Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. SicSpeed
    SicSpeed
    from Idaho
    Excellent work and planning.
  2. swissmike
    swissmike
    Thanks everybody for the encouragement! I can use it...
    Kage likes this.
  3. HotRodToomer
    HotRodToomer
    Im really digging this build!
  4. Maineac 1
    Maineac 1
    Truly amazing metal forming!!I am truly impressed !Keep up the outstanding work !!
  5. Pewsplace
    Pewsplace
    How did he do that? I would have given up long ago. Nice work!!
  6. Gary Addcox
    Gary Addcox
    That old European craftsmanship is alive and well. Such talent.
  7. Olson
    Olson
    Fantastic problem-solving, and thanks much for do***enting your work so thoroughly. I'm very fortunate to have a nearly rust-free project, currently, but the one on deck will need a fair amount of creative rust repair. It's already clear that this one will be one to save, text and all, for future reference, so it's much appreciated.
    "Plan for the car is a early style custom, with chop, lowering, retaining most of the trim and use of a '49 331 Cadillac mated to the stock Ford box and banjo rear. Hubs and breaks will be changed for repro Lincoln units."
    Sounds like a good plan to me...can't wait to see it unfold. These Mercs don't need much to be stunning. I'm building my '46 as a hot rod for its first go-round, but will re-do it as a custom after a few years. My main change will be to switch to a '41 Merc front clip because to my mind it's already custom.
  8. Sprout
    Sprout
    Great build, jealous
  9. swissmike
    swissmike
    Thanks for the feedback everybody!
    Little more progress: all individual pieces are finished and can now be joined. Here is a joint with the formed flange using the HF flanging tool. The tool does not make a flange quite deep enough for 18 ga so had to be tweaked but now works fine. I love the hole punch on it...
    Aligning the pieces is crucial. The all share a straight bottom surface which makes this easier. The rear piece has an angle towards the middle of the car. I only tacked the vertical wall, which allows me to test fit and tack the piece on the car in the correct angle.
  10. 1952B3b23
    1952B3b23
    from Western MA
  11. swissmike
    swissmike
    Welding the joint solid both inside and outside.
    Same thing with the front piece. This is a straight joint which is easier. Length is critical, so careful when marking and adding the additional length for the flange.
    Here is the right side finished. Lot of work but doing manageable sections makes it possible to do this with simple tools.
    Replacing the trunk section of the floor will be next before welding in the main floor, which still needs a couple of features added. Until next time...
    Kage, chryslerfan55 and DirtyNapkin like this.
  12. Finnrodder
    Finnrodder
    from Finland
    Great work,keep it up!
  13. swissmike
    swissmike
    I have to keep telling myself this is a hobby, else I should have bought a done car. You have to concentrate on one single aspect at a time, else it's overwhelming, at least to me.
  14. swissmike
    swissmike
    That's the one. Had to take the jaws apart and deepen the groove a little to create a flush fit with the 18 Ga.
    Kage and chryslerfan55 like this.
  15. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    You are doing a nice job and I like your effort to make everything look like factory made parts.Following with great intresst
  16. The 39 guy
    The 39 guy
    So true swissmike (one little project at a time keeps it manageable) you are doing a great job on the project and the posts!
  17. El Hueso
    El Hueso
    Great creativity! Where there is a will there is a way.
  18. manyolcars
    manyolcars
    Excellent work, Swissmike! This is 10,000 times better than the dummies who use 1" square tubing for a floor
  19. jakespeed63
    jakespeed63
    Great job, Swissy. Me and the boys need to make a pilgrimage down there in the near future. Still have not forgotten those yummy raspberry pancakes.
    JT
    chryslerfan55 and swissmike like this.
  20. swissmike
    swissmike
    Quick update. I started on the trunk floor...
    It's a goner. I will trim it back to the middle of the axle hump and form a shape that allows room for a straightened rear crossmember.
    Does anybody know what the two circular holes are in the flat part of the floor? One is open and the other is still closed. There is absolutely nothing under that location that needs access as far as I can tell and this floor is specific to that car model.
  21. swissmike
    swissmike
    I will make the floor in several sections. The first section covers the axle and the crossmember. It has two rectangular raised areas where the crossmember protrudes from the frame. I made a wooden buck to form them.
    Here it is in use...
    The shaped feature from the outside next to the stock piece.
    Kage, chryslerfan55 and jakespeed63 like this.
  22. swissmike
    swissmike
    The panel with the bend and flange for the bottom floor. Then added some ribs to keep the panel from buckling. The area in the middle will get a cover to access the rear axle U shackles. I am only going to cut the opening once everything is welded solid.
    I left a recessed flange on the stock floor where the two panes join. This helps me align the panels while inform the features and test fit the piece.
    This was one evenings worth of work. I apologize for do***enting what may be completely trivial to some of you guys, but it keeps me focused and plan ahead. Hope to get the trunk floor completed this weekend...
  23. jakespeed63
    jakespeed63
    Trivial shmivial...Keep those pictures coming! Incredible results with minimal resources and maximum skills.
    rodncustomdreams and swissmike like this.
  24. 36 ROKIT
    36 ROKIT
    Amen to that! Press on...(no pun intended)
    lowcoe likes this.
  25. kustomitch
    kustomitch
    Awesome work. Keep it up!
  26. swissmike
    swissmike
    Finished the first piece. The panel needs some general shaping to match up with the existing edge as well as curvature by shrinking the edges. I found that I needed a little extra clearance over the crossmember rivets, so I just used a piece of pipe to form the dimples in place.
    Next was filling the corners and welding everything solid
    A little clean up and voila...
    Kage, chryslerfan55, kiwijeff and 4 others like this.
  27. The 39 guy
    The 39 guy
    I had the same type of holes in my 40 Ford's trunk floor. I was thinking that they may have been used as access holes for whatever jig they used for lifting the floor pan or the body during ***embly and were filled in after the body was installed on the frame.
    I am really enjoying your build thread! Keep the details coming. I have already observed several great ideas I will incorporate into the floor project of my next build.
  28. swissmike
    swissmike
    39 guy - I think you're probably right about the two holes! Thanks for the feedback.
  29. injunjoes
    injunjoes
    Your creativity and ingenuity are inspiring, keep up the good work.
  30. el Roach
    el Roach
