Projects 1938,39,40 Sloper Custom
Discussion in 'The Hokey Ass Message Board' started by X38, Nov 4, 2020.
  1. X38
    X38
    It's in the plan Tony;)
    I came to that conclusion when I fitted blinkers in the rear ones and didn't like the idea of anything visible on the back side. The rear ones will be removeable for servicability. Also like the rears I'll be eliminating the bolt heads and smoothing the front surface.
    hotrodjack33, Stogy, Hnstray and 2 others like this.
  2. tmf
    tmf
    Tony as 50Fraud suggested is a really good idea. I did the same on my Willys and it tidies it all up and makes it look finished.
    Stogy likes this.
  3. I realize you are in summer mode, but a bunch of days have been accomplished since your last post, has anything come to p***?
    40two and Stogy like this.
  4. X38
    X38
    Yes, I have been doing things. I was thinking only Monday that I haven't updated this thread in a while. I'll get onto it soon. But don't get too excited, nothing dramatic, just a lot of fiddly time consuming stuff.
    Thanks for your interest.:)
    hotrodjack33, 40LUV, brEad and 2 others like this.
  5. Bandit Billy
    Bandit Billy
    I am in the same mode. I work on the truck every evening when I get home but no one can tell cuz its just little ****. Still needs to get done though.
    X38 and Stogy like this.
  6. Ken Pecora
    Ken Pecora
    Dang, the talent you guys have is also scary.
    TomT and Stogy like this.
  7. X38
    X38
    Okay, here's a short update on the kind of fiddly things I've been spending time on. As BB says, stuff that still needs to be done.
    The big work has been done on the outside of the fenders. but there is tidying up to do on the inside where the custom work was at the front for the new grille opening and finessing wheel lip repairs from the inside, now that they are off the car.
    One of the things is also dealing with the various remaining splits and cracks that a hard life has left. So here are a couple.
    The first is the corner with the mounting location for the fender brace. This was splitting both sides and rather than just weld them up, I cut an oversize piece and welded that on as well as welding the splits. This allowed me to weld it better and trim to a nice shape when done. (I didn't have to do the other side because as you have seen I've already completely re made that corner.) If you look closely you can also see where someone made a series of holes in the fender lip. Welded them up too.
    The upper edges also had splits aplenty. Delt with in a similar way.
    A bit more of this then I'll finally be able to get these in epoxy.
    itsmee, brEad, 40FORDPU and 16 others like this.
  8. Chili Phil
    Chili Phil
    Nice work, Tony.
    X38 likes this.
  9. X38
    X38
    To back peddle to where I had left off previously...
    You may have noticed blue tape on the lower hood edge in earlier posts? That was me playing with the gap. 38's seem to have an issue here and mine was not very good. After much contemplation I decided to simply slit the lower edge and add a filler piece of what ever was necessary. I admit freely to ****ting my pants about this... long welds and twice each side. What could go wrong? At 2 in the morning lying awake...everything!
    Anyway, I bit the bullet and this is what happened.
    I felt better after that marathon it's decent progress beyond a task I was dreading. Turned out not too bad in the end. Next coming is some primer.
    Stogy, itsmee, 31Apickup and 21 others like this.
  10. goldmountain
    goldmountain
    This just keeps getting better.
    Stogy and X38 like this.
  11. Jacksmith
    Jacksmith
    from Aridzona
    A tricky task... the results out-weigh the work and now you can move on.
    Stogy, brEad and X38 like this.
  12. manyolcars
    manyolcars
    Beautiful car, awesome work!
  13. TomT
    TomT
    Sweeeet! Great vision and even better work to bring it to life!
  14. Bandit Billy
    Bandit Billy
    Gap 'em like they're white, block 'em like they're black. You are halfway home.
    Stogy, Tow Truck Tom, hfh and 2 others like this.
  15. X38
    X38
    Have not heard that before, but it's a good one.:)
  16. alchemy
    alchemy
    Glutton for punishment on those gap fillers on the hood. Ida probably bent an angle on a new strip that was wider, and had one weld seam.
    Have you ever tried TIG welding? If you are a sheet metal guy, you will be way better off working/shaping on a nice soft weld. I spent 30 years using MIG on everything, but then found out how much better TIG is for sheet metal work in the last dozen years. I'm sure you would take to it too!
    Stogy and brEad like this.
  17. X38
    X38
    Yes, that was a consideration. If I had a stretcher /shrinker tool I probably would have gone that way. Believe me, I went through many options!
    re. TIG, I have often thought of that, but I'm saying this is my last rodeo so I'm trying not to get into any more tools. I hear what you're saying though and have witnessed the advantages of TIG.
    Stogy, Outback, Peanut 1959 and 2 others like this.
  18. Bandit Billy
    Bandit Billy
    I have to fess up, I stole that one from Charlie Hutton. I have kept several of his articles about painting tips and his love for black cars in particular. Most TV car guys are hacks (99%), Charlie knows his ****. You might say he is a 1 percenter.
    Stogy, Outback and The 39 guy like this.
  19. The 39 guy
    The 39 guy
    Definitely a challenging repair, and the outcome is good! It seems like most of the 38's I have seen have that same hood gap problem. People must have really leaned on those hoods without releasing them at the hinges first while trying to lower them. My buddies 38 (about 10 years ago) had that problem and I had suggested it be repaired as you did. Something must of been lost in translation though as his body man just welded a thick piece of metal to the bottom flange ( still had the same arch to it though). It just never looked right. It was otherwise a really nice car. The hood gap bothered him so much he eventually sold the car. I get by with the mig welder also. I would like to try a tig again but I just don't seem to have the eye,hand foot coordination to run so I have just had to become a really good grinder/metal finisher :) I am enjoying your posts, I need to get some fresh updates out soon also.
    Stogy, Outback and brEad like this.
  20. X38
    X38
    So here are the pieces in epoxy primer. Behind are the running boards, they're done too and ready for covering.
    Stogy, itsmee, Outback and 10 others like this.
  21. brady1929
    brady1929
    Very cool.
    Stogy and Outback like this.
  22. Outback
    Outback
    from NE Vic
    Just looked up your thread, I somehow missed it in my alerts, it looking great! Any more progress?
    Stogy likes this.
  23. X38
    X38
  24. X38
    X38
    Stogy, itsmee, brEad and 20 others like this.
  25. All one colour again is a milestone worthy of some sort of celebration, congratulations.
    Stogy, X38, The 39 guy and 1 other person like this.
  26. tub1
    tub1
    from tasmania
    You sloper fits very nice , you have spent time making the gaps spot on well done ,my sloper dosnt fit together that well but I enjoy driving it too much to pull it apart as I know I'd never get it back driving again ,
    Stogy, X38 and TrailerTrashToo like this.
  27. Nice job on figuring out the door latch mechanisms!
    Stogy, X38 and lowrd like this.
  28. wstory
    wstory
    from So Calif
    Accolades for working out all that "monkey motion"! An entirely different skill that trueing up gaps,...an art form in it's own right.
    Stogy, brEad, X38 and 1 other person like this.
  29. The 39 guy
    The 39 guy
    Well done! Gaps look great!
  30. Outback
    Outback
    from NE Vic
    Was recently thinking about this thread & was wondering how you were going with the Sloper, it's looking great!
