1937 Chevy coupe windows
Discussion in 'The Hokey Ass Message Board' started by Dogger, Dec 5, 2010.
  1. I am building a '37 Chevy coupe and want to remove the door vent windows and install 1 piece gl***.
    I have been told that due to the geometry changing on the gl*** that I cannot keep the factory window crank mech because it will cause the gl*** to get into a bind when going up/down.
    Is this true?
    If so what have others done to stay away from elect windows ?
    I saw in the April 2010 Rod & Custom,"Hemrod" has what is described as "sliders" to raise and lower the door gl***....probably has 3/4 settings that the gl*** can be lowered to.....is this a kit or do I need to pull out the erector set ?
    Thanks HAMB'ers !!!
  2. the biggest problem is the the vent frame, it on a different angle than the door gl***. if the car isn't painted it's an easy fix. put a straight edge on your door gl*** to the front of the door you'll get an idea of what your up against.
  3. mr.chevrolet
    mr.chevrolet
    i'll buy your vent windows if you are removing them.
