1936 Dodge truck ...another project
Discussion in 'The Hokey Ass Message Board' started by nhmikel, Mar 27, 2013.
  1. nhmikel
    nhmikel
    from NH
    Here's another make I decided on. Gotta love the mid 30's styles.
    It does need care and attention.
    Had it shipped in via Fastenal from TX
    Upon first quick visual inspection I need the following should you have?
    windshield frame, header pnl above, w.s. crank out, p*** door guts, maybe
    misc body parts? Door etc., Got any?
    And thats just the cab... whew!
  2. chevy54man
    chevy54man
    from NC
    Love this style and year of Dodge trucks, looking forward to seeing what you'll be doing to her!
  3. jarhead
    jarhead
    Looking good Mike!!!....
  4. nhmikel
    nhmikel
    from NH
    Its been awhile.....
    Tried to hammer up door hinge pins. No luck
    Whats the best way to remove them?
  5. 56don
    56don
    If they are made like the Ford pins, there is a tool made to press them out. I think **** Spadaro carries it and probably more vendors also.
    It worked on my very rusty 34 Ford truck. I heated the hinges and melted wax into the hinge.They still wouldn't budge so I used the tool and tightened it up and left it on for about 3 days, heating and tightening each day until they came out.
  6. nhmikel
    nhmikel
    from NH
  7. nhmikel
    nhmikel
    from NH
    Since I have no frame yet? Wanted to check on steel prices? Confirmed price for 36 ft approx $200, this would be 2x4 saw cut parts.
    I ask you should I fab my own? How can I figure out where the hood & grille goes if I do not have one? Thinking I what to maintain same distance as original
    Any other comments?
  8. chopd top
    chopd top
    from Florida
    My $.02 worth. The direction you want to go with it will dictate your frame choice. If you want to go with a traditional straight axle front end, building a frame would be the way to go. The only info I have found to help you locate the cab on the frame is here.
    In it, it states that in 1936 the wheel base was changed to 116" with a CA (cab to rear axle measurement) of 37 11/16". That should get you started. Now, if you wanted to go with a more modern suspension setup, (non-hamb friendly) you could always score an S-10 ch***is or early explorer ch***is as the wheel bases are pretty close to the stock Dodge dimensions and you can pick them up dirt cheap! You can find help for that here. Good luck with it!
  9. elitecustombody
    elitecustombody
    36 and 37 are the best looking years for these trucks. Are you planning to use stock fenders? If so, you will need the radiator shell with radiator support and brackets that come off of it to support the fenders. Not easy to find any of those pieces.
  10. nhmikel
    nhmikel
    from NH
    If I cannot locate an orig frame I will fab one for a straight dropped front?
    The cab to rear axle 37 11/16".....where on the cab is that number based from?
    Which hole, etc.? Then I can subtract the difference from 116" to get my location of the fron axle?
  11. nhmikel
    nhmikel
    from NH
    Elitecustombody..... I was hoping you would let lose on the grille support & hood parts?
    Anybody else please let me know?
  12. Buzznut
    Buzznut
    I love this truck, but have to be a little bias toward the '35 (since I have one that my father left to me when he p***ed):
    This is NOT my truck (I couldn't find a photo on my computer) but this is a '35. Mine has it's '50's navy blue lacquer finish with black steelies.
  13. nhmikel
    nhmikel
    from NH
    HMMMM.....Will a 35 nose fit on my 36?
  14. elitecustombody
    elitecustombody
    That's a late 35,it shares the cab with 36.
    But I just love the 36-38 fat fenders. Take a look at this 37 beauty
    Or this 36
    Yes,it will
  15. nhmikel
    nhmikel
    from NH
    Can I mix and match hoods & grille supports?
    Which can you?
    ie.. Will 35 hood fit with 36 or later support?
  16. earlymopar
    earlymopar
    Whats a "grill support"? Do you mean grill "shell"? 36 and 37 have interchangeable grill shells and hoods.
  17. elitecustombody
    elitecustombody
    stick with whatever year you find,35 grille shell with rad support won't fit with 36 hood or fenders. Spend time studying pictures on line
  18. 36brothers
    36brothers
    I have one to get measurements from, as you need. I'll get you a measurment from cab mounting holes to front axle tonight if someone doesn't beat me to it.
  19. elitecustombody
    elitecustombody
    I have 3 of these trucks, just tell me a point on a frame to measure from
  20. nhmikel
    nhmikel
    from NH
    Since all I have is the cab....
    Verify the distance between the cab holes(front to back) that are on the frame.
    Then measure from one of the cab mtg holes to the front wheel center line.
    Or measure from one of the cab mtg holes back towards the rear......
    should be around 37 11/16"?
    Elite.....those are some sweet pics
  21. 36brothers
    36brothers
    Distance from the front cab mounting holes to the center of the front axle is 26 3/8", from that hole to the rear most cab mounting holes is 43", from those rear most cab holes its 46 5/8" to the center of the rear axle. Yes my wheel base is 116"~ There are 6 mounting holes in my cab and frame.
    Dan
  22. nhmikel
    nhmikel
    from NH
  23. 37 caddy
    37 caddy
    from PEI Canada
    There used to be a junkyard in Maine that had a couple of those trucks,it was in a place called Milo,about 20 minutes north of Bangor.It was about 10 years ago i was there,not sure if it is still there or not,i heard the old guy that owned it died,PM me and i can give you some directions on how to get there,might be worth a shot. Harvey
  24. nhmikel
    nhmikel
    from NH
    37 caddy PM sent
  25. nhmikel
    nhmikel
    from NH
    Note to EarlyMopar..... I keep getting messages sent vis my personal email and keep getting failure notices when sending them back to u?
    Please send PM via hamb with contact info?
    Thanks
  26. 36DodgeRam
    36DodgeRam
    Mike, the center hood hinge is 40 3/8" long, the Riteway Headlamp bucket is 10.5" long, 7.25" dia at the lens, 7.75" dia in the middle, and the '36 headlamp mounting base is 7.25" long. I think '36 & '37 use the same grill shell and Ram, and center grill piece, the grill sides are different, but interchange in the shell if you can only find the '37. I notice on the brown '37 above, 3 pieces of stainless trim on each side of the hood, my '36 has 5 pieces, the 3/4" wide middle piece on the louvers, and the two 1/4" strips above and below the louvers. So the hoods might be different. I have alwways thought '36 and '37 fenders are the same, but can't verify that. I hope this helps you put yours together.
  27. elitecustombody
    elitecustombody
    36DodgeRam, Hood sides are different for sure,36 has 5 thin stainless trim pieces versus 37 has only 3. Louvers on 36 gradually taper to almost nothing at the back end, where 37 has a bulge. From what I can see,I can not find any difference between fenders on my 36 Dodge,37 Plymouth and 38 Dodge trucks.
  28. nhmikel
    nhmikel
    from NH
    Earlymopar
    please contact me
    with what you may have? Pm with contact info
  29. nhmikel
    nhmikel
    from NH
    I found a 37? about an hour away. Lots rusty patina
    Please help verify the year??
  30. elitecustombody
    elitecustombody
