Technical 1934 Crossmembers
Discussion in 'Traditional Hot Rods' started by Justin Cuffe, Aug 31, 2024.
  1. Justin Cuffe
    Justin Cuffe
    I came across a s****ped 1934 Ford front and rear crossmember that has been cut in half. Are either of these pieces any good or should they be s****ped? The cuts are clean through the middle of each.
  2. drtrcrV-8
    drtrcrV-8
    As long as they are aligned properly & supported during the weld, any competent welder should have no problem restoring them to being useable. Were you given any reason why they were s****ped?
    Outback likes this.
  3. goldmountain
    goldmountain
    Where are you? I'm in Lethbridge and if you are in the neighborhood, I have '34 rear crossmember I could give you.
