1935-1936 Ford pickup tech for the masses
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 18, 2008.
  1. F-head
    F-head
    anybody know if a 35 grill will fit on a 36 radiator?
    thanks for this great tech post.
    B
  2. Roothawg
    Roothawg
  3. Fe26
    Fe26
    I and my "35" thank you.
  4. stripe504
    stripe504
    from Modesto
    I'm really glad you posted this. Great information.
  5. kruzin karl
    kruzin karl
    My NOS 35 grille doen't have that tab either.
    Also, I was always under the impression that only the very early 35's have the removable window trim and no indented door "pull"? Maybe someone can elaborate on that?
    Nice to see all this info in one place!
  6. Roothawg
    Roothawg
    I am not sure at what point in the year they went to molded door pulls but it was roughly mid-way through 1935. They were removable before that. Maybe Bruce Lancaster could add something here.
    As far as the tab for the V8 emblem, I am beginning to wonder if that was a "Deluxe" option.
  7. daleeric
    daleeric
    from Omak
    Do you still have a 36 truck grill?
  8. 34cdan
    34cdan
    Are the 36 pickup and car frames and running gear the same?
  9. Martin_F
    Martin_F
    The Frame is the same. There are just different mounting holes for the car then for the pick up!
  10. mow too much
    mow too much
    Here's something that maybe useful, it was in a old BOB DRAKE catolog, I feel these need to be in place because it will force more air thru the radiator and though we don't drive thru weat fields anymore it keeps the fenders grille and inner fenders stiffened so they won't flex. and yes they are a pain to install. :(
  11. Jeem
    Jeem
    Alliance Vendor
    Nice to know there is yet more fiddly sheetmetal in the front ends of these trucks!
    Hey, could you post a larger pic so I can see some more detail? I clicked it, but it didn't enlarge much.
    Thanks for showing this to us 35-6-7ers.
  12. mow too much
    mow too much
    Hey, my computer skills are very poor, this is the only way I could get it to take, I sent a copy to root maybe he can have better luck.
  13. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm with Jeem - please post a larger version!
  14. geemann51
    geemann51
    Here you go Bruce...
  15. mow too much
    mow too much
    Geemann your the man.
  16. henryj429
    henryj429
    I have a 36 p***enger car frame to go under my 37. Anyone got dimensions for placement of the pickup mounting holes? That would be a lot easier than figuring it out the hard way. Also, are the car and truck front axle centerlines in the same place?
  17. mow too much
    mow too much
    The car and pickup frames are the same, remove the 4 outrigger mounts that are used on the cars, you will NEED the wood body mounts for the pickup which are spacers between the body and cab they are about 175.00, but the holes are all the same on 35-40s, the radiator mounts are different on the later frames. The center lines are the same.
  18. geemann51
    geemann51
    One more from Mow to Much's archives...
    EDIT: I'd suggest saving this to your computer then using the zoom function of your graphic view to view the detail.
  19. henryj429
    henryj429
    Geez, ya gotta love the HAMB! I didn't really think anyone would have this. Thanks a lot!
  20. kruzr
    kruzr
    Thanks for posting this,
    I have a 37,gas (prob get flack for this but its on s-10 ch***is)filler neck was on right side of cab but I filled it in.
    My bud has a 35 with no filler in cab, is their a difference between commercial and pickup?
    My 37 has V windshield,crank to open it is bad,$75.00 for new one. I;d like to make electric opener for it.
    Got a crank from my bud's 35, found out the arms are shorter that crank out. Was going to change the arms,the gears are worn out on his too.
    And these trucks are hard to find steel rear fenders for.
  21. Roothawg
    Roothawg
    The commercial cab had the gas tank under the seat while the pickup had it in the rear of the frame.
  22. Roothawg
    Roothawg
    Yesterday I received a phone call from a nice fella, Lawson Cox, that is writing a book on the 35-36 Ford pickups. He says it may take 2-3 years but it will be available through the Early Ford V8 club. He has signed up for the hamb but mainly lurks.
    He also said that the Deluxe model was not available until 1936. He is a good source of info and I look forward to him posting on this thread.
  23. mow too much
    mow too much
    Thats cool, because the early ford v8 club is pretty much the gospil on early Fords, I looked for my old copys of the v8 Times for pickup info, but could not find them. Time for the ballgame.
  24. Thanks! Just what I needed
  25. Flat Ernie
    Flat Ernie
    Tech Editor
    Lawson hangs out over on Fordbarn quite a bit...
  26. cool post i have a 36 pickup all stock orignal 21stud
  27. pinupwithgun
    pinupwithgun
    Wow! You guys are the best. Thanks for posting the info. Great stuff.
  28. Lawson Cox
    Lawson Cox
    Roothawg:
    I enjoyed talking with you a couple of days ago about 35-36 Ford pickups.
    I am undertaking the task of writing the 35-36 Ford Pickup book for the Early Ford V8 Club of America and quite a task it is turning out to be. It is, however, progressing nicely but it will be quite some time before it is ready to be published.
    If I can help anyone with their truck, I'll give it my best shot. Just email me at lacoxii@bellsouth.net.
    Lawson Cox
  29. Jeem
    Jeem
    Alliance Vendor
    AWESOME.....when the book is ready, I will buy.
  30. HotRod33
    HotRod33
    very nice...I learned a few things Thanks....
