Projects 1940 ford coupe build
Discussion in 'Traditional Hot Rods' started by newredporch, Jan 9, 2019.
  1. Johnboy34
    Johnboy34
    from Seattle,Wa
    Way easier to do now than later, a lot less cuss words too, [emoji6][emoji41]
    Sent from my SM-G973U using The H.A.M.B. mobile app
    Lifter, Algoma56 and X38 like this.
  2. newredporch
    newredporch
    from pittsburgh
    Yeah, I’d like to skip it but I’m going to cut it now
  3. newredporch
    newredporch
    from pittsburgh
    I decided to play it safe. 97F3A938-83AE-4569-A653-256BB03039DC.jpeg F8D5A814-027C-4488-864C-845175BF706B.jpeg
  4. Done, and now, no worries about clearance. You can add a bumpstop to the inside of frame rail, if you like.
  5. newredporch
    newredporch
    from pittsburgh
    Pretty big day. Cut and welded the notch and primed and painted. 51AB9557-B086-4592-BB61-0BDB211F8FC3.jpeg 7272CDB2-8283-4C5B-BE7C-C76F7A28E5E2.jpeg 8FB33E50-BA20-452F-9497-8A53BF449C94.jpeg FD9DE013-91A2-4EE8-B12E-49ABA81D92C7.jpeg
  6. 42merc
    42merc
    The center section of the rear end will hit the floor pan before the frame.
    olscrounger and okiedokie like this.
  7. joel
    joel
    It looks good; nice job on the frame.
    newredporch likes this.
  8. newredporch
    newredporch
    from pittsburgh
    Thanks. It’s not going to be a show car so it’s not perfect. I just want a nice semi traditional car that’s dependable.
  9. newredporch
    newredporch
    from pittsburgh
    I am trying to make it a “roller”. Things are headed that way. Possibly soon. 03F6BCC5-7DF8-4147-BFF9-BB4A23FA506E.jpeg BBA7F75C-0CDB-483B-8571-10D2489C6B7D.jpeg
  10. Jacksmith
    Jacksmith
    from Aridzona
    50 Merc Man likes this.
  11. Bob Bagley
    Bob Bagley
    Looks good, wish your shop was closer to Va., I need some help with my 40.
  12. newredporch
    newredporch
    from pittsburgh
    And just like the magic on TV shows......... we have a roller BC599F0D-B805-411F-8D99-E0EAD2C0CC8E.jpeg C1A9F97E-BBF0-4E28-90ED-5756FBD25A14.jpeg 45BA53EF-3920-4D44-8567-092C7167E852.jpeg
  13. ibflyin
    ibflyin
    from Tulsa, OK
  14. newredporch
    newredporch
    from pittsburgh
  15. newredporch
    newredporch
    from pittsburgh
    Blasted and epoxy primed. Does this make my rear end look fat? 20B8E9B0-7EAD-4E07-8883-51D3A8FFCE3B.jpeg
  16. newredporch
    newredporch
    from pittsburgh
    7C0A0DC8-3140-4DE4-8625-4A48615063B1.jpeg 85FF14F5-A076-4277-8009-FE9134BC7FB3.jpeg Picked up this little 283 from a friend for 500 bucks. It was in a 1967 Nova. I got to try it before I buy it. It was snappy. I think it’s going to land between my coupe frame rails.
    mvee33, 55 Ford Gasser, brEad and 2 others like this.
  17. brEad
    brEad
    I’m really enjoying your build. Thanks for sharing it. I do have a question though. Looking at the rear end at the leaf springs in this pic. What will keep the axle from rotating in the cradles over time? I had this happen in a truck with a flip kit where the cradles weren’t tall enough to contact the original spring seats.
  18. newredporch
    newredporch
    from pittsburgh
    After I ***emble the body on to the frame and build a driveshaft, I will then set the pinion angle and weld the cradles onto the housing. There isnt a way to know the pinion angle with the springs unloaded
  19. 1971BB427
    1971BB427
    from Oregon
    Your '40 was about the same condition as my '39 Chev coupe when I bought mine in April 2019. I just painted mine recently after building it for the last two years. I had 6 months of replacing metal in the lower 4" of my body too, and all pretty similar to where yours was rotted out. Only good metal down low on mine was the trunk pan. Not perfect, but fairly solid.
    Enjoying your progress, and the whole build!
    Chucky likes this.
  20. chzld88
    chzld88
    Going to be watching this build...
  21. newredporch
    newredporch
    from pittsburgh
    Thanks for coming along.
  22. brEad
    brEad
    Gotcha, thanks for answering that. Makes perfect sense.
  23. newredporch
    newredporch
    from pittsburgh
    Cleaned up the 283 this week. Going to try to get it back in the car next week and figure out the cross member. 7F7D9539-CB8B-44CA-8DEA-81FABFE2C813.jpeg FB458652-D76B-407D-89A7-04ED0CDA7E00.jpeg 83BB6558-6868-4EA2-823A-989B9E325474.jpeg D0405C9A-748B-4D69-8D15-86929322D6EB.jpeg
    chevyfordman, 40LUV and brEad like this.
  24. mickeyc
    mickeyc
    I know its been mentioned here by me and others. That looks like one
    of those cheapo motor stands from the local import tool outfit.
    It appears to already have a bit of a lean. Please be aware that those
    have been known to suddenly fail. Even with a moderate weight
    motor like that Chevy. It would be prudent to consider a support of some sort at the front of the motor. Would not like to hear of an issue to you
    or your project which I have been enjoying observing.
  25. newredporch
    newredporch
    from pittsburgh
    Engine goin in for the last time (hopefully) A01A70C8-D152-4DE6-9CE5-388AAC7F124A.jpeg A8446740-14BF-49AF-8AD0-8172E21F0ECE.jpeg
  26. newredporch
    newredporch
    from pittsburgh
    Spent some time building the exhaust on the hard side A4D3CBED-B901-4827-A7D4-286440FDCBC9.jpeg 70CCBAAA-65B7-447F-BB74-539F0593ED9A.jpeg 8ED0C83B-56B4-4740-B6F6-F9FBE9D01F71.jpeg
  27. joel
    joel
    Just like "factory". Looks good.
  28. 1-SHOT
    1-SHOT
    from Denton
    Early Chevell manifolds fit on the left side and clears the stock box like they were made for the swap
  29. newredporch
    newredporch
    from pittsburgh
    I tend to try and use what I got. Fitting the pipe was not as bad as I thought it would be
    The 39 guy likes this.
  30. lcfman
    lcfman
    from tn
    Looking good,
