COE 1941 Ford COE build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Jul 15, 2011.
  1. wetskier2000
    wetskier2000
    from NH
    Built all the brackets to replace the ratchet straps. Painted the subframe, brackets, Dodge frame and put it all together.. Pics soon... Did an initial lay out the LS1 wiring. Looks like I'll probably add 3 or 4 feet to all the engine harness wires. I can place the PDC and ECM outside under the hood as they were in the Corvette and everything else in the cab.
    Battery placement still TBD.. I'd like to be able to get to it without tilting. My goal is to have all the basics available w/o tilting the cab. Most of this involves just running things like coolant overflow, WS washer, oil fill, dipstick to the front behind the grill. Some are easier then others, of course...
    Thoughts on extending 20 something wires? I'm thinking donor harness I can pull the same color wires from and using heat shrink of some sort. Probably soldered... Ideas??
    Grabbed a right angle brake setup from a JY cube van...
  2. wetskier2000
    wetskier2000
    from NH
    [​IMG]The Aramark cube van on the left was the 90 degree brake parts donor.
  3. kscarguy
    kscarguy
    Good idea on using a second harness fort matching wires. I crimp on bare metal **** connectors (radio shack), then solder the connection and lastly melt shrink tube (westlake Ace hardware) over the wire and **** connector. You will have room behind the seats that you could use for the ecm. That is where all my wiring and fuse panel are located.
    You can use those leftover staps to tie your battery down...HA!
  4. gkent
    gkent
    So who owns the COE in kscarguy's avatar?
  5. kscarguy
    kscarguy
  6. wetskier2000
    wetskier2000
    from NH
    Who's buried in Grant's tomb?
  7. OahuEli
    OahuEli
    from Hawaii
    lol!
  8. kscarguy
    kscarguy
    So what happens when an "un-stoppable force" hits an "un-movable object"?
  9. gkent
    gkent
    So kscarguy, what ch***is is under that thing? Engine up front or behind the cab? What did you use for steering? Anymore info on the build would be appreciated.
  10. kscarguy
    kscarguy
  11. wetskier2000
    wetskier2000
    from NH
    New Wescott fenders. Sure hope they fit.
  12. kscarguy
    kscarguy
    Those look nice. Good thing about fibergl*** is that it is easy to modify.
  13. OahuEli
    OahuEli
    from Hawaii
    Them fenders sure do look purty!
  14. kooscoe
    kooscoe
    This ia A nice COE Build in progres.
    Have fun Building :D:D
  15. wetskier2000
    wetskier2000
    from NH
    I was shamed into doing my own work last night.. I recently met a friend of a friend that's an old school hot rod guy that has some real talent. I showed him the trouble areas where the fenders attach to the cowl and hoped to hire him to make the panels and maybe install them... Instead, he said "these are not as hard as you think". He explained how to do it and told me "You're building this truck, you should be doing this work too".... I know he's right. Oh the shame!
    I actually hoped to farm it out not only because I'm such a newbie, but also to have that part of the work run parallel to getting it running...
  16. kscarguy
    kscarguy
    Show us pictures of what needs repaired, then we can shame you too..HA!!!!!!
  17. flynbrian48
    flynbrian48
    I know the answer to that. I just got a check from Hagerty to fix it...
    Brian
  18. kscarguy
    kscarguy
    ouch...
  19. cabovercholly
    cabovercholly
    Just a quick shout out to a fellow NH coe builder. There aren't many of thes in New England and I really smiled when I happened upon your thread here. Thanks for the inspiration. :) -Cholly
  20. wetskier2000
    wetskier2000
    from NH
    With my head hung low in shame, I shuffled into Harbor Freight and bought the best PacRim shrinker/stretcher 102 dollars could buy. I set it up in the vise and made a test piece out of s**** to fix the cowl area... Having never knowingly been in the room with this tool, let alone use one, I was duly impressed! I did a 90 degree angle on a 6 inch piece and shrunk one side to get the same radius as the wheelwell... It actually worked.. WOW.. I started on a real piece and it's coming along...
    can't post pics right now to the album for some reason... hmmm...
    Where are you located cholly?
  21. wetskier2000
    wetskier2000
    from NH
    Pics of the Pacrim tool and the test piece... I know it ain't much, but for a first timer it impressed me...
    [​IMG][​IMG]
  22. camcb
    camcb
    I'm impressed by your whole thread and my coming across it came at a perfect time. I was planning to stop at HF and buy a Pacrim as well. So it works pretty good eh?
  23. wetskier2000
    wetskier2000
    from NH
    re: worked well?? I really don't have any experience to compare it to, but it did exactly what I wanted it to... BTW: Price was marked as 149.00 and when the cashier asked if I had any coupons, I said "No, but I'd be happy to use any he might have". He said, OK, I can make that 112.00.
  24. camcb
    camcb
    I wondered where the $112 came from. I'll try your tactic if you don't mind.
    I might buy the 36" brake on a stand too.
  25. gkent
    gkent
    Wish i'd known you were after fenders!!!
  26. wetskier2000
    wetskier2000
    from NH
    Why? You got a nice extra set?? How about a right door?
  27. kscarguy
    kscarguy
    Did you ever say what your plan is for your truck? Will it be a pickup, rollback, or ?
    Just curious.
  28. wetskier2000
    wetskier2000
    from NH
    Pickup is the end model, but I'm thinking flatbed w/o the sleeper to get it on the road and then add the sleeper and pu bed as time allows..
  29. kscarguy
    kscarguy
    You'll love the shrinker stretcher. I used a borrowed set to make my boxes and replacement running board splash aprons. You could make your bed using them too. I would invest in a metal saw horse to mount them too. The stabilty helps a lot.
  30. wetskier2000
    wetskier2000
    from NH
    [​IMG]WTH?!?!? The front cab corner patch panel, the new fender and the gravel pan seem like they are WAY off... What am I missing??
