1935 Ford 3 Window Coupe
Discussion in 'Cars For Sale' started by Brian Delie, Mar 4, 2026.
  1. Brian Delie
    Brian Delie
    City: Green Bay
    State: Wisconsin
    Price: 55000.00
    Overview
    The 1935 Ford 3 Window Coupe presented here stands as an exceptional example of vintage automotive craftsmanship. This particular car retains much of its original structure and showcases a blend of cl***ic Ford engineering and thoughtful updates.
    Body and Construction
    This coupe is notable for its original steel body. The body and sheet metal have reportedly never been unbolted since leaving the factory, a characteristic that is evident in its current condition and authenticity.
    Engine and Drivetrain
    Powering the car is a fuel-injected small block Chevy engine, paired with a 6-speed manual transmission. The rear end is a Ford 9-inch, complemented by a Ch***is Engineering parallel leaf setup, providing robust performance and reliability.
    Comfort and Features
    The car is equipped with both heat and air conditioning, ensuring a comfortable driving experience regardless of the weather.
    Wheels
    Eric Vaughn/Real Wheel wire wheels add to the cl***ic appearance and period-correct style of the vehicle.
    Late 1935 Build Characteristics
    It is believed that this coupe was built late in the 1935 model year. Some components found on the car were more commonly installed on the 1936 models. This was a common practice at Ford, where 1936 parts would be used to complete 1935 cars as the supply of original 1935 components was depleted on the ***embly line.
    missmuriel and AV8R like this.
