COE 1941 Ford COE build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Jul 15, 2011.
  1. wetskier2000
    wetskier2000
    from NH
    That's pretty cool. Thanks... Sort of the opposite of what I need to do, but I think the same rules apply.. He was doing a wheelwell panel and making a curved flange on a flat(ish) panel. I need to make a straight flange on a curved panel... If I understand how this works, I think both are pretty much the same process...
  2. I'd practice on something I didn't care about first.
    OahuEli likes this.
  3. wetskier2000
    wetskier2000
    from NH
    Absotively!
    OahuEli likes this.
  4. wetskier2000
    wetskier2000
    from NH
    A non exhaustive search for tipping dies reveals that none are in my tiny shaft size. I see 22mm and 3/4, but my bead roller shaft is only about .060. Maybe a collar of some sort to make up the difference?
  5. I'm ***uming a typo, .600 not .060? A pair of sleeves should do it.
  6. wetskier2000
    wetskier2000
    from NH
    ordered the Woodward Fab set... We'll see what I get and how hard/simple they are to adapt to my TDK bead roller.. (yes .6 )
  7. wetskier2000
    wetskier2000
    from NH
    Went to a charity car show last weekend... I expected the turn out to be strong, but didn't expect 1000 something cars.... Wow... My wife wanted a more comfortable chair for car shows than our little fold out "bag" chairs... Now she has this chaise lounge thing with canopy, headrest, footrest and integrated coffee maker... Guess what... Yup, barely fits in the sleeper with the seats folded down... I could strap it in the bed, but would prefer a "spot" for it.. I may try moving my new gas tank wall towards the rear a bit, but not as far as I had it before and see if I get that "spot"....
  8. wetskier2000
    wetskier2000
    from NH
    No luck on the chaise lounge... it's too big for any configuration of the fuel tank box... Began layout for the louvers on the new panels... Marked with tape... Left and right will line up with 4 inner rows of louvers in the tail light panels. Center set of louvers line up with sleeper louvers when it's tilted... left and right covers bent up. Larger inner covers next...
    OahuEli likes this.
  9. wetskier2000
    wetskier2000
    from NH
    Tipping dies arrive tomorrow...
  10. wetskier2000
    wetskier2000
    from NH
    Louvers punched in the new panels... No I didn't paint a mural on it, it's just a reflection.... o_O
  11. wetskier2000
    wetskier2000
    from NH
    middle set will get finished after tipping die...
    louvers_in_fuel_tank_covers.jpg louvers_in_fuel_tank_covers2.jpg louvers_in_fuel_tank_covers.jpg
    OahuEli, vintage56, b-bop and 2 others like this.
  12. wetskier2000
    wetskier2000
    from NH
    I just realized I took these pics with my "manstep" in... How embarr***ing! :(
  13. wetskier2000
    wetskier2000
    from NH
    tipping dies arrived... Local True Value bits don't quite fit to accommodate my small shaft... May work with some monkeying around... Or maybe I'll just have to buy a Bridgeport.... :D
  14. OahuEli
    OahuEli
    from Hawaii
  15. wetskier2000
    wetskier2000
    from NH
    Tipping dies fit just fine with some collars from the local True Value... (that's the good news).... I tried using them on a curved s**** piece to try and get a 90 degree flange... (this is the bad news)... I see no way in hell I'll get a 90... 45 I can get but then I run into the nut holding the upper die in place. Even without that nut it doesn't seem that could make a 90.... Am I just missing something obvious here??
    I bent up the two other covers and placed them near where they'll reside.... I'm just not groovin on the large flat surface....
  16. lexcoe
    lexcoe
    hammer and dolly would be how I would do it, the tipping die has done most of the job for you....
    JOYFLEA likes this.
  17. wetskier2000
    wetskier2000
    from NH
    I guess my time has come to actually learn how, huh??
    JOYFLEA likes this.
  18. lexcoe
    lexcoe
    everyday is a school day :)
    OahuEli and JOYFLEA like this.
  19. JOYFLEA
    JOYFLEA
    Starting to sound like Gene Winfield.
    lexcoe likes this.
  20. Zuffen
    Zuffen
    from Sydney
    If the nut was replaced with a half nut (or less) you would gain a little and reduce the hammer work, as it would allow the outer section to turn up more..
  21. wetskier2000
    wetskier2000
    from NH
    I've made some attempts at using a hammer and dolly to repair dents, but haven't had much success... I can increase, decrease or straighten flanges I've made pretty well with a hammer, but dents I seem to just make more of a mess...
    This subject could no be more timely... I backed the truck into the pontoon boat trailer and bent up the panel beneath the louvered tail light panels... ugh....
  22. wetskier2000
    wetskier2000
    from NH
    ... on the big, flat panels that look like cookie sheets... Maybe bead roll them similar to the bed's side panels..... hmmmmm...... My wife says bead roll early Ford V8 emblems into them... I'm not convinced... (nor do I have Blue's talent!) :rolleyes:
  23. wetskier2000
    wetskier2000
    from NH
    I see lots of UTube videos that show a curved flange on a flat panel like a wheel well opening, but none that show doing a 90 degree flange on a panel that's already curved like my donor F-150 panels... It should be the same principal, right???
    JOYFLEA likes this.
  24. JOYFLEA
    JOYFLEA
    On a curved panel I use my shrinker / stretcher to move the flange as much as possible then a dolly laid as flat as possible then hammer it out to my 90 .
    Can you move your tipping die out toward the end with washers and lock it in place with the set screws . Is the shaft soft enough to drill and tap ? If so you could cut the threaded part of the shaft off , drill and tap and pot a washer just big enough to hold the die in place with a Allen bolt like a Mittler Brothers . I know it’s a lot of work but would make it easier for all the future work . Also a flat on the shaft for the set screw would help .
  25. In this video, where he is using a stretcher to straighten his panel, you could use a shrinker to curve the panel more.
    Tip the flange a little, shrink/stretch to keep you curve correct, tip some more, shrink/stretch to correct your curve again, repeat, repeat, repeat.
  26. wetskier2000
    wetskier2000
    from NH
    Yes, Blue the dies do have set screws.. I will remove the nut, move the tipping die to the end of the threaded shaft then create a little flat spot for the set screw.
    I think I get it now... rinse, later, repeat... I was unclear that shrinking/stretching was such an integral part of the process...
  27. wetskier2000
    wetskier2000
    from NH
    I moved the donor F-150, louvered panels as far forward as they could go without actually touching the fuel tanks then trimmed the covers... I'm fairly happy with this version but think I'll still bead roll the tops of the cookie sheets somehow...
    b-bop likes this.
  28. wetskier2000
    wetskier2000
    from NH
    ....and as always, thanks for all the help guys!!!
    JOYFLEA likes this.
  29. wetskier2000
    wetskier2000
    from NH
    after several test tries, I got brave enough to try the actual panel... mixed outcome... Even using the set screw on the tipping die and getting rid of the big nut, I still only get to about a 45... had to hammer the rest... Shrinking is going pretty slow too... But all this seems to be going in the right direction... Quitting for the day...
    OahuEli likes this.
  30. OahuEli
    OahuEli
    from Hawaii
    Remember the Three "P"s
    Patience
    Perseverence
    Profanity
    You'll be fine. I tend to lean on the third part.:D
