Projects 1939 Ford Convertible Sedan Resurrection
Discussion in 'The Hokey Ass Message Board' started by The 39 guy, Sep 6, 2020.
  1. bchrismer
    bchrismer
    Sam,
    Your build is so far beyond my skills, which makes it WAY beyond my budget. This is going to be an amazing car.
    b
    The 39 guy and Weedburner 40 like this.
  2. Man, it's hard mentally to take that step backwards when your mind is so close to and ready for paint! Good on you and Don for taking the time and effort to make the right repair.
    The 39 guy likes this.
  3. Rramjet1
    Rramjet1
    You’re making great progress Sam and Don.
  4. patsurf
    patsurf
    darn nice job!
  5. The 39 guy
    The 39 guy
    Most of the time I feel this car is beyond my skill level. Budget ? I gave up on the budget years ago! . Hopefully we will finish it before I run out of wealth and health.
    Thanks Tim, This is a constant problem, especially in this final bodywork and painting stage. Nobody likes doing things twice but it seems that especially in this painting process we have to stop and compare my expectations with the reality of our skills. Doing things twice has strained our working relationship a few times but we are working through it.
    Thanks John! I hope you had a good trip home ( despite your problem) from the cruise in.
    Thank you patsurf!
    Well it's been another busy month around here. Don's been fishing and camping a couple of times. I have been doing yard work and seasonal maintenance and putting on a car show while trying to make some progress on this painting project. We are trying to wrap it up before it gets too cold to paint without making my electric power meter over heat from spinning so fast, from trying to heat this shop while ****ing air out of it with the exhaust fan.
    We finally got some paint on the front fenders.
    Fortunately I remembered to pull these running boards out of storage before we tore
    down the paint booth. They appear to have an anodized finish on the bottom side.
    These are Bob Drake reproductions. They are very nicely made but do require some finishing.
    There is some loose rubber on the flanges that needs to be cut off. Otherwise it will
    probably catch dirt and water causing future problems.
    I used 400 grit paper to prep the boards.
    Masking these things was fun. NOT!
    Don applied 2 coats of 2k ( gray) then some sealing primer,followed two coats of black
    Raptor liner. While doing my 40 coupe years ago I just painted some Rustoleum over the
    yellowish coating . Some of that paint has peeled off over the years, so I wanted to be sure
    we prepped and coated this set properly.
    We had been doing some color sanding on the front fenders so I covered them up
    for today's project.
    We started with 2000 and then 2500. I see some places that need some further
    attention before we buff them. It is nice to see them shine ( with water on them) during
    this process giving us a glimpse of the shine we are striving for.
    While Don was camping last week I just could not resist putting some bling on this
    grill.
    This makes me smile!!!! It took me much longer to install these strips than I thought it would.
    I guessed wrong and installed one whole side of them upside down! Those little clips that hold
    these strips on are a pain to work with. It takes 4 of them for each of the 26 pieces. Darn things
    would fall off of the far end while I was working at the opposite end,trying to line them up
    with a hole in the grill My hand was sore from slamming them down with the soft side of a
    closed fist. I finally got the process figured out after a few hours and the process went much
    quicker on the last 25 or so. They do not recommend using a rubber hammer for this. It is too
    easy to bend the pieces. Over all I rate this reproduction stainless grill trim a 5out of 5.
    One last item for tonight. while don was away fishing I did some work on the ch***is.
    One of them was swapping out the disc brakes. This is the same metric brake I am using
    on my 40 coupe. The new one on the left should provide much better braking than the little
    Mustang 2 unit it is replacing. My experience is that you don't need power brakes if you are
    running these discs up front.
    Yes they are a little wider, but I compensated for that with some ch***is mods.
    That's it for now. I should be back soon with some pictures of shiny black body parts.
    We hope to get the paint booth down and the ch***is and body into the working shop
    before the snow fly's. We are looking forward to the ***embly phase. We expect the 4 door
    body to give us some grief when we mount it to the frame and try to get those door gaps
    back to where they were before we pulled the body off for paint work a year ago.
  6. Wow great update Sam! Looks fantastic!
    I'm glad you made the comment about the Rustoleum peeling on the bottom of the running boards on your coupe...that's what I used on mine. Might need to re-think that.
  7. The 39 guy
    The 39 guy
    Thanks Tim! I don't think it was the paint. I think I did not prepare the surface correctly. Good old spay can Rustoleum has actually severed me well on other parts of the 40 coupe. I used some of it to patch a poorly painted
    piece of the frame in the engine bay. It has held up well.
    anothercarguy likes this.
  8. The 39 guy
    The 39 guy
    We started buffing out the fenders today! This picture just dose not show it's true shine,
    or the big smile on the face of the 39guy taking the picture. Black is a lot of work!
  9. The 39 guy
    The 39 guy
    Don buffed out the left rear today. The front fenders are buffed out and stored away in the car trailer
    for now.
    I have been on this inner fender for awhile. These were shot in single stage black. There
    was just too much orange peel on these panels. The flat surface is easy to sand, the 37
    louvers..........not so much. This is a lot of hand work and my arthritic hands are not liking
    it at all. I am thinking the stock panels would have been a better choice....
  10. That's a big job Sam...lots of hand work with all those louvers. I don't envy you on the task! It's looking great though.
  11. ronzmtrwrx
    ronzmtrwrx
    You’re doing great. Keep up the good work and just remember, if it was easy, everybody would be doing it. :)
  12. The 39 guy
    The 39 guy
    Well it has been another busy month. The last big item to paint was the hood and we have been on it for about a month. We painted the inside first. We had a lot of runs to fix.
    Eventually we managed to get it pretty smooth.
    The yellow tape covers all of the stainless trim attachment holes.
    The top surface was painted next and allowed to season for about 3 weeks before
    color sanding and buffing.
    Note the thin masking plastic covering the walls of the paint booth. Don does
    a great job with a buffer but he can really make a mess ;) That foam pad was a really
    fast cutter but it ended up causing a problem.
    Just a before and after shot.
    The hood was coming out great until the this happened. We think an over aggressive
    foam buffing wheel ripped the paint loose here. So we had to sand the hood down
    again and fix these flaws before re-clearing the whole hood again. We put 4 more coats
    of clear on.
    I did some sanding and then used an air brush to apply some black base coat to the
    damaged areas before applying 4 more coats of clear. We will let this sit for awhile
    before sanding and buffing it with a less abrasive buffing pad.
    This was my new idea for supporting the hood for painting. It allowed better access to the
    flanges/ edges of the hood where they meet the fenders. Worked well.
    We shrunk the booth to half size a couple of weeks ago.
    We supported this back wall and then dismantled a bunch of the booth around it
    We then carefully slid the free standing wall over and inserted it into the remaining
    booth.
    The process went pretty smoothly and we now have a smaller booth which allows
    us to move the project ch***is back into the shop.
    You can see the black or gray area of the floor which shows the floor area gained by
    doing this. We ended up with a 13.5 foot by 27 foot work area. This should be adequate
    for ***embling the car.
    This is the new routing for the exhaust hose.
    That's all for tonight, thanks for watching.
    Squablow, SS327, woodz and 10 others like this.
  13. joel
    joel
    I'm glad to see you making progress . That cut and buff on the the right half looks great. I found it's a lot of work just to re-arrange things so you can have a suitable space to work. I'm doing that here and doing snow removal also. We haven't seen this much, this fast in quite a while. Keep up the good work.
    05snopro440 likes this.
  14. Great progress your tub is comming out great. JW
    Kelly Burns likes this.
  15. It's looking great Sam. I too have experienced and fear the dreaded buff through! It ****s! Fingers are crossed that it goes better for you guys on the second p***.
    Good plan on shrinking the paint booth to gain more working space. I'm setting up a paint booth in my shop as we speak, in my mind I'm trying to figure out how I'm going to get the big pieces (body and ch***is) in and out of the booth and past each other within the confines. It's going to be like one of those sliding square puzzles we had as kids.
    Keep up the good work!
  16. 05snopro440
    05snopro440
    Snow removal can take up a ton of time!
  17. 05snopro440
    05snopro440
    The car is looking great. Those little issues are frustrating but it looks like you recovered quickly from it.
  18. AmishMike
    AmishMike
    Came in to check your progress & happened to read post #1 again. Wow, great job & coming together as you planned. Great build!
  19. Bandit Billy
    Bandit Billy
    Yes, it is, but it is also very, very rewarding when done correctly and it looks like are doing just that.
  20. AmishMike
    AmishMike
    The problem with black after all the work to have good body to receive black - keeping it looking good in the future.
    Weedburner 40 likes this.
  21. neilswheels
    neilswheels
    from England
    Going great guns Sam, loving the updates.
  22. The 39 guy
    The 39 guy
    Thanks Joel! We still don't have measurable snow down here in my valley but they have opened the ski hill in the mountains nearby. I am not looking forward to moving snow around.
    Thanks John Lee, Good to see you are watching.
    We will doing our tetris moves in week or so. I hope the snow holds off another week or two since we have to load the body onto an open car trailer to move it from the clean bay to the work bay.
    Thanks, Yes you have to have a high degree of resilience and penitents to build one of these cars.
    Thanks for checking in Amish Mike!
    Yes black is almost as pretty as chrome :)
    Yep....
    Going great guns.....some times I think....just shoot me....;)
    Hope you all had a great Christmas!
    The 4 coats of clear and a lot of careful sanding and buffing resulted in this shiny piece!
    It took us a long time but the results are worth it. This body and paint work tested our
    friendship many times. I am so very thankful for my friend Don's patience and hard work
    which gave us this great result.
    As soon as we moved the ch***is into the shop we pulled the engine and transmission out of it for
    painting and detailing. This engine was built a long time ago. It is kind of a mystery. All I know is it is
    a 350 with a small B&M super charger and a 750 Holley. It also has 1.6 roller rocker arms. I don't
    know what the cam is or compression ratio. It was supposedly built by someone in the mid west that
    built engines for NASCAR.
    I have never used a supercharger before and I am not sure if I will like the noise it makes. I have only run
    the engine twice in 20 plus years. But it ran well. If I, or especially the wife, don't like the noise I will
    swap the engine out for a a 383 stroker.
    Those blue washer things surrounding the allen bolts will be going away. You can see
    in this picture how difficult it is to get access to the manifold for cleaning.
    I have never seen this type of rocker arm before. They look pretty stout though.
    We discovered the intake gasket had a very small leak while I was sneaking a peek
    through the distributor hole in the manifold, so it had to come off. I tried for quite a while
    to find a Fel Pro1205 intake gasket set like this one but apparently it is not made anymore.
    So we will be trying something else from Fel Pro.
    I installed a Pertronix kit in the old tach drive distributor.
    I struggled with the cleaning this manifold while it was still on the engine. The areas
    marked with arrows had not been polished previously and the sand cast finish was the
    second complication. Just being hard to get at was the other problem..
    I tried to find a new gasket for this blower to manifold connection but could not find
    one with the exact dimensions. So I will be making one.
    I bought a lot of abrasives for this project.. That table top Dremel type tool ( Black and Decker)
    came in pretty handy. Some of them were worthless. The usual progression was 80 grit wheel,
    or drum sander, 180 grit sandpaper, 400 grit sandpaper, 600 grit sandpaper, felt wheel with
    buffing compound and finally hand polishing with aluminum polish.
    Well it took several afternoons to get to this stage. I can see why the factory guys skipped
    polishing those tight areas. You can see the mess of tools and sand paper ac***ulated
    on just the last day. It is not Bandit Billy bright but much better than it was.
    Thanks for watching and Happy New Year!
  23. SS327
    SS327
    I think those are Cam Dynamics rocker arms.
    The 39 guy and ronzmtrwrx like this.
  24. That engine looks like some pretty nice pieces bolted together. With the intake off, it might be a good time to bolt on a degree wheel and put a dial gauge to one of the lifters to determine what cam is in there.
    My brother has run that blower set-up on an sbc in his Willys for close to 15 years now. It doesn't build a ton of boost (4-5 psi), and doesn't make a bunch of noise so it's easy to live with. It pushes his Willys down the quarter in 12.0's...so it's a fun very streetable combo.
