Projects 1935 chevy 3 window coupe
Discussion in 'Traditional Hot Rods' started by 86031hotrod, Mar 2, 2015.
  1. 86031hotrod
    86031hotrod
    [​IMG][​IMG] I am new to the forum looking for some help with ideas for a front end on my 35 chevy 3 window coupe that was restored in the 70s. I have been looking around different threads and photos trying to determine what frame my all steel body is setting on. I want to start a father son project and put a new front end on this car and I am not sure what to order.
    I have been told it is a 50 chevy truck although I have not found a picture that looks the same as what I have. I am having problems loading photos to my album I get a file to large error? I have tried to upload from dropbox, iPhoto and my desktop. I have attached URL from photo bucket i hope that will work.
    I would be Very grateful for any suggestion.
    [​IMG][/URL][/IMG]
    [​IMG][​IMG][/URL][/IMG] [​IMG][/URL][/IMG]
  2. flamed34
    flamed34
    You should be able to open your photos on your computer and select "edit" and resize. The error you are getting is due to the files being too large to upload to this forum.
  3. tb33anda3rd
    tb33anda3rd
    pictures not working.
  4. 86031hotrod
    86031hotrod
    I hope this works. I have been trying to upload for two hours.
    Thank you for the help with the photos!
  5. 86031hotrod
    86031hotrod
    I have attached some photos of my frame, do you recognize it? I want to order a bolt on mustang 2 but need to know what frame I have. Thanks again for the info on the photo uploads.
  6. Texas Webb
    Texas Webb
    Nice looking Chevy.I like the straight axel,does it have ride or steering issues?
  7. TFoch
    TFoch
  8. flamed34
    flamed34
    Yep...that's a stock frame. One of these days I'll quit my day job and stop doing cars on the side and get back to my '34 Town Sedan (pics in albums).
  9. Here's a couple of ****y pics I just grabbed with my phone.
    Right hook, so a little different.
    Maybe the truck part you mentioned is your steering box where it goes through the frame? IMG_20150303_142555.jpg IMG_20150303_142832.jpg IMG_20150303_142908.jpg IMG_20150303_142922.jpg
  10. 86031hotrod
    86031hotrod
    No steering issues, I have just read a lot about the mustang 2 and thought the bolt on would be the easiest for my son and I to do. I have no preferences. I wanted to give the car a lower front end look. The way it is setting now the front finders and grill are shimmed up so they don't set on the front of the frame. I just have the hood setting on the top for the photo, it dose not fit right because of the shim job. Thanks for the reply.
  11. tb33anda3rd
    tb33anda3rd
    1540701-a5a713b4283e7953956cbc9836405954.jpg here is a picture of a 33 front frame. shackles in the front like the one kiwijeff posted. frame looks the same but not the spring set up. 1540701-a5a713b4283e7953956cbc9836405954.jpg
  12. 86031hotrod
    86031hotrod
  13. 86031hotrod
    86031hotrod
    I am pretty sure there have been some mods made on this car, I just cant figure out what they are. Body is in very good shape but the front grill and fenders have been shimmed so the fender don't hit the front of the frame? I cant figure it out. I have been driving it around with it the way it is but if I start on the new front end I want the hood to fit correctly. There is a ton of knowledge on this site it has been very helpful. The only way I can see how I get the front fenders and grill to match the body is to cut the front portion of the frame and go with a Mustang 2 kit?
  14. tb33anda3rd
    tb33anda3rd
    the bracket coming off the side of the grill shell to the frame is not right. i can not tell from the photo but does the grill shell have a "harp" that runs from one side of the shell to the other? are there two bolts holding it to the frame in the middle?
  15. flamed34
    flamed34
    The problem with your front fenders not sitting in place is they don't have the notch to allow the front frame horns to come through. You can see the notch on the front fenders of my '34 just before the transition to the "apron". You fenders appear to be aftermarket fibergl*** or reworked to eliminate the notch.
    kiwijeff likes this.
  16. 86031hotrod
    86031hotrod
    Unavailable!! I just ran out to the shop and looked. The fenders are all steel but looks like someone has filled in the notch. Not sure why but mystery solved. I have been trying to figure this out for 5 years just decided to ask for some help. I cannot thank you all enough. I need to decide what to do with the front end?. I can have the notch put back in the fenders. I can see where the notch was on the back of the fender. Thanks again.
  17. henry29
    henry29
    The axle, steering box, and drag link looks like whats on my 50 chevy truck, but the drag link looks like it's been lengthened.
  18. flamed34
    flamed34
    That's the great thing about the HAMB...collectively, there's a huge collection of knowledge and experience.
    Personally, I prefer the notch to the smoothed off fenders. It's less "streetrod"-ish and necessary to leave leave the frame horns if you want to run a bumper. You'll notice mine doesn't have the horns showing - because someone had cut the original frame in front of the firewall to use a front end that would not work (Camaro front stub). It currently has front rails from a '38 Plymouth with a mustang II, but I recently picked up a stock frame which I'll be redoing and putting under there instead.
    Keep us posted with updates!
  19. mgtstumpy
    mgtstumpy
    Looks like a truck frame, nothing like my OEM frame with lever actions and not telescopic shocks. Bar castings on front of frame looks different again. I'll post some frame specs when back from holidays.
  20. 86031hotrod
    86031hotrod
    Thank you, that would be a big help, I really think the last owner said it was a 1950 truck frame although it does resemble the original frame. I want to order a new bolt on mustang 2 kit or something my son and I can handle the install on but can't pin down what frame is used. I have looked at the 1935 chevy coupe specs and this front end does not match. I am wondering if it was possible he replaced the knee action with shocks? My father purchased the car 37 years ago and stored it driving only a few times. I have tried to contact the guy that restored in the 70s with no luck. I would sure like to see your pics. Thank you
  21. cavman
    cavman
    It's a Standard model, so it wouldn't have knee action when new. There are supposed to be notches in the lower frt fenders to allow the frame horns to protrude. that is where the bumpers attach. I don't think it's a truck frame. I have a Standard sedan. (coach) Nice looking old Chevy, BTW
  22. 49ratfink
    49ratfink
    one thing for absolute certain, that is not a 1950 Chevrolet truck frame, so you can just put that thought to rest.
    tb33anda3rd likes this.
  23. bonzo-1
    bonzo-1
  24. paul55
    paul55
    from michigan
    '31-32 Chevy frames are very similar w/straight rails in front like yours'. So, that's an application you could use. Or, just send your beam axle out to have dropped.
  25. 86031hotrod
    86031hotrod
    This is some great info, I kick myself for not joining this site years ago. I have the stock frame measurements and am going check them tonight. I am very excited to get started after trying to figure this front end out. Seems like someone scabbed together the front end. It worked well for along time. I am trying to decide whether to have the frame notches put back end the fenders and get a drop axle or go forward with the Mustang 2. I am ok with the ride as it is but like the idea of a new front end, Any thoughts?
  26. mgtstumpy
    mgtstumpy
    This is a 34 ch***is comparison. Ladder style construction. 35 p***enger has a an x-member centre section, 34 and 35 Masters have a K-member centre section. This [single] is a modified front frame horn bar casting and flat in design. Note that I've welded up the centre boss areas where the spring shackles originally mounted, parallel leafs front and rear. The rear bosses [double] have more shape due to downward arc of rear frame rails. The centre boss itself is parallel to the ground when mounted with the bars bolting directly to flanged ends. Compare with your frame and bar bosses as well as measurements. Rear spring2.jpg Photo0007.jpg
  27. flatmotor40
    flatmotor40
    from georgia
    Mgtstumpy those bumper brkts that are the ones I need for my 35 standard.Are you going to use them Thanks
  28. mgtstumpy
    mgtstumpy
    I believe that I may have a spare set of rears in the shed and will look tomorrow and let you know. The fronts are on the car now.
  29. trucker1
    trucker1
    There's a pair of '31 chevys in the current Rodders Journal that might give you some ideas. Glynn.
  30. hemiboy
    hemiboy
    Looks like a late '34 to '35 Standard frame- earlier '34s had the ladder style frame, later has the x-member. I have a Mustang II type front end under my '34 with a late '34 x-member type frame. I used a Heidt's crossmember but took an extra 1.5 inches out of where it welds horizontally to the frame, and have 2 inch dropped spindles. The front fender apron, below the grille, is about 3" inches from the ground. I have full fenders, but I like the fenderless look. If I was running fenderless I'd put in a streetrod replacement Model A front crossmember with a reversed eye front spring, dropped axle and Vega cross steer ( and all the ***ociated parts).
    86031hotrod likes this.
