Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. John 79
    John 79
    from Sweden
    Yep, it's kinda tight in some places.
    Stogy, patsurf and Okie Pete like this.
  2. John 79
    John 79
    from Sweden
    On to the drivers side kickup, had to do some repairs in front of the kickup.
    Rust and dirt was blowing the inner and outer frame apart as you can se in the first pics.
    Made a couple of **** welds instead of the single rivit to hold the frame pieces together.
    Also i had a bad weld (made by me...) on the bottom of the leaf spring mount that i wanted to fix.
    rost ram2.jpg rost ram3.jpg urkapad bit1.jpg urkapad bit2.jpg urkapad ram1.jpg urkapad ram2.jpg urkapar ram3.jpg kass svets.jpg ny svets.jpg ny plåt1.jpg ny plåt2.jpg ny plåt3.jpg ny plåt4.jpg ny plåt5.jpg ny plåt6.jpg
  3. Stogy
    Stogy
    This Custom is quite the baby...awesome what your doing. You really got a good handle on making it right.
    John 79 and Outback like this.
  4. John 79
    John 79
    from Sweden
    Thank you sir, thats very kind of you.
    don colaps, Outback and Stogy like this.
  5. John 79
    John 79
    from Sweden
    Well the kickup is now officially done, not the smartest thing to do with the body on or after i put the trunk floor in but i can only blame myself for always being in a hurry and not thinking things thru.
    Had to put the rear axle in place and get it of the jack stands and on the ground.
    It looks alot lower without the fenders skirts when you can see how the wheel sits.
    20250209_120619.jpg 20250209_120656.jpg 20250209_130150.jpg 20250209_133508.jpg
  6. John 79
    John 79
    from Sweden
    Rear shocks in place, drove all last summer without any shocks.
    Had to put them in front of the axle for clearance.
    I work at a company that a**** other things does alot of laser cutting so i use to save stuff that i might build someting of and today i used some for upper mounts.
    Okie Pete, hfh, 63fdsnr and 5 others like this.
  7. guthriesmith
    guthriesmith
    How tall are those lowering blocks? Looks great too! :cool:
    Stogy likes this.
  8. alchemy
    alchemy
    The inverted angle is different, but putting them in front is fine.
    Stogy likes this.
  9. John 79
    John 79
    from Sweden
    They are 4 inch.
    Stogy and guthriesmith like this.
  10. John 79
    John 79
    from Sweden
    Yep but it was the only option, don't think there will be any problems.
    Drove all summer without any rear shocks at all so this must be better :)
  11. John 79
    John 79
    from Sweden
    Started to cut the holes for the bumper brackets, will test fit everything before i weld the inner pieces to the holes. 475591823_662419679561472_3724704040853019217_n.jpg 477996805_1698517584413018_8723585568937759636_n.jpg 476574049_627197546571181_8891817209325011443_n.jpg
    The 39 guy, Stogy, Okie Pete and 4 others like this.
  12. John 79
    John 79
    from Sweden
    Took 2 inch of the rear bumper brackets, the inner brackets were totally different so the are off for now.
    Might do a panel between the body and bumper later on or might not because im lazy.... 20250221_133929.jpg 20250221_133942.jpg 20250221_133954.jpg 20250221_135024.jpg 20250222_131438.jpg 20250222_132134.jpg 20250222_132517.jpg 20250222_135933.jpg 20250222_140012.jpg 20250222_140217.jpg
  13. Crusty Chevy
    Crusty Chevy
    There is a factory accessory pan that goes between the bumper and tail pan. They called it a gravel deflector as owners were reporting stones being thrown up from the rear wheels, hitting the inside of the bumper and ricocheting back and chipping the trunk lid paint. I believe it was not offered until later in '40. Originals are hard to come by but Drake did make copies years ago and some are floating around on the secondary market. You can still be lazy and have one.
    Stogy and Mr.Norton like this.
  14. 1946caddy
    1946caddy
    from washington
    When I got my 40, my son's first comment was how ugly the rear bumper looked sticking out so far.
    I think a gravel pan could be pretty easy to make using a bead roller.
    Stogy likes this.
  15. ronzmtrwrx
    ronzmtrwrx
    Yessiree, that looks much better.
    Stogy likes this.
  16. John 79
    John 79
    from Sweden
    Started to fill the holes for the bumper brackets.
    This whole rear bumper thing is a little side track, got alot of more important stuff to do but sometimes you just want to do some fun stuff. 20250223_160219.jpg 20250223_160443.jpg 20250223_163522.jpg
  17. John 79
    John 79
    from Sweden
    Got the rear axle back together and mounted the brakes/brake lines.
    Put the fuel line back after the kickup work and suddenly it was time for a startup.
    Got it out of the garage so i could have a look, still sits to high in the rear but this is how it will be.
    It might settle a little when i drive it more, still nice to have it moving by own power again. 480289356_23917430154526590_7082039142787063328_n.jpg
    Silva, F-head, treb11 and 10 others like this.
  18. 1946caddy
    1946caddy
    from washington
    I think it sets perfect.
    skooch and John 79 like this.
  19. Besty34
    Besty34
    I agree I think it sits perfect
  20. guthriesmith
    guthriesmith
    It sure seemed lower in the pic with you standing next to it with no skirt. But, whatever the case, looks good. I appreciate you do***enting what you are doing since I will be doing the same with my 40 Merc soon enough.
  21. John 79
    John 79
    from Sweden
    Yeah, but it always look higher with skirts on.
    guthriesmith likes this.
  22. guthriesmith
    guthriesmith
    True. Seems I am going to have to notch mine pretty good too if I want it as low as I’m thinking. And, the Mercs have to have skirts. The wheel opening isn’t as nice of a shape as the Fords.
  23. John 79
    John 79
    from Sweden
    [MEDIA] [/MEDIA]
  24. 6sally6
    6sally6
    Once you fill the trunk with luggage and 'STUFF'... it will drop some more.
    You married ?!! (she can make LOTSA luggage for a trip)
    6sally6
    Nice ride BTW
  25. John 79
    John 79
    from Sweden
    Yes im married! The gas tank is empty to so some gas and tools will do the trick
    Okie Pete and guthriesmith like this.
