Technical 1936 Borge Warner T-9 question
Discussion in 'Traditional Hot Rods' started by Zigs, Sep 3, 2024.
  1. Zigs
    Zigs
    I have a36 International with a T9 . I pulled the top off and got all the rods to move and shift. That was a month ago. Now it won't shift. While cleaning could I have loosen dirt in the shift rods , ball bearings etc.
    I have exploded picture of shift deck but no explanation on how to tear down.
    Any help or guides would be appreciated
  2. Mac VP
    Mac VP
    I ***ume that you have the BW truck 4 speed spur gear transmission….straight cut gears and shafts and NO synchronizers. If it shifted through the gears before you did anything, and you never dis***embled the shifter housing ***embly, chances are that you probably didn’t get the gears and forks correctly aligned when you put the top back on. If you did take the forks and rails apart then they may not have been properly re***embled. Those shifter housings are tricky to ***emble and you usually need a special tool to get them back together.
    Okie Pete likes this.
