1937
Discussion in 'The Hokey Ass Message Board' started by logdog37 chevy, Mar 4, 2013.
  1. logdog37 chevy
    logdog37 chevy
    from otsego
    Hi I have a 1937 Chevy half ton truck that was my great grandpa's. me and my dad are going to start doing the body work on it what can I do to get it lower without doing anything to the frame:confused:
  2. slammed
    slammed
    How much time have you spent around old cars and truck's? If your looking to leave the fenders on it and have truck when your done welcome aboard. Pix of this truck. Drive train plans. Theme of build. This helps w/ your question.
  3. logdog37 chevy
    logdog37 chevy
    from otsego
    I have spent many years with old cars but this is the first time i have done a full rebuild. It has a 261 chevy engine with a stock frame. I plan to take the fenders off and I want it to look like an old school hot rod.
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    banging
    head
    on
    keyboard
    kidcampbell71 likes this.
  5. jimstro16
    jimstro16
    Good luck... sounds like your going to need it
  6. rustang
    rustang
    The '37-'38 trucks are one of my all time faves, I've had a couple of them over the years... my present one I've owned for 32 years.....
    Just my opinion, but this style truck looks best with the fenders on, i don't really care for the look with the fenders removed on these, esp. if they are not lowered.
    Lowering one without frame or body mods is pretty tough to do using the stock running gear...
    Tom
  7. Ghost28
    Ghost28
    You have one of the most desirable years of the chevy trucks. I agree with all the others about leaving the fenders on your build. After it's all said and done the time and effort put into your truck, it would be well worth it in appearance and value. And I am sure your grandfather would be proud of you for saving his truck. Good luck with your build.
  8. LAROKE
    LAROKE
    This one is lowered about three inches in front (leaf springs from Eaton with hot rod drop and ride rates) and two inches in back (lowering blocks).
    I agree with the others that this year of truck looks much better with fenders.
  9. logdog37 chevy
    logdog37 chevy
    from otsego
    It does look good with fenders.
  10. B.Sharp
    B.Sharp
    Her's mine with a fatman IFS/ 2" dropped spindles under the front and 3 leafs in the rear with 2" blocks. Full fendered and a long bed.
  11. 1951Streamliner
    1951Streamliner
    from Reno, NV
    For the love of God please leave the fenders on.
  12. K13
    K13
    Yup leave the fenders on!!
  13. Kinky6
    Kinky6
    Yeah, about that fender thing...... :rolleyes: You might go take a look at some posts on here on authentic hot rods from the '40's and the '50's ( can someone post a link to help him out?)
    Up through about 1934, a lot of the "old school" (read, origional) hot rods do look very cool without fenders, although a lot of them ran fenders for street use, and looked very good also. After about 1935, the no fender look just doesn't look so good.
    Research and plan before you start altering stuff just for the sake of changing it, and you'll end up with a better looking project.
    Just my 2 cents worth, *****6 :cool:
  14. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Do your gr grandpa proud and fix it up like he would like to see it.
  15. joel
    joel
    Yeah, I can hear it from here.
  16. jarhead
    jarhead
  17. Saxman
    Saxman
    There you go, dropped axle and full fenders would be the ticket. Those are cool lookin trucks...when they have fenders.
  18. Black Primer
    Black Primer
    If you really hate your fenders PM me. I'd be interested in them.
  19. raymay
    raymay
    Another vote for leaving the fenders on. There is plenty of room under them if you plan on lowering the truck. Check some of the aftermarket spring options. The cheapest way to lower the back is to install lowering blocks.
    I have had a few 37 Chevy trucks. On my last one I cut and pasted pictures, did drawings and even build a diecast model of what I wanted to build. The result was a modified body into a kingcab that was mounted on an S-10 ch***is which provided me with one of the nicest handling rides. It was a pleasure to drive this truck on long trips. Low does look nice but you should also consider being able to enjoy driving it. Where you live and the kind of roads you drive could play a part in your decisions. I had my truck lower until one day when I had the bed loaded and it kept bottoming out. A switch to a different size lowering block in the rear end solved my problem and I was still satisfied with the look and ride I was getting.
    Before you start, try getting a plan together of what you want the truck to look like and how you want it to handle. Look at other guys trucks, ask questions, keep an open mind and check out the type of parts you could consider using on your build. Once you know the direction you want to go, you should be on your way to a successful build.
    Good luck. Take your time and have fun with it.
      187.7 KB
      109.2 KB
