COE 1940 Chevy COE build
Discussion in 'Off Topic Hot Rods & Customs' started by Getfuzzy, Nov 22, 2020.
  1. Getfuzzy
    Getfuzzy
    from NE Ohio
    I haven’t put up any pics for awhile, so winter is starting and my outdoor projects are on hold and I’m working on the 40. I got the dash metal work done for the gauges and ready for high build primer. Switch over to door gaps and door body work. This is after the first round of adding to the doors.
    C840FE32-CB40-46C4-9E50-803051EB0097.jpeg D2E2FFFA-26EA-406E-999C-D632EB291523.jpeg 4BE58D1D-4E2B-44AD-843B-FDB5B31745A1.jpeg 9C320768-BEA8-423C-B8AC-37AEF133F213.jpeg 16C6292C-4083-4362-A37C-04AF0B5E7056.jpeg
    b-bop, neverdun, vintage56 and 3 others like this.
  2. Getfuzzy
    Getfuzzy
    from NE Ohio
    I’m back on it. Been cleaning and priming a bunch on small parts. Remade the lower panel on the cab and doing some metal work on the lower cab corner I replaced a while back. I’ve been getting use to the new shrinking disk I purchased. Tomorrow I start on replacing the belt line with new metal from TS coach works.
    b-bop, RMR&C and lexcoe like this.
  3. Getfuzzy
    Getfuzzy
    from NE Ohio
    Tomorrow we cut. 9F06449D-4B9D-4286-BF0A-0AD4146419D1.jpeg 807EE68C-AF12-495F-968E-A5CC84580EA2.jpeg 0418DE22-3486-4822-8439-83D33CE4CFD0.jpeg
    b-bop, JOYFLEA and vintage56 like this.
  4. wetskier2000
    wetskier2000
    from NH
    that's impressive!
  5. Getfuzzy
    Getfuzzy
    from NE Ohio
    5E8C1910-8837-4CA8-99CB-388EC0A98D92.jpeg 0DC8CE13-B6AD-4E07-9E71-7BC3EA0FC229.jpeg C20D7066-AB9B-4FB0-8C19-014A51E0FA84.jpeg C901B4DD-4319-4B56-89F3-DCFE58D037FD.jpeg
    had a few delays. But got the belt line cut out and the New metal tacked in. Also made new rails that go from the floor to the back cab stiffener. But made them bolt in.
    b-bop, RMR&C, vintage56 and 1 other person like this.
  6. Getfuzzy
    Getfuzzy
    from NE Ohio
    5BFDA432-6F93-4F35-BD32-FA6B23507965.jpeg B67E652C-F5E3-4863-B957-62AA1CCCEE0A.jpeg 428DF526-2B01-459F-B209-DECB87484B9D.jpeg 7ADD18E4-56BB-4AA4-8BEE-4745250D2097.jpeg
    Made more progress today with the driver side.
  7. Getfuzzy
    Getfuzzy
    from NE Ohio
    I finally finished welding in all three of the TS coach works panels.
    This was my first Tig welding project. I’m pretty happy. Now I need to do another round of planishing of the finish welds. 60D43D40-9C6E-4D79-A209-A8D055AB12C3.jpeg 642F2DFE-46AC-4C1F-8E4B-41E27B131CDC.jpeg BB764037-E83E-4AFF-9AA3-99D409DBC047.jpeg 6016ABD2-10D4-4393-AF5A-B293034CFFEF.jpeg
    b-bop, lexcoe, JOYFLEA and 1 other person like this.
  8. JOYFLEA
    JOYFLEA
  9. Getfuzzy
    Getfuzzy
    from NE Ohio
    Took a break from hammer and dolly work today. My dash chrome trim is trashed, so I made new ones. Still need some fine tuning and finishing.
    3AA6F000-FB22-4CC0-9FF0-38616A2DB062.jpeg 03FDAFCF-C373-481F-816D-33AEDC6D67A2.jpeg FEA869A0-9A36-487C-A022-5EBB6AC9C9FB.jpeg
  10. wetskier2000
    wetskier2000
    from NH
    What a beautiful piece, how did you form that?
    JOYFLEA likes this.
  11. Getfuzzy
    Getfuzzy
    from NE Ohio
    1/2” half round Aluminum from McMaster Carr. My old ones fit great but rusted. So used them as a guide as I bent the Aluminum ones. I did so tests with some s****s for the rounding of the ends and for drilling the back sides for mounting 6-32 1/4” long. I think I’m going to round the ends in the center of the dash also.
    b-bop likes this.
  12. I've got a similar situation coming up. The Autocar cab has a couple style lines that appear to be mounted in the pinch-weld on the nose. The originals are stamped sheetmetal, but making new ones out of sheet looks like a can of worms. Maybe your method would be easier. IMG_0286.jpeg
  13. Getfuzzy
    Getfuzzy
    from NE Ohio
    It might work, but with the bends or curves that you’ll need to make. You will need to anneal the aluminum first. It’s not hard to do as long as you have a torch.
  14. After my other post, I looked at MMC and they sell a "half oval" in mild steel that is closer to the shape I need, 3/4" wide and 3/16" thick. If I use that, I can heat and bend it quite easily. You got me to thinking and I thank you for that!
    Getfuzzy likes this.
  15. Getfuzzy
    Getfuzzy
    from NE Ohio
    No problem every once in a while I come up with something that works.
  16. Getfuzzy
    Getfuzzy
    from NE Ohio
    Got the lead out so to speak. Removed the cracked old lead, welded the seam and filled with metal to metal. Letting it set for a few days then finish
    . 05E5C47C-2766-4EC1-A1DF-D5DFB23571EA.jpeg 43EF594F-EE0C-4144-BC68-369A369DF13C.jpeg 97C75A3B-4E9C-432E-82DD-5C03EA84EBEB.jpeg 5686AD06-2A9A-4856-831A-00E81519BDCC.jpeg 842AE251-92AA-4FB1-9AE5-0345B47D8AFE.jpeg 67A86C10-53FC-40C1-B6E3-BF810E359518.jpeg
    b-bop likes this.
  17. Getfuzzy
    Getfuzzy
    from NE Ohio
    9AA79B07-983B-46EC-95CC-5C178431682C.jpeg 2C5F2BFA-FFDF-41DA-8C5D-9C0B9BFB5322.jpeg 6E0AD03C-22FD-419B-9310-A00A663D1279.jpeg
    back to work on the 40, scored a efi fuel tank at the Summit Racing scratch and dent. Mounts made up tomorrow paint and install.
    b-bop likes this.
  18. Getfuzzy
    Getfuzzy
    from NE Ohio
    small steps. Bottom side of cab bed lined. Then a couple days later fire wall bed lined.
    6A001E3F-78D4-451C-84CF-7570195102BE.jpeg 6B4B0418-2645-4B08-8057-C238F11B4B25.jpeg D48633FA-740D-4C99-A5DB-2B3F1D9B3959.jpeg DFA9AFD6-EE2C-4E33-AE3D-75A68A0DDE45.jpeg
    b-bop and neverdun like this.
  19. Getfuzzy
    Getfuzzy
    from NE Ohio
    Here’s some progress pics. Put the cab back on for the winter, and started test fitting the new to me fenders. Had to extend the front of the bottom step to match the fender opening. Also made some new step to frame brackets
    . EA9F4435-09DF-43FC-932B-9F55900DBA55.jpeg 6C4CB0F9-0727-4B28-8C6A-71727378FC22.jpeg F253DDF3-C1AD-4EAD-AE25-B2C46ADD5C53.jpeg D3047742-8D58-4D34-AB17-726D08733345.jpeg 7A978A87-A81A-4B4D-AC15-541F44DE268B.jpeg 2F763F8F-51CA-499B-A556-790B94AAFB88.jpeg
    neverdun, b-bop and RMR&C like this.
  20. wetskier2000
    wetskier2000
    from NH
    Looks awesome... Are those stock fenders for your model year or will you have to put your creative talents to work fitting the grille and hood?
  21. Getfuzzy
    Getfuzzy
    from NE Ohio
    Yes as far as I can tell, they’re 39/40 fenders. The wheel opening is a little smaller than the 40 fenders that came on the truck. It was a pretty easy fix. As you can see in my avatar pic the ones that came with the truck were pretty trashed.
  22. Getfuzzy
    Getfuzzy
    from NE Ohio
    I haven’t posted in a while. Got the under bed box’s mounted, the driver side is for what ever and the p*** side has the compressors, tank, manifold, battery and hydraulic pump.
    Today cut out the treads for the upper step.
    231116DF-2F76-4CC9-B5E9-CC55BC38B316.jpeg 90C29509-E801-4211-B018-70A6E2C7440A.jpeg FC5CD389-49CB-47AE-91FF-E39912B5A6B4.jpeg 8AA1B66A-C7FC-4380-BE0E-6DC5F30A4DF4.jpeg
    b-bop and Gary Man like this.
  23. Getfuzzy
    Getfuzzy
    from NE Ohio
    In the last couple of days, mixed some Raptor liner up with a tint the local paint supplier made ( AL Pavey ) super nice to work with. I really like this stuff! The color looks closer in person.
    ! F64CD074-B864-4647-B19C-58548B3026E7.jpeg 48ACC08B-4E81-4A1D-A1A5-AECDB9670042.jpeg
    neverdun likes this.
  24. neverdun
    neverdun
    Beautiful work.
  25. Getfuzzy
    Getfuzzy
    from NE Ohio
    Thanks it’s just slow going.
  26. verde742
    verde742
    Anything worth having is worth the time it takes " Gramma said....
    actually she was talkin' bout my girlfriend, " said: "Anything worth having is worth waiting for. """
    b-bop likes this.
  27. Getfuzzy
    Getfuzzy
    from NE Ohio
    More things figured out ( like steering linkage with the new column) putting all the brake system back on to finish brake and power steering and booster line. Then radiator and mounts. Oh and access in floor for fuel tank pump
    . 764B89F7-EBE6-4C2E-B9C8-4714F4F2084E.jpeg 23348773-7605-46A1-AC8C-23388AD06D2D.jpeg E5305EC5-648C-4A7D-8A80-2F59BA5D5AD9.jpeg 84C679B6-A984-477D-8AEE-346ED04A6611.jpeg 1E2CAA97-3EA4-4FBF-829E-E88AFC02E562.jpeg
    b-bop likes this.
  28. wetskier2000
    wetskier2000
    from NH
    Nice work!! Does the lower end of that intermediate steering shaft need a support also??
  29. Getfuzzy
    Getfuzzy
    from NE Ohio
    I tried both lower and upper, and the double upper is the one that needed the support.
  30. neverdun
    neverdun
    Did you have to rotate the rack to line it up?
