Technical 1939 Ford Front Wheel Size
Discussion in 'Traditional Hot Rods' started by rejuvinated, Feb 6, 2024.
Tags:
  1. rejuvinated
    rejuvinated
  2. alchemy
    alchemy
    Are you in the right place? Sounds like large diameter rubber bands to me.
  3. rejuvinated
    rejuvinated
    I think so.
    Car is being built as a Street Rod with custom TCI frame, 9" Ford rear, LS3, and 4L60E. Running 18X9's on the rear with 275/40-18 tires. Just need to figure out really what offset or backspacing for the fronts with that 225 tire.
  4. alchemy
    alchemy
    I think everything you said is foreign. The HAMB is for traditional hot rods, not LS and IFS.
    lothiandon1940 likes this.
  5. rejuvinated
    rejuvinated
    If I'm in the wrong place I'll certainly retract my post. Did traditional hot rods use anything but flatheads, straight axles, and banjo rear ends, or would that be a Custom Hot Rod?
  6. gimpyshotrods
    gimpyshotrods
    "5. As mentioned throughout these guidelines, the H.A.M.B. focuses on TRADITIONAL hot rods and customs. Posts pertaining to traditionally inspired, but not quite period perfect belong on the main forum found here. Please note that we don't focus on things such as modern fuel injected motors, big-inch wheels, frame clips, after market independent suspensions, etc... at all on the H.A.M.B.. As such, posts that stray away from the "traditional inspired" will be deleted."
    https://www.jalopyjournal.com/forum/threads/the-h-a-m-b-rules-guidelines.44274/
  7. tippa77
    tippa77
    from Finland
    My '39 uses 6.00-16...
  8. gimpyshotrods
    gimpyshotrods
    Nothing after 1965, with rare exceptions, mostly for safety (seat belts, brakes, etc.), and ability to maintain modern road speed (overdrive transmissions, etc).
    Of what you listed, only the car body and the 9-inch rear end are acceptable here.
  9. rejuvinated
    rejuvinated
    I aplogize for the error. I figurred car guys were car guys.
    I'll delete my post.
  10. lothiandon1940
    lothiandon1940
    ...Take two steps back and re-read what this place is all about.
  11. gimpyshotrods
    gimpyshotrods
    We largely are.
    This forum has rules set by the owner. Everyone is required to follow them.
    Many of us have cars that cannot be mentioned or featured here. That's fine.
    Speccie, lothiandon1940 and Just Gary like this.
  12. 65standard
    65standard
    Front wheels are 16x4 wide 5’s
  13. i.rant
    i.rant
    Google “ How to measure backspace”……….;)
