Features 1940 and 1939 Deluxe Fords.......Lets see em!
Discussion in 'The Hokey Ass Message Board' started by junkmanjr, Jan 31, 2009.
  1. hot rod pro
    hot rod pro
    from spring tx.
    here is my 39 deluxe.
    here is a 40 standard that we built at the shop.
    -danny
  2. OL 55
    OL 55
    HOT ROD PRO ............... very nice sedans !
  3. hotrod40coupe
    hotrod40coupe
    Here is mine taken about 35 years ago. It's in pieces now.[​IMG]
    PONTNAK123 likes this.
  4. George G
    George G
    Here's my '39 deluxe and parts car.
  5. wcreek
    wcreek
    39 Standard found me. Like I needed another project.
    Needs a clean frame, anyone in the east have a decent one?
    What year frames fit ?I just did some work on a 36, and it looks the same.
    RODIST likes this.
  6. Chopt 34
    Chopt 34
    from Florida
    My Channeled 40.
  7. 36 ROKIT
    36 ROKIT
  8. Flat Ernie
    Flat Ernie
    Tech Editor
  9. Wow thats a bunch of cool rides guys. Thanks for the responses.
  10. 39 All Ford
    39 All Ford
    from Benton AR
    Did I see that 39 on ebay a fey months back,, or was that just a very similar one I saw.... I know the one I saw was in Canada, it was red oxide... LOOKS the same... :D
    Funny, I cant remember names for ****, but I remember old cars pretty good... (Unless I am wrong about that car, if thats the case I don't remember much of anything I guess ... :D
    I have been working on my 39 for the past several months, I had to work with my doors A LOT to get the lines to where I HOPE they will look right.
    I even had to "pie cut" the frame section in the rear of the drivers door in order to tighten the radius near the bottom of the door.
    Is this a common issue? or is it because my car was beat to hell over gravel roads for 30 years?
    The p***enger side of the car had been badly wrecked a long time ago (repaired with LOTS of lead), I might have expected fit issues on this side, not to say that I didn't have to work to fit the p***enger side because I did, but the drivers side was worse as far as fit goes.
    Has anyone had these doors fit right without work?
  11. 34hemipu
    34hemipu
    Here's my 40 , wanted to do a "McCoy" look , but mother GM showed me the door so now its in the cl***ified.
      442.4 KB
      487.4 KB
  12. chickenwire
    chickenwire
    from New Jersey
  13. Weedburner 40
    Weedburner 40
    Front fenders are attached to the cowl and running boards. There is one or two bolts throught the inner fender panels into the frame, behind the axle. The grille, fenders, inner panels and air dams that feed the air through the radiator all bolt together at the front. The yoke that attaches to the inner fender panels and sits on the front crossmember holds it all up. Unfortunately, if you have changed to a late OHV engine, or IFS, the yoke doesn't work because the crossmember is gone and/or the crank pulley hits the cross brace. Removing the brake makes the yoke too weak to hold the fenders up properly. We sell a fender support bracket that bolts to the frame rail and the inner fender that cures that problem.
  14. rodncustom
    rodncustom
  15. Johnboy
    Johnboy
    What a great lookin bunch of cars. 39 and 40, two of Fords best years. 32 wasn't to bad either.
  16. George G
    George G
    Yes I believe it was on Ebay. The guy said he sold it on Ebay and when the buyer figured out where Prince Alberta Saskatchewan was he bailed on the deal. I got it for $2500.
  17. Those are some beautiful automobiles. I would love to graft the front end off of one of those years onto my 38 pickup. I saw a pic of that combo once and have wanted to replicate it ever since.
  18. Flat Ernie
    Flat Ernie
    Tech Editor
    You miss the point.
    Resurrecting an identical post is far better use of bandwidth than creating one from new. And make no mistake, these are identical posts...
    However, the length of this thread is precisely why I didn't close it and suggest the search/resurrection of previous posts...
  19. Ebert
    Ebert
    from Keller, TX
    Here's mine...
  20. OL 55
    OL 55
    Ebert, very nice............
  21. tradrod
    tradrod
  22. 40fairlane
    40fairlane
    The blue one I have had about 10 yrs.The red ones are from a Boerne,tx rod run
  23. Pete Fox
    Pete Fox
    from Belgium
    [​IMG]Here is mine 39 Tudor Deluxe together with my 36 humpback!
  24. Pete Fox
    Pete Fox
    from Belgium
    [​IMG]I can not download my pics!
  25. Pete Fox
    Pete Fox
    from Belgium
  26. sodaturk
    sodaturk
    from san diego
    This is my Dad's '39 Deluxe...
  27. Reddy
    Reddy
    My 1939 Deluxe Ford....Mike
  28. OL 55
    OL 55
    Neat picture.
  29. Is that Tony Nancy Yellow?:D
  30. I'm suprised no one has posted a pic of Jerry Moreland (i think thats right) black one. When The Pro Fat movement was getting going with Fat Jack.
