Projects 1935 3 Window Coupe
Discussion in 'Traditional Hot Rods' started by Glenn Ninow, Dec 28, 2021.
  1. yes
    17 vote(s)
    94.4%
  2. no
    1 vote(s)
    5.6%
  1. wheeldog57
    wheeldog57
    Neat car Glenn, what a beautiful start!!
    1937 was a transition year for the flathead, some 21 stud, some 24 stud blocks depending on what vehicle. If you could get a picture of the engine, we can maybe see what you have there. Side picture and picture of the distributor (if possible) that distributor is tucked in front behind fan.
    Again, cool ride man.
    loudbang and lothiandon1940 like this.
  2. Glenn Ninow
    Glenn Ninow
    I'm near 100% certain it's a '37 block with '35-'36 heads with head mounted spigot and water pump at the front. The block has the front water pump opening which is closed with a plate and the '35/'36 style engine mounts. It also still has the 'crab-style' 3 bolt distributor but, because it's a Canadian flathead it's difficult to verify engine numbers and ***embly dates because Canadian blocks etc., didn't follow US numbering and identification schemes. What I'm not sure about because I have not looked yet is if the block has the 'tin' side panels - I'll check it out a little later as I continue my research and auditing.
    loudbang, lothiandon1940 and Stogy like this.
  3. Jack Rice
    Jack Rice
    My Dad with my Sister in or about 1945
  4. alchemy
    alchemy
    Your block won't have tin sides, that was only on the smaller V8-60's.
    You will be hard pressed to find any numbers other than the large model numbers on the block or other components. At least anything that is decipherable. In the US there were no serial numbers on the engines, but maybe they stamped them in Canada?
    Glenn Ninow and Stogy like this.
  5. 40ragtopdown
    40ragtopdown
  6. youngrodder1929
    youngrodder1929
    Great coupe! Welcome aboard from down the road
    Davis
    loudbang, Stogy and Glenn Ninow like this.
  7. Glenn Ninow
    Glenn Ninow
    I'm in Marpole, where about might you be located?
    loudbang and Stogy like this.
  8. ***Area-51***
    ***Area-51***
    from Ohio
    Hope your proud of that thing, a very appealing 35 Ford.......
    Glenn Ninow and loudbang like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Beautiful ride.
    RE: Converting from mechanical to hydraulic brakes -
    Skip right over hydraulic drums and go straight to hydraulic discs, if you plan to do any amount of driving in it.
    I lived with drums on the front of a '46 Ford pickup for a year before converting to a Speedway disc kit for about $320.
    If you have the best pair of drum brakes and you're on the road surrounded by disc braked cars you'll still be the low man on the stopping totem pole.
  10. XWYNNSGUY
    XWYNNSGUY
    Hi, You can send that maroon 35 over to my garage anytime you want !! Love it !!
