Technical 1939 Ford Pickup SBC vs SBF
Discussion in 'Traditional Hot Rods' started by The37Kid, Nov 2, 2017.
  1. The37Kid
    The37Kid
    Thanks, I'm really into closed hoods, open ones mess up the lines. SBC is bought and paid for along with what I believe is a NV3500 five speed, bought a set of original Oldsmobile Rocket valve covers, so I'm good to go. Need to track down the HAMB guy that built the '53? Chevy pickup the combo came out of. Bob
  2. scrap metal 48
    scrap metal 48
    I'd rather have a Chevy with a mechanical fan than a Ford with an electric fan....
  3. The37Kid
    The37Kid
    Always wonder what is the least number of wires needed for a running registered vehicle.
  4. 55styleliner
    55styleliner
    I had a ‘40 pickup with a 289 in it with the stock firewall.
  5. InstantT
    InstantT
    from SoCal
    Given the choice of those 2, I'd go chevy.
    Given any other choice, I may say different.
    Sent from my LGLS992 using The H.A.M.B. mobile app
    The37Kid likes this.
  6. I'am not brand loyal Ford in a Ford, however I have always felt if you're going to build a S.B.C. it should look like a S.B.C. After all they are every bit as traditional as a 324 Olds.
    [​IMG][​IMG]
  7. Rocco611
    Rocco611
    from Madera Ca.
    I would go with your gut Ford in a Ford . My 32 Ply Pa coupe I built in High School has had a SBF in it since 1976. when my brother drove it ten years before me it had a 265 chevy and a powerglide before that it had a studebaker champion 6 ( my dads favorite engine of all the swaps. ) I plan on rebuild when I retire, in the back of my mind always wanted to build it all mopar, thinking hemi this time around.
  8. rd martin
    rd martin
    from indiana
    im a chebbie guy, please no hate mail! i have always had access to lots of chevy parts, so thats what ive have done over the years. i have put 3 chevys in forty fords. if you cant decide, i will send you my the****** ph number.:rolleyes:
  9. divcoguy
    divcoguy
    Read that you were thinking about putting a ford engine in a '39 pickup. I have a ford in my '40 coupe. It's a 302 with automatic ******. Appears that part of the firewall is trimmed a little. If you want to see a picture of it, I can take one or come look at it.
    The37Kid and tb33anda3rd like this.
  10. InstantT
    InstantT
    from SoCal
    My 39 is getting a sbc, too.
    In my opinion the sbf will NEVER look as traditional as a smallblock chevy no matter how you dress it.
    My original plan was a y block, but that motor needs a go through. Then I saw a red 40 at the early ford store with an old sbc. I can't even describe it. It's as if Henry built that car knowing sbcs would be available someday. Gorgeous!
    saltracer219 and scrap metal 48 like this.
  11. 210sedan
    210sedan
    from upnorth,wi
    well said sbc it is
  12. Ken Frazier
    Ken Frazier
    You mention in your post about a 38-39 club. How do you access this. I'm building a 38 PU and I'm sure this would be a great resource.
  13. 1946caddy
    1946caddy
    from washington
    LOU WELLS likes this.
  14. slim38
    slim38
    from Sudan TX
  15. I'm a Ford guy, and other than the 2" extra length in the water pump, the SBF and SBC are almost exactly the same size. And having the distributor in the front means you can 'cheat' the engine back further without having to worry about distributor clearance. Plus the Ford is 100 lbs (221-302) or 50 lbs (351W) lighter... before you add aluminum heads/intakes.
    I'll agree that 'dressing' one to look vintage is much harder on a SBF, but it can be done. There a fairly wide variety of intakes available for the 289-302 including 3-2s and 2-4s, tunnel rams, plus Webers. The 351W not quite so much, there's two 2-4 intakes available (Edelbrock, but it only accepts Edelbrock carbs) and the Price Motorsport unit that uses 'Ford traditional' Holleys, as well as a Weber set-up.
  16. krylon32
    krylon32
    from Nebraska
    About cutting the firewall. Many years ago I watched as a died in the wool Ford purest (Moose Marion) put a SBF in his 34 Vicky without cutting the firewall, always wondered how he did that?
