1934 Ford Radiator question
Discussion in 'The Hokey Ass Message Board' started by 343WINDOW, Sep 12, 2012.
  1. 343WINDOW
    343WINDOW
    I'm putting an 8ba in my '34 coupe. I know about how tight this is and I'm just going to recess the firewall...the flattie I have is a fresh rebuild complete front to back sitting on a stand with an old truck rad and battery. I bought it this way and can fire it up and let her run...so I don't really want to be changing cams, pumps pulleys etc. I am ordering the rad from Br***works and they offer the option of the recessed top tank for fan clearance, just like the originals. You can only get a three row rad with this option opposed to four without. Do I need this fan cutout?
  2. 3banjos
    3banjos
    from NZ
    Why do you need to recess firewall.
  3. thunderbirdesq
    thunderbirdesq
    If your engine and cooling system are in good shape, I think a 3 core would be sufficient. I used a little mustang 3 core unit on my last 8ba powered roadster and it ran nice and cool in just about any weather.
    Because the 8ba pulleys are longer.
  4. 343WINDOW
    343WINDOW
    Every post I've read on the Hamb says it's a tight fit even with all the early front dressing....am I wrong????
  5. Weasel
    Weasel
    Exactamundo - why recess the firewall when it orignially had a flattie in there anyway? My 1933 three window had a 59 AB - actually a Canadian C59A - and it just sat in place of the stock 21 stud engine with absolutely no mods. Recessing a firewall should be a last resort measure when all else fails....
  6. 343WINDOW
    343WINDOW
    So.....get the recessed top tank??????
  7. krylon32
    krylon32
    from Nebraska
    I might be wrong but the 8BA presents different installation problems from the 59 AB?????? In a 33/34!
  8. Weasel
    Weasel
  9. 343WINDOW
    343WINDOW
    I read this post before I posted my question. There is lots of talk about pulleys and pumps, but nothing about fan hitting tank if you don't have the factory recessed tank. Br***works is the only company that offers this factory recessed tank...everyone else says you have to run an electric fan with theirs...which I have no desire to do. So do I play it safe and get the recessed tank and go without four rows of cooling?????
  10. thunderbirdesq
    thunderbirdesq
    Because like he said in his original post, he has an 8ba and doesn't want to change out all the required **** on the engine to make it 59ab size.
    Honestly, I agree... I would probably just change everything over rather than cut a nice firewall, but there are ways to do it nicely if that's what he wants to do.
  11. rrthiv
    rrthiv
    from S.E.Ohio
    It is a tight fit if using the original cross member,i made 4" spacers on the motor mounts to get the crank pulley above the cross member,never cut the firewall.
  12. Weasel
    Weasel
    Which proves I know zip about flatties;) - but hey I am a Willys guy....
