SOLD 1934 Ford 3 Window. It is channeled but not chopped, that’s when I stopped working on it because I couldn’t decide if I wanted to lower the lid or not because it has nice original wood in it. I was going for a Robert Lomas look so I will probably chop it if I keep it. Frame is pinched, boxed with @ioniahotrodshop dimpled plates and crossmember, has 32 front frame horns and Pete and Jakes pedal ***embly. 1950 Ford flathead truck motor, it spins freely, but I’d still probably go through it. Cornhusker adapter to T5 transmission. Fenton Headers, Harrell Heads and Intake. New br***works radiator. Winters V8 Quickchange with wedgelock diff and 9 inch axles, has Lincoln drums brakes. It is hung using 36 rear wishbones and I already had a driveshaft made for it. Front axle is an original dropped axle from Juaquin Arnett collection, also with Lincoln brakes. Unsplit 32 wishbone. 6.00 16 tires up front 7.50 16 on the back on Washington Blue wheels. Nice 34 grille New rear window wood kit. New Tanks gas tank mounted in trunk with a craftyb flip top gas lid. Most of the heavy fab work is done, doors still need gapped and there is some fine tuning to be done on body, if you are a fanatic that wants everything metal finished you probably have more work to do.
