Technical 1939 Ford pickup spring
Discussion in 'Traditional Hot Rods' started by FECH, Jun 11, 2024.
  1. FECH
    FECH
    Just to double-check before bending back. Is the correct end the one that is straight RH side?
    I ***ume the one in the picture should be fixed.
  2. alchemy
    alchemy
    I’m guessing the perch was bent for a reason. Who would go to that work for no reason? Maybe try to find out why?
    Notice that somebody wailed on top of the end of the axle with a hammer? Something was probably bent, and a Neanderthal fixed it. Might not be pretty, but maybe it’s square now. You go adjusting things back and it might not be square anymore. Have you done any measuring to determine that the important parts are out of whack?
    Budget36 likes this.
  3. gary macdonald
    gary macdonald
    Do not bend yet ! ONLY BEND IF NEEDED AND IT DOE NOT LOOK LIKE ITS NEEDED !
    It was bent for a reason by someone that knew a thing or two .
    It would only need to be rebent if it was not parallel with the other side .
  4. FECH
    FECH
    Thank you all for the helpful information!!
    I will try to find the original main leaf and the second one. Please help with the dimensions, so I will purchase the correct ones.
