COE 1941 Ford COE build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Jul 15, 2011.
  1. wetskier2000
    wetskier2000
    from NH
    [​IMG]A couple more pics
  2. RMR&C
    RMR&C
    from NW Montana
    Looks kinda like the fender contour is off.....the patch panel may be off a little as well.
    I would install the grille and align the sheet metal off of that. You may have to modify the fenders....
  3. beater40
    beater40
    I can see getting the steering back to where you want is very tricky and the double boxs make it possible, I was looking at a similar situation a while back but if you go one step further and look at the steering rack, by using one isuzu box it will turn the wrong way but if you could find a steering rack from the other side of the crossmember, this will steer the other way. If you understand what Im getting at, a rack behind a crossmember turns one way and a rack in front of a crossmember steers the other. This may be a bit late as you look well under way with your set up, just thought I'd mention if it helps. Nice job your doing with the truck too, cheers.
  4. kscarguy
    kscarguy
    My thoughts...
    1. mount the grill.
    2. fit the lower chin to fit the grill.
    3. Use your new shrinker to curve the patch panel in slightly...VERY slightly since the bumper hole won't twist.
    2. cut the fender right at the edge of the mounting lip, from the bottom up a few inches past where the contours meet. Apply light pressure to spread the bottom of the fender out to align (it won't take much force with the lip cut free). Grind the inside of the fender with 36 grit, feathering the edge back 2 inches, and fibergl*** it back together on the inside. (use aluminum foil sandwiched between the fender and body as a mold release). You might want to remove much of the lower lip and reform it from gl*** and resin.
  5. wetskier2000
    wetskier2000
    from NH
    Hmmm... that's 2 votes to align from the grill outward... The guru I talked to mentioned making the truck fit the fenders... I think I have alot more homework to do...
    Notice how the "legs" on either side of the patch panel's bumper opening are different vertical lengths?? Is that right??
  6. ftw666sgv
    ftw666sgv
    Is that an EMS product? If it is, that would explain a lot. Form my experience, there is a lot of tweaking you have to do to their panels to make them work.
  7. kscarguy
    kscarguy
    Yes, the different leg lengths are correct.
    Make sure that you take time to align the edge of the patch panels with the grill shell. That curve detail is a real pain to get just right. I do not believe that either the grill or the chin should stick out, but don't hold me to it since my grill is so different.
  8. banzaitoyota
    banzaitoyota
    I had a set of stimpled dies for my Horror Fright Shrinker made by someone on metalmeet.com and that was the best upgarde since sliced bread
  9. ems customer service
    no it is not, ems does not make cab over parts
    the ems guy
  10. kscarguy
    kscarguy
    Wetskier, can you put a twist into that coner patch panel to pull the lower fender side corner inwards?
  11. wetskier2000
    wetskier2000
    from NH
    I'm playing with patch panel, gravel pan and fender placement to see if things can line up w or w/o changes...
    Does the running board have 1/2 gap to the lip on the filler panel/valance in the stock setup??
  12. shopdawg
    shopdawg
    from alberta
    It's at least 1/2in.[​IMG]I would like to mention that the original fenders have large mounting holes for adjustment. Do start with the grill surround fitment,also the gap under the doors is important.IMO Looking good!
  13. wetskier2000
    wetskier2000
    from NH
    BTW: The patch panels came from Northern Cl***ic Trucks... Also got door inner and outer patch panels and rear cab corners... Just gotta put it all together somehow..
  14. kscarguy
    kscarguy
    You can pull it together... After everything else you've tackled, this will be easy. just put the radio on loud, and crank it out dude!
  15. wetskier2000
    wetskier2000
    from NH
    Small adjustments and I'm MUCH closer now... I haven't m***aged any metal yet, but I still have a small area that doesn't line up that may need a little shrinking as KS aluded to.... Pics soon...
  16. wetskier2000
    wetskier2000
    from NH
    Just moving the panels a bit and cutting the old metal up further to better handle the patch panel and I'm MUCH closer....
    Thanks for telling me to put in the grill... I see I have wider gaps on the sides near the bottom than I do at the top. I think both sides of the cowl need to come in towards the center...
  17. kscarguy
    kscarguy
    That's looking better. Since your grill does not fit perfectly, just thow it out and buy a new one...Oh, and let me know when trash day is so I can come by and pick it out of the pile...!
  18. wetskier2000
    wetskier2000
    from NH
    Getting real close. I made 2 of the patch panels and mocked them up above the Northern Truck cab corner patch panels... Making progress... Does the grill line up pretty poorly right from Henry? Notice the gaps, they are tight at the top but pretty big at the bottom... Ideas??
    [​IMG][​IMG]
  19. gkent
    gkent
    Here's how mine fits
  20. wetskier2000
    wetskier2000
    from NH
    Thanks! I'm going to look closer... Maybe the hood "clip" attachment points and subsequently the cowl mounting points have been spread apart...
  21. shopdawg
    shopdawg
    from alberta
    The grill surround can be manipulated a little to tighten up the gap at the top. on the first c.o.e i did i had to put a brace accross the grill surround towards the top to help keep its shape. On my 39 i cut the edge at the top on one side and added 3/16in to even up the gaps. I've seen some nice restored trucks and the gaps were not great.
  22. gkent
    gkent
    No intention to hijack this post but this seems like a good place to post since most guys here seem to have Fords ...
    I need a front roof section from a '39-47. In fact just the front corners would do - email me if you have these to spare. The attached photo shows what I need them for to repair. Thanks. email: stanton_giles(at)hotmail.com
    Thanks
  23. wetskier2000
    wetskier2000
    from NH
    Fixing the right rear portion of the wheelwell.. Rotted pretty bad. Had to strain my melon to figure out how to make the part... I did it in two pieces...
  24. wetskier2000
    wetskier2000
    from NH
    2 pieces becomes one...
  25. RMR&C
    RMR&C
    from NW Montana
    Pics aren't showing for me?
  26. wetskier2000
    wetskier2000
    from NH
    Sorry... I pasted the pics instead of Albumming them... How's this??
  27. kscarguy
    kscarguy
    Oh, those bring back memories...before you install them, while it is easy to access, can you try to get some kind of rust preventer up and inside the wheelwell arch.
  28. wetskier2000
    wetskier2000
    from NH
    Aren't my new nuts pretty?!?!?
    McMaster-Carr had them for 10 bucks a box and $5 shipping brought 2 boxes to my door the next day. They call them Weld nuts or Bridge nuts. I was mistakenly calling them Cage or Captive nuts. They go inside the wheelwells and the fenders bolt to them.
  29. phat rat
    phat rat
    You braggin or complainin. Course new ones might help old guys. LOL
  30. kscarguy
    kscarguy
    How many in a box? FYI - Mac's also sells them.
