Projects 1934 ford three window project
Discussion in 'Traditional Hot Rods' started by Elvis100, Aug 13, 2017.
  1. Elvis100
    Elvis100
    Continued working on the trunk panels. I eventually got the trunk latching, had to reprofile the catch plate a good amount to line it up with the latch. I finally got tired of every tool or fastener falling through the differential access hole every time I set something down. I pressed a round cover and locked it in with the original wire. The wire would have been used with a fabric to cover it originally. I used a 5 gal bucket to mark a circle on plywood, sandwitched that with metal plates.
  2. rusty valley
    rusty valley
    nice!! by golly i need one of those covers too. gotta go find a bucket
    Elvis100 likes this.
  3. alchemy
    alchemy
    I never knew they had a wire to hold that cover in!
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
  5. Elvis100
    Elvis100
    Yeh, there are three little slots corresponding to three bulges in the wire.
  6. Elvis100
    Elvis100
    Thanks, the shop trash bucket did double duty as a template. The size was perfect
  7. sliceddeuce
    sliceddeuce
    Nice work as always.
  8. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Great build thread, love the work. The first pic you posted of your Dad I thought he resembled mine. My pop was a truck driver and could do a bit of metal work. Keep up the great work, thanks for sharing all the details!
  9. Elvis100
    Elvis100
    Took is easy today, cleaned up the shop and ran some errands. I have my work schedule for tomorrow. Got the P***enger door skin! Great job by Waldon Speed Shop in Pomona CA!
    kidcampbell71, TheBookman and Stogy like this.
  10. Elvis100
    Elvis100
    Thanks, I’m getting a lot done on lockdown
  11. Aaron D.
    Aaron D.
    Walden has a great video of how they replaced the door skin on a 32. The video is on their website.
  12. Elvis100
    Elvis100
    Thanks, can you post a link. I couldn’t find it
  13. rusty valley
    rusty valley
    i would like to ask some questions on the diff cover. so, it looks like about 3/4" plywood, obviously the male die is slightly smaller than the female pressed over it, was the plywood itself strong enough to get a uniform press all around the part? did you need to place some steel over the whole thing to press it? move around the edge multiple times to get the "pie tin" shape uniform? thanks again for your efforts here, great do***entary.
    brEad likes this.
  14. Elvis100
    Elvis100
    Hi, yeh. I used a 1/4 inch steel plate below and on top of the plywood. And then a smaller 1 inch piece on top to distribute the force. Had to press about 1/4 of it at a time, total of about 8X pressings. The second time around without the positive and only to flatten deformation.
    brEad and rusty valley like this.
  15. rusty valley
    rusty valley
    makes sense, thanks
  16. Aaron D.
    Aaron D.
  17. Elvis100
    Elvis100
    Stogy and kidcampbell71 like this.
  18. sliceddeuce
    sliceddeuce
    Can't have rock 'n' roll without feedback, and you can't have a hotrod without a bullet hole or two.
  19. Elvis100
    Elvis100
    rusty valley likes this.
  20. Elvis100
    Elvis100
  21. Runnin shine
    Runnin shine
    Both my hot rods had bullet holes in their dash panels before I got my hands on’m.
  22. 47streetrodder
    47streetrodder
    Spoken by a true Hot Rodder.
  23. Elvis100
    Elvis100
  24. Pete
    Pete
    Excellent work!
    Iv been doing the same thing, fixing rot. 35E8DB72-D960-4D54-ACBD-E492943584B2.jpeg 640BF47F-F6DE-4759-A423-3B58595A85A8.jpeg 512B0F45-474F-4744-8171-A1FD87990AC1.jpeg 3879522B-811C-4FA6-82D9-141B46E7BCB4.jpeg
    Stogy, brEad, Elvis100 and 3 others like this.
  25. Elvis100
    Elvis100
    Thanks, you also...looks like the same rot. Did you see the roadster doors I got from you in progress on my other thread? A little more on this one and then back to the roadster.
    Stogy, brEad, kidcampbell71 and 2 others like this.
  26. Elvis100
    Elvis100
    Got the door skin fitted and installed. Now back to adjusting gaps
  27. Johnboy34
    Johnboy34
    from Seattle,Wa
    I see you had to remove the hinge, what all was involved with the door hinge piller being sprung?
    Sent from my SM-G973U using The H.A.M.B. mobile app
  28. Elvis100
    Elvis100
    It wasn’t as bad as I thought. The big thing was being able to tweak it a little with the door skin off. I had plans to strengthen the hinge pillar, but the “hat” channel inside was pretty decent, just needed a little hammer and dolly. I took the hinges off a while back because they were bent. I have them attached with 5/16-24 same as the b-pillar. I’m waiting on a rivet nut tool to install threaded inserts in both doors
  29. Johnboy34
    Johnboy34
    from Seattle,Wa
    Thanks, I don't need to remove the skin if I can help it. I'm thinking about drilling a couple hole through the outside & hat channel, bolting a bar inside and pull a little. We'll see....
  30. rusty valley
    rusty valley
    i believe 33 hinges were bolted to the doors, 34's welded
