got both front fenders done except for the area where the grill bolts. I think I will leave them this way so that people can see at the show what they looked like before and after.
      124.6 KB
      106.4 KB
  3. willysguy
    willysguy
    from Canada
    That is some nice metalwork!
  4. Salt Flats Speed Shop
    from Utah
    Just goes to show how important it is to have the physical object of whatever you are copying there to check back and forth with. When I went up to take patterns of the roof on my buddies 33' vicky I took my trusty contour gauge. The contour gauge has two sections that screw together and because of this the gauge has the tenancy to pivot on that joint. So because the joint was loose it through off my patterns ever so slightly especially on the long curves where I had to use the gauge multiple times on the same line. Basicly I descovered what everyone was saying...that the roof needed to be leaned in. My patterns werent saying so, but they were slightly off.
    Now that I have correct patterns the roof is finaly where it needs to be.
    I also started on the bead that continues from the rain gutter around the back. It almost time to start t******* and welding all these pieces together.
      112.1 KB
      123.7 KB
  5. Salt Flats Speed Shop
    from Utah
    I got the other side drip rail bead made.
      117.9 KB
      123.7 KB
    Dave Mc likes this.
  6. Salt Flats Speed Shop
    from Utah
    I got the p***enger door parts painted. Once the paint dries I can put the door back together.
      126.3 KB
      123.3 KB
      124.9 KB
  7. Bass
    Bass
    from Dallas, TX
    The work you did on the fenders is flat-out amazing. I'm super-impressed with everything I've seen you do so far.
  8. Salt Flats Speed Shop
    from Utah
    This morning I got the p***enger door all put back together and hinged on the car.
      112.9 KB
      116.2 KB
  9. Salt Flats Speed Shop
    from Utah
    This morning I started tacking all the pieces together.
      116.7 KB
      113.8 KB
  10. Salt Flats Speed Shop
    from Utah
    Today I started completely welding the different sections together.
      123.5 KB
      116.1 KB
      117.2 KB
    Dave Mc likes this.
  11. 33Tudor
    33Tudor
    Looks to me like you got yourself a Vicky!
  12. Salt Flats Speed Shop
    from Utah
    Just continuing to get the pieces welded together.
  13. gotwood
    gotwood
    from NYC
    Incredible work!! Crazy question, what are you doing to fenders after you metal work them as they have a media blasted look vs say a filed and finished appearance. It is a satin look? Maybe it is just pic but it looks to have a finish vs say a 180 satin look ?? Hope I am being clear in question?
  14. Salt Flats Speed Shop
    from Utah
    I think I understand what you are saying. Its just stepped up to 500 grit sanded with an orbital.
  15. Salt Flats Speed Shop
    from Utah
    Ive been working on finishing the seams on the back, as well as bolting on the fenders and running boards.
    My goal is to have the drivers side of the vicky conversion finished for the show. The p***enger side with the bullet holes will take some more time. But at least people can see the drivers side complete so they can get a good feel for how the rest will look.
      114.4 KB
      115.2 KB
      116.9 KB
      122.8 KB
    Dave Mc likes this.
  16. Salt Flats Speed Shop
    from Utah
    I worked some more on the roof getting the dents worked out. I also got the gas tank cover roughed in just so I could bolt it on for the show.
      121.6 KB
      123.6 KB
      127 KB
    Dave Mc likes this.
  17. James D
    James D
  18. SUHRsc
    SUHRsc
    nice work! It looks great!
  19. Salt Flats Speed Shop
    from Utah
    I started this morning on making the corner of the roof. With all the seams coming to one spot it would be a mess welding. Plus making this piece allows me to get the contours right were I want it.
      117.6 KB
      119.9 KB
    Dave Mc likes this.
  20. Really nice work! How did you make the beads and get them into the proper arrangement?
  21. Salt Flats Speed Shop
    from Utah
    I have two machines that I use to make my beads. My bead roller, and my Lennox (pullmax style machine). As for the proper arrangement I just followed my patterns that I took of the original car.
  22. zombiemandan
    zombiemandan
    from Wyoming
    I keep seeing this thread come back to the top but every time I check it there's nothing new. The last post I see was in 2007. What gives?
  23. Salt Flats Speed Shop
    from Utah
    Honestly I have no idea what you are saying. I started this thread in january of this year 2009. And there have been over 100 reply's. You sure your seeing things right?
  24. Salt Flats Speed Shop
    from Utah
    I got the roof area all worked out. Just some more work on the beads and I can fill the open area below.
      121.5 KB
    Dave Mc likes this.
  25. chad
    chad
    LOL you must no be paying any attention ....Their is tons of progress...it no easy feat to take a 2 dr sedan and convert it to a vicky
  26. zombiemandan
    zombiemandan
    from Wyoming
    I must have had a glitch. I posted then a couple more pages popped up. As for the 2007 thing that was just me being a dumb***. Salt Flats, I live in Wyoming and if you ever start offering metal working cl***es (as mentioned) I would definately be interested
  27. I figured you had a reciprocating machine of some flavor. Couple questions:
    1- Can you show the dies you used?
    2- How did you lay out the flat metal in order to get the three dimensional bead? Three dimensional curved beads give me fits..
  28. Salt Flats Speed Shop
    from Utah
    No worries bro :) Ive had a few glitches on this site too.
    As for when I start having metal working cl***es I will defiantly let you know.
  29. Salt Flats Speed Shop
    from Utah
    Tomorrow Ill post some pictures of the dies. As for laying out for the beads its kind of hard to explain, but after I get the bead pressed there is just a lot of hand m***aging to get it to curve where I want it to.
  30. toxictom
    toxictom
    damn, find this thread yesterday and soaked these pictures up like a sponge....and burn it into my brain for ever...this is, how my workpieces should look in the future ! absolutely fantastic ...
