COE 1941 Ford COE build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Jul 15, 2011.
  1. wetskier2000
    wetskier2000
    from NH
    Is this any better??
  2. wetskier2000
    wetskier2000
    from NH
    200 MPH!!! Yup, that's how fast I went... Oh, OK, it was before calibrating the speedo.. :rolleyes:
    Hooked the LS1 up to a laptop, set up a bunch of things with the help of a buddy... Speedo is correct now, shifts into all 4 gears!
  3. wetskier2000
    wetskier2000
    from NH
    I might have to think about a neutral safety switch... Started it up last night in reverse... Didn't quite need to change my shorts, but close.. Good thing the garage door was open.
  4. HOTFR8
    HOTFR8
    You could make you own using a brake switch. Would mean it could only start in park.
  5. wetskier2000
    wetskier2000
    from NH
    I actually have the Corvette Clutch-Depressed switch that I can use. It's hanging on the column right now and needs to be pressed to start the truck. I adjusted the linkage a bit so it should be in Park on the trans when it's in Park in the cab now.
    Wired backup lights and a horn.
    Began wiring the headlights last night... I found I could get Delco plugs with pigtails to match the Corvette headlight harness plugs. Then I ran the pigtail wires into 1 of the headlights thinking "this is great, I can unplug the headlights right here under the fender.....".... Yeah, not so much! The big 5 pin plug won't fit up the mounting shaft of the headlight bucket or thru the backing plate under the fender. DOH! I'll just use those single wire connectors on each wire so I can unplug inside the bucket. I presume I need to be concerned about moisture inside the headlight buckets as they do not appear to seal at all... Right?
  6. Zuffen
    Zuffen
    from Sydney
    Headlights will work underwater so they won't give trouble in the rain.
    For water to short out 12volts the wires need to be in very close proximity (thousndths of an inch) so with the spacing on the back of a headlight you won't have a problem.
    Corrosion would be my biggest concern.
  7. wetskier2000
    wetskier2000
    from NH
    Yup, corrosion is exactly my concern, but now that we've bounced this around a bit, I suspect there probably is no good reason not to just heat shrink the connectors like I have done for all the soldered splices. These little connectors are the ones for a single wire where one end is female and the other is male, they can be unplugged.
  8. Get the shrink tube with the hot melt glue in it, really seals and encapsulates well.
  9. wetskier2000
    wetskier2000
    from NH
    Yeah. that's what I've been using. It's a little hard to find and usually labeled "Marine". But, the stuff works VERY NICE. With more than 50 splices, I hope it works long term as good as it seems to initially.
  10. Many years ago, I stumbled across a guy selling 2 gallon bags of short pieces for $5 each. I bought a bag of several different sizes, not realizing what I was getting. When I got home I tried some out, and right then "saw the light", I have hoarded it and guarded it with my life, while wiring several different vehicles without ever having a problem. (3 of those vehicles were daily drivers that I put over 100,000 miles on after the mods)
  11. wetskier2000
    wetskier2000
    from NH
    Both headlights mounted, wired and working!
    I am going to use these for the front turn signals. I think I can get 2 in each little turn signal "can".
    They'll be hidden under the stock 1941 gl*** lenses, but I hope they'll be a bit brighter. The front Ford turn signal real estate is pretty small, I'm trying to make the best of what's there in hopes that oncoming traffic might actually see them..
    Anyone got a spare turn signal gl*** and metal bezel/retainer? I only have 1.
  12. wetskier2000
    wetskier2000
    from NH
    modified the front marker light "cups" to hold the LEDs. They came out pretty nice and are hidden by the original gl***..
  13. Zuffen
    Zuffen
    from Sydney
    Wetskier,
    You could have mentioned the Neutral Start Switch earlier, then I wouldn't be in bed for 8 weeks with a fractured pelvis after starting my car in reverse and getting crushed between it and the car behind it.
    Serves me right for not fitting it correctly to start with.
  14. wetskier2000
    wetskier2000
    from NH
    WOW. I'm very sorry to hear of your injuries... I gotta ask... How do you start the car and stand behind it at the same time?
  15. Zuffen
    Zuffen
    from Sydney
    When the rear tray is full of LS3 and all the relays are behind the engine it's easy.
    All the relay's that run the engine are under the alloy cover in the bottom left corner, just in front of the spare.
    OahuEli likes this.
  16. wetskier2000
    wetskier2000
    from NH
    is that motor in backwards for front drive??
  17. iwanaflattie
    iwanaflattie
    Hey wetskier,can u fix ur image for the turn signals?i want to see how that led under a stock gl*** looks thanks! .
  18. wetskier2000
    wetskier2000
    from NH
    Doesn't really do it justice... It's brighter in person than it appears... But I think they'll be seen even in he sunlight.
  19. wetskier2000
    wetskier2000
    from NH
    OK, I feel like a real dunce... I got my fancy new windshield gaskets from Northern Cl***ic..... How the hell do they go in? I thought I'd be getting something that covered the "flange" the outlines the inside of the windshield opening when the windshield is tilted out. I think that's what I peeled off 3+ years ago, but..... These look more like the are designed to hold the gl*** in the frame. My gl*** was gooped in by the gl*** guy.,.. Help!
  20. Zuffen
    Zuffen
    from Sydney
    Wetskier,
    Mounted back to front with drive to the rear via 4x4 transfer case and offset diff.
  21. gkent
    gkent
    If I ordered a windshield gasket I would expect what you got. I would call the piece you need a "seal".
  22. wetskier2000
    wetskier2000
    from NH
    Oh shoot!! Does anyone sell the aforementioned "seal"??
  23. wetskier2000
    wetskier2000
    from NH
    New 20" front tires. It seems likely that I'll end up with 20" tires. There are many more size options than in the 17s that are the minimum size for the Dodge 1500 calipers. Wheel choice is still TBD. I'd like something like a Torque Thrust II, but I don't think I can get them in any size that will work for me. My next idea currently at the top of the list is a stock dodge 20" chrome, spoked wheel. Maybe I could leave the rim chrome but powdercoat the rest in the color of the truck. Like this:
    Here's Buford loaded up on my buddy's trailer and going to get an exhaust system.
  24. daddio211
    daddio211
  25. wetskier2000
    wetskier2000
    from NH
    Slowly increasing how far I drive the COE. Yesterday I did about 50 miles. A mix of light urban, back road and highway... Buford performed quite well. Lots of thumbs ups, 2 "what is that?"s and 1 "That thing is SICK!". (I think that's good, ain't it?)... I've added some plastic behind the grill to make the airflow to the radiator more direct. It now stays about 210 on secondary roads at about 50 MPH, climbs to 220 on the highway at 75 MPH. In traffic the fans come on and keep it under 220. I still think that's too hot, but the Corvette boys say it's normal and the factory settings for the electric fans are higher than 220. I think I can still improve it... we'll see...
    Does this guy look happy??
  26. wetskier2000
    wetskier2000
    from NH
    A buddy took these.... I know the style isn't everyone's cup of tea, but talk about "SICK"!!!!!!!
  27. vintage56
    vintage56
    reminds me of Ramone - "VON DUTCH STYLE!!!"
    http://data:image/jpeg;base64,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**aQIwtSljJ6HxE2NEulklshCgD3XOcniPtQezF94KScqk8Z8/nTzabSG1ZTB0UrvEgqN097haD50U6FSBWS4mVITHeOUD8t/jAjjW7bkDNdROY66Sevs8TbWplbVSEnKgAmNNLzJE+MeVLCRwJlRNlCfDoeNTTb7QQ5lwtPFTzZIKcyLgAkmBcHxm9aN43M5IgC9hJiR8TQu0nDIzk6eQngBw8qGTAMT535U7drgUeO45AKlJbSUxA1EEixjn3aGw+MClQkJEjU24XOlKw5lAOawIt4XFbIxHezWOpEgWOulDanyGy34ba7+HnI5lSk3Sk5kq0APXj8a6ru/vMziEA9qkKAGZJgQek61wFh4BoqJVMjLy4zPWpcDjw24FCSCQVfMjwrY5SjwCSTPpXIOZPn9qx2SeQ871Tdgb9NvqCFJ7MnmbcP1FWv8RyuK7ItPontbJzXhFQB/pWO26fGns3xSvoIIrGWoQ+e**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***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**S0EoRJU2lakglJJ7sjQjlyipxuliInNh/Dt2wfCDWZO2E4TbbYBGdQkQdKGGNyLS4y8QpJkcLjrQ727eLTcM5xzbUhfwSZPkKk2Nu8tx9Lb6VMIsVqWMpAJAAE8TIpdqXI25+j6G2ZtFDjLbgjvpSq2kqAJPrULWIAecgT3UfNdD4Ps0NpSiAhKQExpAFqEGKIfXCZEIE/5jVriTWFjd1zMZpfjsEytWZxInSSojTz615WLVypZisSVPBtQChkKxIgjvAcfGi8kXwPHFJFRU4vELVlBK1Gw91M+gtSjGbKxHbFamVi8jThpoaf7EYcw0lSFpJsYE28rVtidtlthRdd****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**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**xU9Tm/wCTn8kuIJ8L2**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**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**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***Sf6CjRrRsrYqPzKUojmbVM1s1IuAB1gcOtKcftIrQW7yTMi0ixANQbB2vmIQVxlJtJsVCtyC0N8diQwApzMEkxIEpnhJ1HpS/B7ZzZi2ltaUECQvKBOgIV6UyxpSUlJhZIAyqMyCY0Og41Tn93EBZS2VXuqFAjWw6/GnW3yB2XHEbdcTAAMxfKQRPEpUNYqHD7yOOCF2RdKrAHTU1Xm9nKCQlINrJ5jqTw10FbnAho5pzQIM8T151N44h3MmxO1FL78IBSQmw1FvIaVrs3egYd4JUkFspJPOTaZPDpRW6OEweLDiVhxLqFGQlZAUg6EDgQbWq6Yfd3DoAKWGiQAASElVrC51otxjw0Dl8mjLzaiG2wjKE5lFGQhPKTa2vGp9nqTiAbylCo9n2oHEcr1IvCoSVLCUhWUDMACSOIgcBaitk4NJCs6ic0QLJgAWgpvN5muTM1GNlY9le3r3MRiGh2aW0vTZWXUcipOniQao2P3FxTSTmIgA2QrNPSCAr4V2LaAW23mbHaZfyyM8cxHtGqdtHedsG8hY1SsZfpY0dNlyN8cgmoFFXujjA2FjKkkWhQmImFWotO7rzDViHMyTmy3IUbm3K2vwq5YTezDrAk5bcU5gD0iKPaxzRT3****AxJ+tdTnN9omox8HIe0chIIEpgGbERpbWmKnypQMgREjzE/Wr7tXYmHxJBNlJ0IUATMdL+Bmq9j9zFJkoJgzAXAJPRQ86ZT9g2geG24plZyuQg9ZE9UmrTszeNtaMy1QelhPQcBVCx2x3GyolvueZ4XEjhWNl4kJbynLCSAJVcAiY0vTOKaAm0z/2Q==[​IMG]
    JML
  28. wetskier2000
    wetskier2000
    from NH
    that's funny!!!!!!!
  29. vintage56
    vintage56
    I love that movie...
  30. kscarguy
    kscarguy
    Backorder Bob (Bob Drake) might have the seals. If not, you can use two 1939 Ford p***enger car windshield seals and make your own COE seals. You need two to have enough length and you will have to glue the corners. The cross section of the seal is exactly the same.
