Projects 1934 ford three window project
Discussion in 'Traditional Hot Rods' started by Elvis100, Aug 13, 2017.
  1. Elvis100
    Elvis100
    Then this happened, still have some adjustments to do to fit the doors.
  2. Stogy
    Stogy
    Breathtaking evolution happening here...thanks for sharing @Elvis100
    Elvis100 likes this.
  3. sliceddeuce
    sliceddeuce
    Moving along nicely.
  4. flamedabone
    flamedabone
    I can't get over how nice the cowl vent piece came out. That is a pain in the *** piece to build, let alone to build right.
    Nice work, -Abone.
    Stogy and Elvis100 like this.
  5. Elvis100
    Elvis100
    Thanks, I’m getting a lot of time on it
    Stogy likes this.
  6. Elvis100
    Elvis100
    Thanks, it took me a while, but very satisfying to get it installed. Wish I had done one on the roadster last year.
    Stogy likes this.
  7. Elvis100
    Elvis100
    Got the driver gaps pretty good, the p***enger is going to need some extra attention. It obviously popped open at some point and the hinge pillar is pretty shabby. I’m going to do the whole skin on it and sort out the hinge pillar when I have it open. The driver I think I can get away with redoing both outer and inner lower patches.
  8. Elvis100
    Elvis100
    Installed the new wheel well on the driver side. I also ordered a door skin for the p***enger side.
  9. Elvis100
    Elvis100
    Looking back over some pictures, here is the car when I first got it
  10. Elvis100
    Elvis100
    Got more done today. Welded the quarter lower patch. Cut out the p***enger wheel well and lower quarter in preparation for new metal. Temp installed quarter braces
  11. lilmann
    lilmann
    Outstanding job and attention to detail
  12. Elvis100
    Elvis100
    Thanks, I’m trying
  13. Elvis100
    Elvis100
  14. Johnboy34
    Johnboy34
    from Seattle,Wa
    I'm another "attaboy" on that cowl vent, and all the rest is nice work also! Can't wait to see what you find in the p*** door, I have a driver side sprung a little I need to fix.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  15. Elvis100
    Elvis100
    Thanks, I’m pleased with how it came out
  16. Elvis100
    Elvis100
    Finished up the p***enger quarter panel. I have my quarantine beard.
    There are two dimples in the quarter panel brace on the p***enger side to mount the tool box. I pressed them using a stack of washers and a piece of oak with a hole cut in it.
  17. sliceddeuce
    sliceddeuce
    Like the progress..Carry on.
  18. rusty valley
    rusty valley
    nice job again, do you have the tool box? i do, if you need to make one
  19. Elvis100
    Elvis100
    Thanks,
    I have part of one that came with my roadster rear clip...I may hit you up for a couple measurements when I make one.
    brEad, kidcampbell71 and Stogy like this.
  20. Looking really good, nice work.
  21. Elvis100
    Elvis100
  22. rusty valley
    rusty valley
    that dont look like much to go on for a tool box, i have an original in good shape, i'll post it for all to see
    brEad likes this.
  23. Elvis100
    Elvis100
    Thanks,
    That would be great.
  24. Elvis100
    Elvis100
    Started working on the drivers door...I’ve been dreading it. The old repairs were done by simply forming sheetmetal over the rusted metal and brazing it in place. There was a good 1/4 inch of bondo over that, that was removed with media blasting. I got everything fit and made the bottom 5 inches of the hinge pillar.
  25. Elvis100
    Elvis100
    Got the new metal welded. I’ll have to come back and lead the seam later
  26. Elvis100
    Elvis100
    Worked on fitting the deck lid...initially it wouldn’t fit and since the panel below the deck lid it the only reproduction part, I started there. The panel measured a full 1/4 inch taller than the original...uff. I was able to unfold the top edge and then fold it 1/4 inch lower. I still have to adjust the mounting on the left side to line up the body line. I also need to make some adjustments on the right side...[​IMG]
  27. Elvis100
    Elvis100
    Worked on the panel below the decklid today. Before I got into it I installed the decklid support. On the left side I raised the panel about 1/4 inch by cutting the mounting pad off and moving it down. On both sides the body line didn’t line up with the quarter panel. I pie cut horizontally at the bottom of the line and then again vertically from the bottom to relieve the metal.
  28. Elvis100
    Elvis100
    After lunch I started on the other panels for the trunk. The original support panel has not been media blasted...I’m getting spoiled. I removed it from the below the deck lid panel. I think I will just clean up the nibbled out holes since I will need the access for tail lights
  29. rusty valley
    rusty valley
    that looks like most of the firewalls i've had that some one installed a heater by drilling a bunch of holes and beating the center out with a chisel ! good work as usual, thanks for posting
  30. Elvis100
    Elvis100
    Yeh, I’ve seen that a few times. Thanks
