Technical 1937 steering column bearing
Discussion in 'Traditional Hot Rods' started by richard crow, Aug 11, 2024.
  1. richard crow
    richard crow
    got great help on lower bearing.now i need help on the upper bearing..the orignel is a rubber bushing i would like to install a bearing. its a stock 1937 1 1/2 column i am using the 37 wheel. thank you
  2. 19Eddy30
    19Eddy30
    from VA
    Msc, Grainger , Mcmaster ,
    I like having the book instead of the online catalog find it hard to navigate.
    Needing to know the ID of tube & OD
    Of shaft , then check spec on bearing ,
    I like using seal bearings ..
    Then there are times , maybe Id can find ,& not Od or vice reverse , then creative thinking required, or cut bushing / bearing out of Br*** / Bronze,
    Welder To make shaft bigger where Bearing will ride / set , turn on lathe
    For press fit or cut for Snap Rings or both ,,
    Some times Id of tube to big , on lathe
    Make a Bushing to fit Id of tube then Id
    On bushing to fit Od of bearing,,,
    I have cut many columns & adapt ,
    I have cut OEM Upper tilts off & adapted ,from other brands , there are alot of "Aftermarket "steering columns on the market that are just " Junk" including Flaming River,
    Also if you have the experience and know what you're doing you can also make your own collapsible column shaft
    Made my own several 32s,
    So the original locking for the steering wheel lock works,,, ( Original Drop)
    Doing this Does & make it easier when you have Lathe & welder ,,,
    But not necessary..
    Sometimes you have to do the farm fix hand tools ,hacksaw ,cracks in your porch to make and use like a metal break,,
    Some times Just need to think out side of a box
  3. F-head
    F-head
    They make an upgraded rubber bushing with a bronze insert
    They work great and still retain some vibration dampening
    C and G ford parts and Sac vintage ford has em
  4. 19Eddy30
    19Eddy30
    from VA
    For Vibration could you use
    urethane, with Bronze / Br*** bushing
    1-2 inch deep into / down column tube.
    With bushing centered.
  5. Deuce Lover
    Deuce Lover
    Many guys on Fordbarn hunt down and use the wheelbarrow bearing from Ace Hdwe.
    Track Order
    <\/i>","library":"fa-solid"},"toggle":"burger"}" data-widget_type="nav-menu.default" style="box-sizing: border-box; --flex-direction: initial; --flex-wrap: initial; --justify-content: initial; --align-items: initial; --align-content: initial; --gap: initial; --flex-basis: initial; --flex-grow: initial; --flex-shrink: initial; --order: initial; --align-self: initial; flex-basis: var(--flex-basis); flex-grow: var(--flex-grow); flex-shrink: var(--flex-shrink); order: var(--order); align-self: var(--align-self); flex-direction: var(--flex-direction); flex-wrap: var(--flex-wrap); justify-content: var(--justify-content); align-items: var(--align-items); align-content: var(--align-content); gap: var(--gap); position: relative; --swiper-theme-color: #000; --swiper-navigation-size: 44px; --swiper-pagination-bullet-size: 6px; --swiper-pagination-bullet-horizontal-gap: 6px; --widgets-spacing: 0px 0px; --e-nav-menu-divider-color: var( --e-global-color-text ); --menu-height: 100vh; width: 1140px;">
    Home / Steering / 1933-39 Ford Modern Replacement upper steering column bearing
    [​IMG][​IMG]
    1. [​IMG]
    2. [​IMG]
    Regular Price $9.00
    Part No. 40-3517-MDN
    19 in stock
    1933-39 Ford Modern Replacement upper steering column bearing quan***y
    Add to Wishlist
    Categories: Accessories, Steering, Suspension / Ch***is Parts
  6. RICH B
    RICH B
    I like to use a F-1 bearing, cone, and spring. Drive the bearing down into the tube with a pipe.
