Technical 1940 toe boards
Discussion in 'Traditional Hot Rods' started by Thomas Green, Oct 9, 2024.
  1. Thomas Green
    Thomas Green
    Just throwing this out there. Is there any reason someone couldn’t replace the wooden toe board with 3/4 “ pvc sheet stock? It sure as hell won’t rot
    Tow Truck Tom likes this.
  2. Busmania
    Busmania
    from Denver
    I was thinking of making a set out of metal myself. Hard to find the wood ones it seems.
    jazz1 and Tow Truck Tom like this.
  3. Thomas Green
    Thomas Green
    I was at the hardware store and looked at the pvc board and was just wondering
  4. 325w
    325w
    Wonder if PVC would transfer heat into the cabin? Wood would stop the heat better. My opinion only
  5. nochop
    nochop
    from norcal
    Didn’t know they still used wood in 1940, learnt me sumthin taday
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I Believe that may be true.
    Wood is easier to work with, as far as rot,, 80 years from now... who cares?
    jazz1 likes this.
  7. jazz1
    jazz1
    I learned that as well.. I dragged home a ‘48 sedan delivery, rear door frame was wood..
    OP id use wood for toe board, unless shape complex then use tin
    nochop likes this.
  8. Mr poopy pants
    Mr poopy pants
    I didn’t know that they had wooden toe boards ?
    There is some great quality marine ply these days that you can coat with top quality yacht varnish and the like.
    Should last long enough to p*** that ol hotrod over to the grand kids
  9. chevyfordman
    chevyfordman
    Wood is a good sound deadener too and it takes for ever for wood to rot in a hot rod.
    Unkl Ian likes this.
  10. choptop40
    choptop40
    Use the wood and spray or apply to the underside undercoating....my avatar had wood floors and I made new ones out of plywood....
    okiedokie likes this.
  11. V8 Bob
    V8 Bob
    I used 1/8" steel sheet for toe boards in my '40. The main reason was to minimize floor thickness, allowing increased clutch and brake pedal travel with non-stock clutch linkage and master cylinder.
    jazz1 and clem like this.
  12. jumbogem29
    jumbogem29
    from Alabama
    I just bought new toe boards for my 40 ford coupe from Fordwoodart.com nice pieces just paint and install fit like a charm.
    warbird1 and Tow Truck Tom like this.
  13. clem
    clem
    but it might melt……………:D
    PVC would be less resistant to heat and fire than steel or wood.
    probably be the main reason why nobody uses it.
  14. hotrodA
    hotrodA
    Here are mine. PO made them from 3/4” cabinet grade walnut:eek::D HA!
    -Brent- and jazz1 like this.
