Technical 1940 Ford Steering Upgrade
Discussion in 'Traditional Hot Rods' started by Matt C., Dec 29, 2020.
  1. caprockfabshop
    caprockfabshop
    Flathead header is totally different than a 5.0 header, sounds like you need to look at the various block huggers that are out there
  2. X38
    X38
    It's unfortunate @Matt C. never came back so give feedback on the help he was given and how it panned out. That would be helpful.
  3. X38
    X38
    Or do some modifications or make something.
  4. With a small block Chevy in the '38 Ford pickup, I used a manual box out of a '64 Chevelle--not sure if that is the 525, but it came out of a wrecked Chevelle with only 11,000 miles on it. The cool thing about it is that the splines are the same as the orginal Ford box and the Ford pitman arm fits it. Steered easily. The trick on exhaust clearance was to use a p***enger side exhaust manifold from a '67-'72 Chevy pickup on the driver's side.
    stillrunners likes this.
  5. jcb50
    jcb50
    My 39 had a 525 box when I bought it with a flathead. Absolute nightmare!!!! Replaced with a Vega box, its OK but not ideal . I am building a 40 coupe currently and am rebuilding the original box. This is the best way in my opinion.
    I wish my 39 still had the original box, it would be a much nicer driving car!!!
  6. joel
    joel
    FYI Borgesson makes the 525 in both 16:1 and 24:1 ratios.
    PONTNAK123 likes this.
  7. X38
    X38
    Naturally I have to ask why?
    I can't see the installation, but have to suspect there is something fundamentally off with what was done to cause such a negative outcome and ***essment.
    The installation of a Vega box also causes a raised eyebrow.
    Also, when you say '525' and 'Vega', do you know who actually manufactured these? Between installation and parts, I'm looking for clues in the dark.:confused:
  8. X38
    X38
    @jcb50 , still waiting patiently for a response.
    Algoma56 likes this.
  9. poco
    poco
    from oklahoma
    I have a 50 ford with flathead and cannot find parts to rebuild, suppliers advertise parts but are out of stock. What other box can i adapt to the 50?
