Technical 1936 frame
Discussion in 'Traditional Hot Rods' started by 3wmike, Nov 13, 2019.
  1. 3wmike
    3wmike
    Hi, does any of you guys know if a GM t10 five-speed fit into a 1936 ford frame without bigger modifications, as widening the frame
    Thanks
    Michael
  2. alchemy
    alchemy
    A T10 5 speed? Do you mean a T5?
    No widening needed, but lots of t******* of the center of the X. Shouldn't need to remove any of the X rails themselves though. Depending on how far up (forward/back, up/down) you mount the engine and trans, you might even be able to leave the bottom plate alone and keep your wishbone mount.
  3. razoo lew
    razoo lew
    from Calgary
  4. 3wmike
    3wmike
    Thank you, now I know it´s possible before I take the old transmission out of the ch***ie
  5. zorro4153
    zorro4153
    from Pa
    Just make sure that you can move the trans back and down enough to get it out with having to pull the engine. If you have to remove the front sheet metal and pull the engine to get the trans out, you'll kick yourself in the *** later
    LOU WELLS and seb fontana like this.
  6. 3wmike
    3wmike
    I´ll remember that :)
