1936 Roadster build (from a 4 door, and 5 window)
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Mar 19, 2010.
  1. brigrat
    brigrat
    from Wa.St.
    Whenever I think Chris is gonna do a zig he does a jag, it's kinda scary till you see it unfold ................................. the price of 4 doors just keeps going up!
    I have to be excided, I sold a nice '36 3/W to make it happen..................
  2. sled
    sled
    Yeah Lon,your dream is coming closer now and you could'nt be in better hands...simply love Chris work and at that age ,man....this is gonna be a KILLER ride...start smiling there!!!
    I can find you another 3w ,no worries...you're gettin a one off built right there,shall we say a winner???
    mexican fans are watching here...popcorn,please!!!:D
  3. shoebox1950
    shoebox1950
    I just looked at your website....uh, holy ****- you do some AMAZING metalwork! That '33 tudor-vicky transformation is unreal. Looking forward to seeing this '36 come together...awesome stuff!
  4. Salt Flats Speed Shop
    from Utah
    Ive been working more on the cowl. I got the two end pieces made that the door goes against, and now i'm making the piece that transitions underneath.
  5. FalconMan
    FalconMan
    from Minnesota
    You are doing one heck of a job ! I cant wait to see more .....
  6. Amazing work Chris. Looking forward to the progress on this one. If your other cars are any indication this will well worth watching and could put a rare body style within the average guys grasp. Pat.
  7. vonpahrkur
    vonpahrkur
    Really digging this thread!!
    couple questions for Chris, you said you are using a four-door cowel-any special reason? is it different that a coupe?
    You said the rear section is from a coupe, are the doors coupe or four door sedan, why or why not?
    thanks in advance.
  8. Salt Flats Speed Shop
    from Utah
    To answer your question the doors on the roadster, five window, and 4 door are the exact same length.
    The cowl on all the closed cars are the same also weather it was a sedan or coupe.
    The back sections on the 5 window coupe, and the roadster are basically the same exept for the different lengts of the area above the trunk. And the fact that the roadster has wood posts instead of steel on the coupe.
    So basically I could have used a 5 window completely for the project, but we had access to a 4 door for the doors and cowl. And then I just had to find a 5 window back section to complete the setup.
    Hope that all makes sense.
  9. vonpahrkur
    vonpahrkur
    Yes thanks, looking forward to seeing the next steps in the process!
  10. Salt Flats Speed Shop
    from Utah
    Just making more pieces to the puzzle.
  11. Pinstriper40
    Pinstriper40
    That looks great so far! This will be one heck of a car!
  12. loudpedal
    loudpedal
    from SLC Utah
    More PLEASE!!!
    I'm chompin' at the bit here...
  13. sled
    sled
    One of my favorite threads right here...Chris ,you're doing one heck of a job,so it will bring finally a rare bodystyle to a wider crew..i wont mind do the same as a conversion ,i got plenty 36 down here to use
    VERY inspiring,it will be a killer car...thanks for posting this,subscribed and cant wait to see more of your impressive work...learning every day!!
  14. 50Fraud
    50Fraud
    Verrry interesting!
  15. Salt Flats Speed Shop
    from Utah
    Getting most of the cowl all tacked in place. Just have the last two pieces to make on both sides.
  16. loudpedal
    loudpedal
    from SLC Utah
  17. Salt Flats Speed Shop
    from Utah
    More on the cowl. Got all the major pieces made and tacked in place.
  18. flynbrian48
    flynbrian48
    Man, you're making me want to cut the top of the cowl and doors off the Fordillac and start over. This looks fantastic, much better than what I did. Good reason to look for another clapped out '36 body, I know I can do better having seen how you are doing this.
    Brian
  19. brigrat
    brigrat
    from Wa.St.
    You have nothing to hang your head about Brian, your brain child and unique, keep it that way for sure!
  20. Salt Flats Speed Shop
    from Utah
    Sorry for how long its been since I last updated. Its been a crazy couple weeks around the show and with the photo shoot on my 32' sedan.
    I got the door taken apart, and sand blasted. Ill make the inner frame fit with the new hinge location. Then ill work on the door skin and the top of it transitioning into the cowl.
  21. koolkemp
    koolkemp
    Just a question for you..did you make some kind of tool to peel back the fold on the door skin so you could remove it safely? Would love to see some pics of the process if possible??
  22. Salt Flats Speed Shop
    from Utah
    Honestly I just use a small claw hammer. I filed the ends a little sharper.
    I first have to locate the spot welds and carefully drill them out with a drill bit. Then I use a combination of a small screwdriver to lift the edge, and then the claw hammer to hook onto the edge and pry it up.
    I will have to run the edge through the bead roller to make it a crisp 90 again, cause it doesn't come off perfectly straight. But overall it works nice. Cause then i'll just make the top of the door piece, weld it on, and then crimp it back over the frame.
  23. mpot
    mpot
    I can't tell you how much I envy your work. My '36 (see avatar) has been my drag car for the last 15+ years and it will be my next project to convert it to the street after I finish my '32 roadster. Unfortunately, I don't have the skills to turn the 5 window into a roadster. Beautiful work. My eyes are glued!
  24. Hot Turkey
    Hot Turkey
    I can dig it man!
  25. brady1929
    brady1929
    man are you awesome with magical skills
  26. brigrat
    brigrat
    from Wa.St.
    Enough kudo's or his hourly rate might take a hike upward!
  27. DeuceDog
    DeuceDog
    from Breese, IL
    I don't mind:D
    DD
  28. Salt Flats Speed Shop
    from Utah
    Got back today on the p***enger door. Got the top hinge relocated and attached to the inner door. It opens and closes nicely now.
    Now its on to building the roadster top part of the door skin.
  29. Salt Flats Speed Shop
    from Utah
    Im starting on the pieces for the top of the outer door skin. Its coming along nicely.
  30. lorodz
    lorodz
    wow man you got such fantastic metal skills wish i could do 1/4 of what you have already done
