Projects 1938 chevy gasser
Discussion in 'Traditional Hot Rods' started by Oldskooloval, Jan 3, 2023.
Tags:
  1. Oldskooloval
    Oldskooloval
    Frame cleaned and painted, ready for ***embly A56A2482-1732-4E5D-8E9A-507E76877FE0.jpeg
    Stogy, Manostihl83, enloe and 6 others like this.
  2. Oldskooloval
    Oldskooloval
    287 cu in g***er engine. 2.850 stroke on a 4.00 bore. Billet main caps, Callie’s crank and Oliver rods,461x heads ported with ***anium valves and t&d shaft mount rockers. Edelbrock tr1 also modified extensively inside the plenum. Gonna start out with a single carb and a liberty modified Nash Transmission DAB3289D-DA39-4568-ABD9-E5F422248497.jpeg 998813A7-FF78-47C2-8809-F22036028DB1.jpeg F832F408-C928-495E-A1DA-4A39D151B090.jpeg 44BFC9A9-D824-48E8-87DF-4B6ED16DC357.jpeg EE1182CA-D515-4891-B3B6-9F33F73B8787.jpeg
  3. Oldskooloval
    Oldskooloval
  4. guthriesmith
    guthriesmith
    Man, this is going to be cool! Thanks for the updates.
    Stogy likes this.
  5. "Race only" Yeah...
    I can almost smell it.
    And I thought I heard the faraway shriek of a big bore short-stroke small block...
  6. AHotRod
    AHotRod
    That engine combination brings back great memories ... used to see them at 10,000+ leaving the starting line ... what a hoot.
  7. Tater Bug
    Tater Bug
  8. Ericnova72
    Ericnova72
    from Michigan
    Any pics of the finished tunnel ram interior??
    Stogy, Tickety Boo and 427 sleeper like this.
  9. Something like this…. 10814A2F-4036-4483-A6C1-0144D8A40C37.jpeg 084DBFF3-B1EF-4973-AE89-04249552508F.jpeg I might be wrong , but this is how I’m going to do mine!
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    Very cool :cool:, ends up similar to the base of my Victor Ram.
    Improved my 60 ft time after texturing the floor of my Ram with a needle scale gun to help in keeping the fuel from puddling, are you planning to run a single 4?
    Stogy and 427 sleeper like this.
  11. Jdmcrx
    Jdmcrx
    very cool build . Cant wait to see some vids on this
    Stogy likes this.
  12. pila38
    pila38
    Love me a ‘38 Chevy. This looks bad***
    Stogy likes this.
  13. Basically the same
    Top hat" type ch***is in my 36 coupe. It was a g***er in the 60s and other than adding front disc brakes it's exactly as it was built by the prior owner. It's got the original drop axle with blocks to raise the front up and it's staying that way because I'm retaining as much of the original vibe as possible without sacrificing safety. The motor mounts were also built in the 60s and are welded to the top of the frame as well as having braces welded to the bottom & sides. It's not going anywhere. 57 Olds rear and home built square tube traction bars are also original to the 60s builder. Call me crazy but I'm even going to keep the stock steering box unless it gives me trouble and then I'll go with a period correct subs***ute. Pic for inspiration.
    enloe, akoutlaw, 72yenkonova and 6 others like this.
  14. Grumpy ole A
    Grumpy ole A
  15. Marty Strode
    Marty Strode
    enloe, akoutlaw, 72yenkonova and 5 others like this.
  16. 1971BB427
    1971BB427
    from Oregon
    When I built the motor mounts for my '39 Chev g***er I made the mounts start at the bottom of the hat channel frame and extend to the top. Then I used flat bar across the top extended out over the vertical plates to box them in and give plenty of support so they wouldn't tear out of the sides of the frame. Those frames are nice, but also fairly thing metal, so a vertical edge welded to the frame could easily tear itself out of the metal over time if not done right.
    NHBandit likes this.
  17. Dan Hay
    Dan Hay
    In regards to the thin top hat frames, the home made mounts in my 38 had ripped the top of the frame at the weld. The weld is indeed strong, the frame, not so much. See first pic
    I cut those out and went with Ch***is Engineering bolt in units, that encapsulate 3 of the 4 sides of the frame rail, providing reinforcement to the top and sides of the frame.
    NHBandit, enloe, akoutlaw and 3 others like this.
  18. deathrowdave
    deathrowdave
    from NKy
    That’s the answer to engine mounts . I also but tubes through the frame , welded so tightening would not crush the top hat of the frame
