Projects 1934 Gaz ( russian Ford)
Discussion in 'The Hokey Ass Message Board' started by dutchrod, Feb 2, 2025.
  1. dutchrod
    dutchrod
    Yesterday this 1934 Gaz followed me home.
    Gaz is a manufacturer that build cars under Ford License , (the Gaz AA is like a Ford Model AA)
    It is "normal" size and not the smaller like the English model Y.
    I'm no expert on the 33/34 fords but this Gaz fordor looks like the usa model 40 but some differences:
    -The grill is different.
    -ch***is looks a bit different and has parallel leaf spring front and back
    -it has juice brakes but I don't know this type.
    -there is a wooden subrail below the rocker ( don't know about this in usa models)
    -it looks like there was a hump/trunk on the back like some cars had at the time.
    The original engine and trans where not with the car and I don't know what engine used to be in there.
    It is cool to see cars like this popping up , i never new gaz made cars like the model 40.
    I got it cheap just to use the body to convert it to a 5w coupe.
    Maybe the frame is usable but I will see when tearing it apart.
    For now I'm on the hunt for quarter panels.
  2. dutchrod
    dutchrod
  3. dutchrod
    dutchrod
    The wooden subrail/structure.
    Do the usa models this ?
  4. dutchrod
    dutchrod
    Banjo axle on parallel springs.
    There was cut down torque tube with the car that's suggest that it was closed drive but that would not work with this type of spring setup ???
  5. hrm2k
    hrm2k
    Holy **** !!!! What a score. You are going to have a ball when it gets on the road. It is gonna fool a lot of people. You have to do a build thread.
  6. catdad49
    catdad49
    I think it’s pretty amazing cars like this survived the war. The Model 40 guys will be all over this, be prepared to take more photos! Post more when you start your conversion, Carp.
  7. stuart in mn
    stuart in mn
    Turns out there's a Wikipedia page for that car. It may have some useful information for you. For one thing, even though it looks like a 1934 Ford it appears it didn't go into production until 1936. https://en.wikipedia.org/wiki/GAZ-M1
  8. rusty valley
    rusty valley
    Very cool! USA models did not have wooden sub rails, but Aussie cars had different rails, perhaps wood? dunno.
  9. wheeldog57
    wheeldog57
    Oooh I like that grill!! Good luck and have fun with it. Keep us posted
    Sharpone likes this.
  10. goldmountain
    goldmountain
    With the back end already cut like that, you won't have as many keyboard warriors bad mouthing you about a coupe conversion. "Little Gaz Coupe" has a ring to it.
    Sharpone and chlsnk like this.
  11. No **** :cool:, can you imagine having 34 GAZ as a screen name :D. You better do something about that 19 inch ground clearance :D
  12. Dash is the same as '34 Ford, Hood is about 4 inch longer than '34 Ford because it had a straight 6.
    I would say that wooden rocker was put in there by some "Eastern European" backyard builder some 50 odd years ago. Did you get all the patch panels from the guy ? I ordered them from Mac's a good 25 years ago and they were a perfect fit. Thinking back i signed up here in 2003 and allready had the car a few years before.
    wheeldog57 and Sharpone like this.
  13. dutchrod
    dutchrod
    Yes i got some patch panels and rockers with it.
    Lot of work but worth saving !
    Sharpone and Squablow like this.
  14. unforgiven
    unforgiven
    from East Tn
    Wow. That is cool to see a Russian Ford.
  15. rschilp
    rschilp
    Love it.
    I'm local to you, would love to check it out in person sometime.
  16. Johnny99
    Johnny99
    Kind of looks to me with the U-bolt set up and what looks to be a grease fitting going into what appears to be some kind of a collar that rear rotates in that set up would work with a torque tube. Or maybe I'm hallucinating?
  17. rusty valley
    rusty valley
    Good eye Johnny, it looks like its made to pivot there
  18. chrisp
    chrisp
    Chevy used parallel springs with torque tube, the rear end is mounted on grease sleeves.
    I don't know if anybody saw but last year Russians led an attack in Ukraine with a column of GAZ /Ford model B trucks. That was surreal.
    Sharpone, Beanscoot and rusty valley like this.
  19. What is the progress to date as to making a coupe body ?
  20. Beanscoot
    Beanscoot
    Anyone have links to video of the GAZ / Ford B trucks in military action?
  21. spudshaft
    spudshaft
    bumping this because that would be really interesting. Also, great build project.
  22. dutchrod
    dutchrod
    it is in storage for now but when my new garage is build this summer you are more then welcome!
    Sharpone, rschilp and leon bee like this.
  23. Squablow
    Squablow
    Vent windows! That's really cool, I never saw a 33/34 Ford with vent wing windows in the doors before. This seems like a perfect car to make into a 5w coupe, I'll be following along and I hope you post progress pictures when you cut into it. I cut up a really rough '33 a few years ago and I got pretty far on it but I ended up with a bit nicer '34 starting point and sold my '33, I'm hoping to get back after it sometime soon.
  24. oldsmobum
    oldsmobum
    from SoCal
    https://www.kyivpost.com/post/23120
    I found this. GAZ-AA, based on the ford model AA of the 30’s. I didn’t easily find anything showing the GAZ-67 (model B derivative) but if they have them and they can make them run, you can be sure they were/are using them.
    Squablow likes this.
  25. dutchrod
    dutchrod
    For my fordor to 5w coupe conversion i’m gonna need some dimensions.
    I don’t have a 34 5w close by but i will take some patterns of a real coupe in the future but for now i can go on with planning if i have these dimensions.
    Can somebody give me the measurements like on the pics below.
    Greatly appreciated!
    Ff somebody have drawings , patterns or blueprint of a 34 coupe i would love to have it.
  26. dutchrod
    dutchrod
    I found a pair of quarter panels , they will be new and handmade.
    I have to wait with the build till my garage is finished , i will start a build thread.
    In the mean time i’m collecting parts.
    Today i picked up a 255 french flatty wich i will take apart and freshen up.
    treb11, Sharpone, Okie Pete and 6 others like this.
  27. Squablow
    Squablow
    The French flathead is a cool piece of history. Some unique water pump/engine mounts on there, I never saw those before.
    seb fontana and arse_sidewards like this.
  28. Beanscoot
    Beanscoot
    I had the same thoughts on the water pumps, especially the left one. Can "normal" ones be fitted instead?
    seb fontana and Squablow like this.
  29. Squablow
    Squablow
    I thought I read that the US style pumps bolt up and the only difference is the bolt sizes are metric in the French block. I could be wrong though.
  30. Beanscoot
    Beanscoot
    Years ago I read that the threads were standard except for the exhaust manifold studs.
    Just make sure to start 'em by one thread and then run them in with an impact.:D
    Baumi and Squablow like this.
