Projects 1941 Oldsmobile 98 Coupe Custom
Discussion in 'The Hokey Ass Message Board' started by speters, Aug 30, 2011.
  1. 1951Streamliner
    1951Streamliner
    from Reno, NV
    hahaha i totally forgot that it was you who was building the 48 as well! haha. Oh well, I think the taillights you picked look good. Have you decided what to do with the turn signals yet?
    EDIT: the turn signals in the front of the car ;)
  2. speters
    speters
    I have a set of 47-48 ford ones coming from MAC monday. I plan to put them where the slots are now. You can see the white dots in the pictures where I still had the mock up templates in place.
  3. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Those will look nice. Did you see what it would look like with the turn signals out more towards the sides? It might make the headlights not look so crowded towards the center. Either way it will be a really cool car once youre done :)
  4. mgtstumpy
    mgtstumpy
    Here goes.
  5. speters
    speters
    I tried the turns out wider and it just made the headlights look out of place more
  6. speters
    speters
    It took me almost 8 hours but I was finally able to fit some new springs up front to fix the turning clearance. It also gave the Olds a nice taildragger stance.
    Me in the Olds!!!!
  7. 1951Streamliner
    1951Streamliner
    from Reno, NV
  8. 40StudeDude
    40StudeDude
    Amazing what a set of wide whites can do for a car...now all you have to do is build some skirts for the rears and you WILL have a tail dragger....!!!
    R-
  9. speters
    speters
    Got the motor running tonight! A couple of gas leaks but nothing we could not fix
    http://www.youtube.com/watch?v=Cu7nAMpan7Y
    It sounds crazy because of the open headers. My tubing and mufflers should be were wednesday.
    We were also able to fix the column mount and power steering. We are getting closer and closer!!!!
    One issue I still need to tackle! Once the motor had been running a few minutes one of the freeze plugs sprung a leak, as soon as I touched it with my finger it got worse. The plug is totally rotted away and as soon as I put a screwdriver to it a big hole opened up. I do not have room to get a hammer and screwdriver in there to get it out. I am thinking about using a punch and a air palm nailer to try and get in there. ANY OTHER IDEAS? I will post some pictures of the plug location tomorrow.
  10. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Ive heard that for certain freeze plugs you have to pull the motor to get to them.
  11. speters
    speters
    Morning bump for some more ideas
  12. r7bis
    r7bis
    once 1 freeze plug goes the others arn't far behind. bite the bullet and replace them all
  13. speters
    speters
    I have heard that before. I just need to get it moving by Saturday. After that I will have time to change them all
    I still need to come up with a throttle cable. Any ideas on which cables work with this set up?
  14. speedway adapter and a bolt in ball would be the best guess
    then a camaro cable and accel petal or a lokar will need to fab the bracket off a q jet maybee
    maybee a expandable NAPA rubber soft plug until next week break out the center of the old plug
  15. speters
    speters
    Here is the evil freeze plug
    I haven't tried it more today. I am hoping some pry bars will do the trick.
  16. NashRodMan
    NashRodMan
    Speters,
    To get it out use a small punch and hit it towards the block on ONLY one edge until it rotates. Then use a small pair of pliers to pry it out.
    Paul
  17. Nice car, You're right though a lot of black, the grill and bumper in silver really help to break it up,
    what kind of ch***is did they use for the build? do you know?
  18. speters
    speters
    Tonight I got the freeze plug out and the new one in! I found a few br*** tools that did the trick. I also picked up a throttle cable bracket and I think I have the go pedal all figured out. Brake bleeding and exhaust tomorrow.
  19. speters
    speters
    Not sure on the ch***is. I was told 80s Monte Carlo but I am not sure. This car has a 128" wheel base so I don't know
  20. 46carnut
    46carnut
    I have a 46 Cruzer and I put a 51 pontiac Wheel in it. easy install bolt in. Also ignore the minions and there negative comments, different is the only way to be. If every one is thinking the same no one is thinking.
  21. speters
    speters
    Major updates!!!!
    It drives!
    http://www.youtube.com/watch?v=zr4giLa5M0c
    We drove it back to my house with my friends repair plates last night.
    I got a ton done now that it is back in my garage where I have all my tools.
    Finished dying the seats
    Put these in
    How do you like the bullets?
    Looks better in here than in my warehouse
  22. pwschuh
    pwschuh
    Not bad at all. If you can find them, I would add the art deco trims back to the front fenders, next to the headlights. Wheel/tire combo looks really small on that car.
  23. speters
    speters
    The wheels/tires are small but they are the only size that would fit with the fender modifications the last guy did
  24. csimonds
    csimonds
    Lookin Good Bro! Glad to see you got to take it for a little drive.
    Chuck
  25. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Lookin good man. Would it really be hard to re-radius the front wheel opening and then run teardrop skirts in the back? It looks much better than before now, but i think if you did that and them put some bigger tires on it would really take the car to the next level.
  26. speters
    speters
    Made it to the show!
  27. waldo53
    waldo53
    from ID
    Major improvement! That rear view looks 1000% better than what you had to begin with.
  28. speters
    speters
    We brought the car back to the warehouse to get it out of my garage. Now it is time to sell it
  29. speters
    speters
  30. speters
    speters
