Features 1939 Ford Tudor Front Shocks
Discussion in 'Traditional Hot Rods' started by ZeGermanHam, May 22, 2020.
  1. ZeGermanHam
    ZeGermanHam
    Hey Folks,
    My brother is restoring a '39 Ford Tudor to be a traditional hot rod similar to what our dad drove when he was young. Brother is somewhat new to the early Ford V8 world (as am I), and he had a question about the front shocks. The attached photo is a few years old (frame is now completely restored), but the question is about the origin of the front shocks shown in the photo. We had ***umed they were original '39 Ford equipment, but a prominent member of the local Early V8 Ford club said they were not original, and he didn't recognize them as being from something else like a Ford truck from the same period.
    I'm ***uming it would have originally had lever type shocks like the rear? Anyone recognize what is shown in the photo? Thanks in advance.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    those cars were born with lever action shocks, what you have there is an early aftermarket tube shock kit
    dana barlow and lothiandon1940 like this.
  3. flatford39
    flatford39
    what Moriarity said.
    lothiandon1940 likes this.
  4. ZeGermanHam
    ZeGermanHam
    Thanks Moriarity. Given that my brother is going for a 50s/60s hot rod vibe (i.e., not 100% original hardware), is there any reason why he shouldn't stick with the tube shock setup? I know when people sometimes modify suspensions it can lead to an undesirable/unsafe outcome. Not sure if this layout falls into that category, or perhaps it's commonly done and a well-established method.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    that setup is perfectly acceptable and was a fairly common modification done back in the day
  6. ZeGermanHam
    ZeGermanHam
    Great, thanks for the info! Much appreciated.
    dana barlow and Moriarity like this.
  7. ronzmtrwrx
    ronzmtrwrx
    Look just like the ones on my old 39. I figured they were an aftermarket piece as they bolt in the same holes where the original lever shocks mounted. Adjustments.JPG
  8. ronzmtrwrx
    ronzmtrwrx
  9. ZeGermanHam
    ZeGermanHam
    Yep, they definitely look the same as the ones on your old '39. What's odd is that my brother said they have a Ford stamping on them, suggesting they came from another Ford vehicle rather than aftermarket. Not sure if this is actually true, though. I haven't looked at them closely myself.
    Yep, it was originally a V8-60 car, but is being modified with a hot-rodded Mercury 59AB engine like was in the '39 my dad drove when he was a kid.
    dana barlow likes this.
  10. olscrounger
    olscrounger
    Have used several sets of those on 40's-believe they may be later Ford as they had a Ford stamp as well. They work fine-better than some of the aftermarket kits. Only issue is that they can contact the inner fender panel and cause front sheet metal alignment issue-have to correct that.We made a 3/8" steel plate to space it out and welded to the bracket bolt area--also shortened a few at top for different shocks--all worked well.
  11. cs39ford
    cs39ford
    I got same set up on my 39. They Work well. Been that way since the early 1990s on mine.
  12. alchemy
    alchemy
    I think they may be 1948 Ford parts. Maybe.
  13. olscrounger
    olscrounger
    Yep--46-48 I think
    lothiandon1940 and Moriarity like this.
  14. FritzJr
    FritzJr
    1948 was the first year for the tube shocks. 1946 and 1947 still had the lever shocks. The '48 shock brackets were and easy way of updating older models.
  15. ZeGermanHam
    ZeGermanHam
    Any idea which models? I've been googling stuff like "1948 Ford shock mounts" and nothing shows up in the image results. I'd love to figure out what type of vehicle they came from if they are actually a Ford factory part from later on.
  16. olscrounger
    olscrounger
    Fritz says 48-p***enger cars I think-I see them now and then on ebay--they work well-as said , much better than aftermarket in my opinion
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    here is a diagram of the shocks and mounts. I am back to thinking that what he has above is aftermarket
  18. ZeGermanHam
    ZeGermanHam
    Just got a photo from my brother confirming they have a Ford logo and part number, so I guess they aren't aftermarket. That said, they look nothing like the ones you posted above. Peculiar.
  19. olscrounger
    olscrounger
    ^^ I have never seen this type. The ones I have used only have two mounting holes and line up with stock holes in 40 frame. Also have Ford stamp. These look interesting.
  20. ZeGermanHam
    ZeGermanHam
    Not sure if you're referring to my post or Moriarity's. The front shock mounts on my brothers have two bolts and appear to use the stock holes on my brother's V8-60 frame.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    hmmmm interesting.....
  22. olscrounger
    olscrounger
    I was referring to Moriarity's post above. The ones you show I have used a lot. The others I have never seen. Just be aware as I mentioned, they can hit your inner fender panel and throw off front sheet metal alignment-easy fix
    Moriarity likes this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    the diagram I found and posted was from van pelt sales, the picture was from ebay, so who knows....
    olscrounger likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
  25. olscrounger
    olscrounger
    Interesting--never seen those-learn something every day-the Ford ones I have used many times on 40's
  26. tub1
    tub1
    from tasmania
    They look the same as all Aussie 46/48 Ford's have ,we had tube shocks from 1940
    67L36Driver likes this.
  27. Graybeard4545
    Graybeard4545
    from Maryland
    I have the same set up on my 40 standard. Tube rubs a bit on fender well.
  28. 67L36Driver
    67L36Driver
    ‘40 with aftermarket tube shock kit.
    No idea who made them. No markings. Frame bracket will fit right or left.
  29. ronzmtrwrx
    ronzmtrwrx
    Took a closer look at mine. They apparently are aftermarket as there’s no Ford marking on them. Only a part number, L & R IMG_6200.JPG
  30. Tim
    Tim
    from KCMO
    The ones @Moriarity shows are 47-8 factory parts. They won’t clear a 46/ earlier car because the inner fenders for the 7-8 have a different shape with a divot for them.
    found that out last fall when I found out they wouldn’t fit my 46’ with out some hammer time.
    the ones OP posted as confirmed already are a very common era correct after market part
